BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > BMS 3.5in Exhaust Tips Unboxing, Install, and Review
      03-17-2017, 12:46 PM   #45
BespokeM
BespokeM's Avatar
Drives: M2C
Aatish, it looks like the BMS tips are shorter than the stock tips, is that the case?
      03-17-2017, 12:57 PM   #46
Aatish
Lofty
Aatish's Avatar
3458
Drives: i4 M50, 991.2 C2, RRS Diesel
They are shorter from the back end, however stick out about the same, if not a little more.
F30 335 (FBO and BM3 OG)
991.2 C2
Range Rover Sport Diesel
I4 M50 (coming soon)
      03-18-2017, 09:08 AM   #47
STR8-6IX
Drives: RWD 528i N52
looks much better then before. I was skeptical about the burnt colour, but it looks awesome with your paint.
if you debadge the 335i / x drive logo off the back and tint your windows (if you havent already) it will really complete the look of your car.
Aatish3458.00
      03-18-2017, 10:08 AM   #48
overkill1125
overkill1125's Avatar
Drives: 2019 440xi Gran Coupe
Originally Posted by Thisisdudewhoru View Post
Can someone measure the diameter of the stock exhaust pipe that goes in the tips and inner diameter of burger tips?
Burger says they won't work with M performance exhaust but I don't see why they won't if the pipe is same diameter. Only thing I see with my M performance is there is no alignment pin but I can tack them in place if need be
Any update on tips for the mpe?
      03-18-2017, 11:47 AM   #49
Aatish
Lofty
Aatish's Avatar
3458
I'll take some measurements when I'm back, but in theory they should fit.
MPE pipe is a bit larger in diameter than stock. The tips are held by the friction created by the spring arms one the inner wall of the tip.
I'm 90% certain they should fit, but don't have an MPE to test on. If any of you guys have an MPE and stock exhaust tips, try slipping them on. If they fit and stay, then these should fit and stay.
991.2 C2
      03-18-2017, 10:35 PM   #50
overkill1125
That's what I'm thinking that In theory it should fit but no one confirmed yet and it's also stated on the site that it's not for use with the mpe.
      03-19-2017, 12:27 PM   #51
Aatish
Lofty
Aatish's Avatar
3458
Check this out...
http://www.2addicts.com/forums/showthread.php?t=1010102
It's for the 2er, but I'm certain it also holds true for 3er.
991.2 C2
      03-20-2017, 12:02 PM   #52
overkill1125
BMS replied to my email and stated that the tips won't fit the MPE and the tabs will break if I tried.
Too bad and the search continues. Anybody know of other options?
      03-20-2017, 01:28 PM   #53
Aatish
Lofty
Aatish's Avatar
3458
Weld
991.2 C2
      03-28-2017, 07:36 AM   #54
overkill1125
Can't believe that there's no other options besides bmw tips for the MPE.
      02-18-2018, 08:50 PM   #55
thatf30
thatf30's Avatar
Drives: 2017 330i M Sport
2017 BMW 330i  [10.00]
Nice write up! And nobody else noticed the Rolls Royce in garage? just me? Ok... (I'm a fan)
Aatish3458.00
      02-19-2018, 10:46 AM   #56
Aatish
Lofty
Aatish's Avatar
3458
Good eyes
991.2 C2
thatf30136.50
      02-19-2018, 11:59 AM   #57
s2kvee
Drives: 2008 BMW E90 M3
Just purchased a set of used bms tips which came with 1 extra... I’m going to attempt this install on my MPE and I’ll let you guys know how it turns out in a day or 2 when they arrive
thatf30136.50
      02-19-2018, 12:30 PM   #58
thatf30
thatf30's Avatar
Would like to know! Just picked up my MPE today
Thatf30.com
      02-19-2018, 01:12 PM   #59
Aatish
Lofty
Aatish's Avatar
3458
The problem with the MPE is the diameter of pipe is smaller than the stock, by 1/2 an inch I think. You could bend the friction clips to get the tips to stay, but there will be a gap in between the pipe and the inner tip wall.
991.2 C2
      02-19-2018, 02:36 PM   #60
El Conquistador
Drives: M240 Vert - 6M as god intended
Other way around, the MPE exhaust end is 80mm while the stock is 70mm. Some cram their stock tips on since the diameter is big enough, but mushes the spring clips.
But it is hard to find 80mm inlet tips besides the $20 M Performance tips with the $80 ///M etched on or the $300 CF Ms.
      02-19-2018, 04:11 PM   #61
Aatish
Lofty
Aatish's Avatar
3458
That's an option. I think ECS Tuning has some adjustable diameter tips. Not sure if anyone tried them, or if they're still for sale...but hey, worth a shot.
991.2 C2
      02-19-2018, 04:14 PM   #62
Mike@N54Tuning.com
Drives: 2007 335i, 2015 M3
Ya I believe you are right there is a size mis match between 1/4 - 1/2"
Mike
Aatish3458.00
      02-19-2018, 06:50 PM   #63
El Conquistador
Did it fit?
      02-21-2018, 08:32 PM   #64
s2kvee
Did it fit?
yes it did fit.... you have to bend the clips and work with them one at a time... but they fit, fairly snug also...
the outlet of the BMS tip is smaller than the MPE outlet so it will wrap inside the MPE pipe... so when you look at it.. it looks fine.. no gaps
i have black BMS tips which is a tad bit bigger than the M performance tips.. and since i bought these used and cheap. no complaints but i will be looking for a pair of Burnt Slant Tips to replace these.
2008 E90 M3 6-Speed - Sold
2013 F30 335i MSport 6-Speed - Current
      02-21-2018, 08:41 PM   #65
El Conquistador
      02-22-2018, 11:51 AM   #66
s2kvee
Left tip is BMS, Right tip is M performance.
That’s all the pics I took during the install..
Attempt the bms tip install at your own risk, as BMS stated they are designed for the stock muffler, and with the enlarged outlet on the MPE, you risk the possibility of snapping off the spring clips when forcing the install.
Aatish3458.00
