01-19-2018, 01:58 AM | #23 | |
Rep 182
It can be switched or variable (ie smooth or progressive) depending on what the methanol kit can output. |
gx5_027200.00 |
01-19-2018, 11:42 AM | #24 | |
Rep 1,862
Drives: powered by bootmod3
01-19-2018, 03:44 PM | #25 | |
Rep 182
My thoughts about the Pi were particularly in response to flex fuel and port injection where I think it is totally unsuitable in a way that those not familiar with automotive control tasks may not appreciate when they may look at the GPIO count, processor speed, memory and price only, without considering the specific needs of latency, determinism and interface hardware needed for automotive tasks. If it wouldn't be too much work to redo your existing services to work with an RTOS, I still wouldn't trust soft RTOS tasks anything like automotive grade microcontroller hardware with phased lock loops, peripheral control processors and automotive/industrial geared timer arrays to decode toothed wheels and schedule injection pulses or even communicate with deterministic latency to the DME. By the time you've lost presumably desirable Linux features and added automotive peripherals over SPI, you may as well have an automotive grade microcontroller providing the peripherals where it can autonomously control them over an internal bus without even bothering its own CPU with interrupts. I'd trust a Pi, especially if also running Wifi and ethernet, far less than a dedicated PIC in these circumstances, never mind something more appropriate like an S32K or Tricore. I'm sure there is a lot of interesting stuff that could be done with a Pi that is not time or safety critical, but that isn't port injection or flex fuel. I wish there was more convergence between microcontroller and applications processors, as the amount of RAM and flash is still poor on the microcontroller side. However, when I see Linux, ethernet, an SD card interface and HDMI, garbage collection and a heap, I run a mile from wanting that controlling my engine and see latency everywhere. It all screams of user interface and is great at that. |
gx5_027200.00 valve float162.50 |
01-19-2018, 08:41 PM | #26 | |
Rep 2,357
(A Dane in China) |
01-20-2018, 02:21 AM | #27 |
Rep 182
gx5_027200.00 deezeedee33532.00 |
01-20-2018, 04:29 AM | #28 |
Rep 2,357
Just very impressed with your level of knowledge on this subject. What is your bagground? Automotive engineering?
(A Dane in China) |
01-20-2018, 05:13 AM | #29 |
Rep 182
No because I graduated in medicine not engineering.
Yes because I have been doing electronics and programming for about 35 years, tuning for 17 years including professionally, reverse engineering ECUs and adding new code to them for 12 years. Best known for my previous open source work for Mitsubishi Evo, and commercial work for Cobb on Nissan GT-R adding new features for tuners. I sold a medical practice just over 2 years ago to retire at 40, but after 3 months got bored and decided to get back into ECU code development. Few small contracts, but mostly R&D over the last year on my own initiative and funding. |
01-20-2018, 11:15 AM | #30 | |
Rep 1,127
BMWcurious226.50 |
01-20-2018, 09:06 PM | #31 | |
Rep 2,357
(A Dane in China) |
01-22-2018, 05:06 AM | #32 | |
Rep 182
I think this is a bad idea because every time you open the pump switch and then go WOT at least the first time, the DME will have to react to going lean and knocking. Why not prevent it happening in the first place and use the lambda and knock control lightly and as a secondary line of defence? |
gx5_027200.00 |
01-22-2018, 10:54 AM | #33 | ||||||
Rep 158
Flash Only Meth injection Tuning
The JB4 actually doesn't add boost by itself. You actually tell the JB4 how much boost to add by adjusting the Boost additive. Then if the car isnt pulling timing, after a few pulls, it will add the boost. If its pulling timing and avg ignition goes down. it will reduce boost. Funny thing is, the JB4 has no idea what the DME timing target actually is. Which is why the JB4 does not increase or reduce boost dynamically. it does so over time. Quote:
The TB/MC-1 controller, the current limits for failsafes and etc can be adjusted completely for any pump you use. And the TB/MC-1 can monitor ACTUAL flow by adding a flowmeter. And failsafes can be tied into that as well. The TC/MC-1 also can use PWM for the injection solenoids, regular injectors or PWM the actual pumps. And also can use, Throttle, Pedal, and etc. Pretty much any 0-5v source can be used as a trigger or control medium for the meth or failsafe. BMS has to offer FREE support and Maps to run with their JB4, because IT NEEDS IT to work fully. Kinda hard to make someone pay for something that is needed for your product to work 100% Quote:
Boost control works. I have used numerous External EBC's on these cars without issue. JB4 again, Not needed. Also, below is a couple of qoutes from another thread i was in and meth questions came up. It will expain a bit of how the DME can be tuned to protect itself with meth. Quote:
01-22-2018, 01:34 PM | #34 | |
Rep 115,980
The TC/MC1 is a dumb controller not aware of any engine data so you'll never be able to tie in a safety for engine data like running lean, knock, fuel trims maxing out, DSC intervention, gear, oil temperature, etc, etc. BMS offers free back end flash maps that are fully unlocked because they make their money selling the JB4 and everything else is just to provide their customers with the best and easiest possible tuning options. The JB4 is a powerful tuning device, one that doesn't cost that much more than the TC/MC1 controller, but certain things are best done in the flash map directly. Like VANOS adjustment, speed limiter delete, exhaust burble, base fuel scalar ranging, etc. Having both gives you the best of both worlds without dealing with locked flash maps. Since the fee structure is setup where the MHD flash license, map package, and logging software are all priced ala-cart the JB4 owner only needs the MHD flash license. This saves on the map package, logging package, and custom mapping expenses. Winds up costing the same or less for a much more flexible and powerful tuning solution, with better resale value, and a wider range of support. Mike Last edited by Mike@N54Tuning.com; 01-22-2018 at 01:40 PM.. |
01-22-2018, 02:04 PM | #35 | |
Rep 158
Considering how my post distinctly stated how to tune meth with the DME. I'm still unsure where you got that I'm "Encouraging Spray and Pray". End result: JB4 drops into a lower boost map as a failsafe (IE- drops boost) TB/MC-1 drops boost as a failsafe DME... DYNAMICALLLY lowers boost (load) and increases (in realtime, instantly, not over several pulls like the JB4) as a function of all sensor inputs as a safety. and is seamless integration and nothing can run the engine better. So long story short, which is what was asked. JB4 is not needed to run meth. And you aren't Missing anything when a good controller and DME are used, unless you like the steering wheel controls. BMS offers FREE BEF's because they have to. If they didn't, BEF's wouldn't exist. I calibrate people on all platforms using all methods including the JB4. so I know what it can do and can't do and what nuisances and good things it brings with it. And I never hesitate to tell people what those things are. But don't confuse my statements as hating on a JB4 (as most people do). |
01-22-2018, 03:23 PM | #36 |
Rep 182
Is JB4 logging knock on individual cylinders on MEVD17 DMEs? If so at what frequency? Does it log DME fuel trims or a difference between target and actual lambda to look for AFR error?
01-22-2018, 03:38 PM | #37 | |
Driver
200
Rep 516
01-22-2018, 03:47 PM | #38 |
Driver
200
Rep 516
Again - thanks to everyone for the fruitful debate!
It's refreshing to see people directly addressing what other people are saying, respectfully - and I'm thankful people are speaking from experience. |
01-22-2018, 04:52 PM | #39 |
Father of Frankenfold
299
Rep 531
Drives: Yo daddy's 2014 X3 M Sport
I'm about to run an HPC progressive variable voltage controller off of the tmap as input to it with a harness patch to tap into. Plug and play simple and inexpensive.
I'll be using a tee off of the washer pump output. The WMI pump easily pulls from the washer tank through the pump. The inline pump that feeds the windshield washer nozzles barely impedes supply flow, and certainly not enough to restrict anything. It'll pour the whole tank out under gravity if you disconnect the tube from the pump output. Concerns regarding "it'll catch fire and blow up" due to the washer tank need not fret. It's all external to the engine bay and will be running nothing but OTS WWF. Horsepowerz here I come!!! DME, let your smarts keep me safe when I f**k up and make me power when I treat thine N55 well.
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
FSociety3812.50 |
01-22-2018, 06:31 PM | #40 | |
Rep 115,980
Mike |
gx5_027200.00 |
01-22-2018, 08:33 PM | #41 | ||||
Rep 158
AFAIK, the JB4 for the Fseries does not monitor timing corrections, but raw timing. How it works to increase boost is avg the ignition advance to where it "THINKS" timing is good. I say thinks, because the JB4 has no idea what the timing target is. Im not sure what the refresh rate is. Quote:
Ive run 100% meth before with no issues. But for customers i usually tell them to remain around an 80/20 mix of meth to water just for flammability. I would make a separate outlet for the meth pump if youre going to use the washer tank just to be safer. Quote:
I do believe in my quoted posts i stated tune the car with meth at full tilt so you know the limits. Then if by chance the DME see knock while meth is active it will reduce boost. If you're not running meth for whatever reason run a none meth flash, done. Not worried about running out of meth and etc. because why? the meth controller will dump boost if meth runs low or there is a pump or flow issue. DME does the rest. ALL IN REAL TIME, not over several pulls so the JB4 can figure out if the timing is good or not. |
FSociety3812.50 |
01-23-2018, 09:46 AM | #44 | |
Rep 115,980
That timing data is used in a variety of ways by the JB4 for auto tuning purposes, as part of the integrated water/meth safety (just because you're injecting fluid doesn't mean you're injecting enough to prevent knock), and any other internal algorithm that needs to take in to account engine knock and timing advance. Regarding methanol safety it's a complex issue. The DME runs long term timing and fuel adaptions and even if using meth on a "pump gas" map timing can be advanced by the DME, and when that octane and fueling is suddenly removed, quick knock occurs the DME is not always able to properly deal with, and pistons can be broken. This was a common issue with the N54 in 2008 using the JB3 system and non-integrated meth kits before BMS introduced CANbus and their WMI safety integration systems. Running WMI without a properly integrated safety system is just playing Russian roulette with your engine. Running less aggressive tuning can reduce the risks but who installs a WMI kit to run less aggressive tuning? Programming the flash tune to react to knock with load changes is too slow of a response to be effective in this regard. If you can run a flow sensor input in to the DME then that would be the best way to do it "flash only". I use quotes because you're still using a piggyback for the WMI and flow sensor control. Just not a JB4 piggyback. But like most features implemented "flash only" it becomes a compromise solution. Kinda does the same thing, but not really. Devil is always in the details. Mike |
