07-03-2016, 12:18 AM | #90 |
Comes to RWD from FWD, with a dream of AWD
Rep 117
Anyone have this error code after coding 2TB?
Code:
Unknown - FKB_CF2101 - No message (shift paddle operation, 0x207) Fault description: The receiving control unit logs the fault when an expected message from transmitting control unit is not received. These types of faults usually stem from interference on the bust connection between the affected control units (physical link). Somehow this error is persistent |
08-12-2016, 01:40 PM | #91 | |
Rep 191
Drives: 2013 BMW 335i M-Sport
I don't need to Code VO? to get sports auto performance? I have a weird 2013 Msport, that didn't come with paddle shifters, BUT, I do have Sport and Sport+ mode available and 205 is listed in the VO. If I change FDL to the above the DS indicator will change to gear output, and I'll have this smooth / quick shifting everyone is raving about??? TIA
2013 335i M-Sport 8spA
2011 M-B GLK350 2000 Dodge Ram 2500 QC 4x4 CTD |
08-12-2016, 01:50 PM | #92 | ||
Rep 397
I just coded FDL and the shift does become faster.
Past: E46 Metallic Blue Coupe 323i GONE: E86 Jet Black Z4 Convertible GONE: E92 Crimson Red 335i, F30 Liquid Blue Matallic 328i Current Garage Queen: Mineral White F83 M4 |
fhlh37.50 |
08-12-2016, 05:28 PM | #93 |
Rep 191
Yup. Best mod I've done so far! Thanks all!!
09-15-2016, 04:36 PM | #95 |
Rep 191
that's correct... that is a good indicator you coded correctly, as is the swifter shifting... it's the best mod I've done to date
10-11-2016, 10:32 AM | #96 |
Rep 7
I FDL coded only these two items on my car (2013 328i Msport that already had the Sport + setting with the 205 option) and it is now showing a check engine light. Any ideas or should I just revert back?
10-12-2016, 10:22 AM | #97 |
Rep 7
Thanks for the reply kretzu.
I ran tool32 for now to clear the code, so far it seems like everything is OK and hasn't come back. If it comes back, I will run Rheingold and see the specific error code. Worst case scenario, I'll revert it back and take it to the dealer for diagnosis. I don't know if it's a placebo effect, but I do feel a difference in the way the car shifts, even in comfort mode. |
10-14-2016, 11:46 AM | #98 |
Rep 296
Is it possible to program sport automatic on a BMW x1 e84? My wife's F30 has sport automatic stock and it's a night and day difference better than my x1.
D Unit
Bay Area, CA |
10-15-2016, 02:25 PM | #99 |
Rep 263
The E84 X1 has a completely different automatic transmission, older generation ZF 6-speed. The F30 we're talking about here is a younger generation 8-speeed ZF 8HP (which has sport automatic option). This could explain the night and day difference
10-15-2016, 02:49 PM | #100 |
Rep 296
That is unfortunate and I believe your facts are correct. I guess I will avoid driving my wife's f30 as much as possible....
10-19-2016, 07:13 AM | #101 |
electrified
32
Rep 127
Hey guys,
I have a question, my 330e didn't come with the sport automatic option, but it still shows S1, S2 etc instead of DS. It shifts really quick aswell, sometime it feels like a jolt when it shifts gears. Can it be that this car has a special gearbox due to the electric motor? Thanks in advance. |
10-21-2016, 12:36 AM | #102 | |
Nemo banks
65
Rep 253
10-21-2016, 12:42 AM | #103 | |
Nemo banks
65
Rep 253
10-21-2016, 08:51 AM | #104 | ||
Rep 962
10-27-2016, 06:59 PM | #105 | |
Rep 35
I coded SAT and was unable to see any clearly identifiable difference (as you point out pushing shifter to the left already brings up S1,S2 etc on the 330e) I keep meaning to code launch control via FDL coding and see if that works. To date I've not been able to see confirmation of whether anyone else with a 330e has done that (successfully or otherwise). |
11-08-2016, 03:32 AM | #106 | |
electrified
32
Rep 127
11-17-2016, 01:05 PM | #107 |
Rep 5
Hi guys,
I have a 2014 335i xDrive with the M sport package but without the sports automatic transmission. I need help coding 2TB since this is my first BMW. Can anyone help me out. I have seen that I need a cable and a few programs, it's what I need to do inside the programs that I need help with. |
11-17-2016, 07:14 PM | #108 | ||||
Rep 8,364
Depending on your EGS, you may not even have LC funktion parameter present. Quote:
12-04-2016, 11:36 AM | #110 |
Rep 6
Hi, this is my first post here!
I have had a 330e for a couple of months now. Rather stupidly I assumed it was a sports auto box as it came with paddles. I don't so much mind the speed with which the gears change up, but the guessing game, entering a corner and manually changing down a gear is infuriating. The delay between clicking the paddle and the gear changing is ridiculous! Plus I don't like how mid corner it still insists on choosing to kick down in to a lower gear. Will the coding change improve this? How straight forward is it to do yourself ? I have ordered a cable. I have also been quoted £160 for someone else to do it for me. So I have a cable on order, I know I need the software and a token? Where is the best place to get this? Any advice appreciated. Last edited by Funkydunc; 12-04-2016 at 11:42 AM.. Reason: Additional question. |
