12-19-2015, 10:41 AM | #1 |
Rep 10
Down pipes install- How long?
Sorry for the noob question. Wondering the time it takes to do Downpipes. I'm looking at the VRSF Cattless and am going to have a local mechanic do the work.
12-19-2015, 04:47 PM | #3 |
Rep 190,804
Local mechanic with a lift should be able to do it in couple hours
12-20-2015, 02:29 PM | #5 |
Pace Car Driver
1548
Rep 3,164
12-20-2015, 03:38 PM | #7 |
BMW Fanatic
331
Rep 1,076
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 |
12-20-2015, 04:13 PM | #8 |
Rep 902
Drives: 13' F30 385xi VNV Speed Custom
Garage List 2013 Mercedes SL63 ... [0.00]
2010 VW Tiguan 2.0 ... [0.00] 2015 Tesla P85D [0.00] 2014 Mercedes S63 AMG [0.00] 2007 Mercedes GL450 [0.00] 1967 Ford Mustang [0.00] 2013 BMW F30 335xi [0.00] |
The front drive axle and front diff are in the way. Makes suspension work and turbo work much more difficult. Also charge pipe routing is tighter as is everything else in the engine compartment basically. xDrive downpipe job isn't hard with 2 people, just use a long extension and universal to tighten and loosen the upper V-clamp from the top. Make sure to replace your lower clamp because it's a crush seal gasket and can only really be used once.
13' 335xi, ACF Tuned, ACF Stage 3 Turbo Kit (67mm),PDU PI, ACF Stage 4 LPFP, M-Perf Brakes, AEM CM10 Meth/Nitro, CG DR-1 + VS-1 3.5" Turboback, AFe S2 CAI+Ram Scoop, ER Chargepipe, Wagner EVOII Comp. FMIC, Stop-Tech SS Brake Lines, BMS Sport Oil Cooler Valve+Spacers F10mm R15mm, 19" Bridgestone Potenzas, KW EDC Coilovers, CF Seibon Hood + CSL trunk. Track:Pagid Race Pads, Stop-Tech Custom Pads Front+Rear Racing Tow Hooks
12-20-2015, 10:19 PM | #9 | |
Rep 938
F80 M3-DCT MaxPSI CH, BM3 with F80 Paul E85 and Custom Rom track tune MCS 2Way Remotes
Signature SV104 E46 M3 F85 X5M https://www.instagram.com/fastmacm3/ |
12-20-2015, 11:16 PM | #10 |
Rep 4,323
One hour $150 is all I paid!
12-20-2015, 11:28 PM | #11 | ||
Rep 902
12-22-2015, 11:28 PM | #12 | |||
Rep 4,323
I had to reuse mine too...
12-23-2015, 08:43 AM | #13 |
Rep 6,990
OP - just to clarify, there's only 1 downpipe on an N55 engine. Easier than the N54 that had 2, the rear one being relatively difficult to remove/replace. Shouldn't take more than an hour of labor at a shop that knows what they're doing.
Just be sure you won't run into any trouble with emissions testing for your yearly State inspection. Some states actually "sniff" the exhaust with a sensor where others just look for a "ready" state from the OBDII readout. You'll also get a CEL and the exhaust will have a very distinct smell.
12-23-2015, 01:03 PM | #14 |
Rep 902
Keep in mind these numbers below are for the non-LCI models, only use these if you have a car built before 07/13 and a PWG.
If you have an LCI car with an EWG you have different part numbers. Lower Clamp and Crush Gasket: 18307620349 Upper V-Band Clamp: 11657620508 Upper Gasket: 18307553601
12-23-2015, 05:42 PM | #15 | |
Rep 4,323
And yes I have an OG F30-2012 build date with a *yawn* PWG...
12-29-2015, 06:06 PM | #17 |
Rep 938
I just did mine it was supper easy. It takes about an 1hr to 1.5hrs. Everything is easy to access.
12-30-2015, 12:42 PM | #18 |
Rep 939
12-30-2015, 12:53 PM | #19 | |
Pace Car Driver
1548
Rep 3,164
He even ate supper while he did it. |
01-01-2016, 01:25 PM | #22 |
Rep 4,323
I went to Enzo, in Long Island - it was about a 80 minute drive from Bedminster, but well worth it.
