BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Idiots guide to coding EBT
      03-21-2014, 04:06 PM   #1
teaston
Drives: X3 M40d
Post
It appears that all Business Navigation cars built since at least September 2013 have the Combox in the boot, so EBT (Enhanced Bluetooth and USB) can be enabled with E-Sys. NBT Pro Media has the Combox built into the head unit so can also have EBT coded.
Edit 14/4/2015:
Also it now appears that March 2015 onwards built cars with Business Media now have the Combox built into the head unit, like NBT. These have also been successfully coded for EBT, see demig's post #368.
E-Sys, psdzdata files & install/coding guides can be obtained from shawnsheridan PM him a request, he is the coding master and a very helpful chap, also find him and lots of coding info in this thread: http://www.f30post.com/forums/showthread.php?t=696777
First follow the PDF guide that came with E-Sys 'E-Sys - Installation'
Then follow the PDF that also came with E-Sys 'How to change FA in F-series car' but with these changes/additions
1. At step 2. select F020 in top window and check bottom option 'connection via VIN.
2. On step 3 you need to press 'save' after pressing 'read' then save file as any name you want, then the 'edit' button will be enabled.
3. On step 6 change 6NH to 6NS
4. Once all steps are complete: go back to expert mode, Coding =>
right click FA and select activate FA =>
Click read SVT
Right Click on HU_CHAMP2 (HU_NBT for NBT Pro Media or HU_EntryNav for newer business media) (the ECU itself not the underlying CAFD) =>
Select CODE
Wait for 'Abarbeitung beendet' which means finished completed.
Right-Click on CMB_Media (step not required for NBT pro media or newer business media) (again the ECU itself not the underlying CAFD) =>
Select CODE
Again wait for Arbarbeitung beendet
6. Click disconnect, Done!
On the older systems to enable Bluetooth streaming:
In idrive go to 'telephone' => 'Bluetooth telephone/devices' => highlight your phone => press option or click right => go down and select 'configure Bluetooth' =>
tick all the options => go back => go up to your phone and select it => tick audio
now go to 'media' => 'external devices' => your phone will now be an option to play audio from! Either change track back or forward with idrive or control
from your phones screen.
Of course you will also now have Album art from USB stick and iphone through lightning cable, and also full control of music library from iphone in idrive using lightning cable.
Don't forget to appreciate this post if you found it helpful!
Appreciate 23
      03-21-2014, 04:11 PM   #2
nordberg
Drives: F31 330d M Sport
Good work! I need to finish building my cable and get coding myself if I ever find the time....
      03-21-2014, 04:13 PM   #3
Drives: xxxx
Nice guide, although I will likely be seeking out some one to do mine in summer.
      03-21-2014, 04:53 PM   #4
c.grex
Drives: F31 330D Luxury
Do you album art via bluetooth?
      03-21-2014, 04:58 PM   #5
nordberg
Affirmative.
      03-21-2014, 05:10 PM   #6
teaston
Drives: X3 M40d
Originally Posted by nordberg View Post
Affirmative.
Really? I don't!
Do you have full control of iphone music library over bluetooth? I just get current track title & forward and back a track.
Jonny354.00
      03-21-2014, 05:17 PM   #7
c.grex
That's why I asked. The demo car I had did the album art over BT. That was a factory EBT.
      03-21-2014, 05:18 PM   #8
teaston
Drives: X3 M40d
Which nav system did it have?
      03-21-2014, 05:18 PM   #9
c.grex
Affirmative.
Are you coded EBT or factory?
      03-21-2014, 05:18 PM   #10
c.grex
Professional! May be that's the difference.
      03-21-2014, 05:20 PM   #11
teaston
Drives: X3 M40d
I think so!
Doesn't matter too much as long as you can get sound from your phone, and from my ipad! Tried it earlier and it's awesome watching vids on ipad with sound coming from the HK!
      03-21-2014, 05:22 PM   #12
c.grex
Originally Posted by teaston View Post
I think so!
Sounds a good idea. I've ordered pro, so hopefully I'll get album artwork over BT
      03-21-2014, 05:23 PM   #13
Drives: xxxx
I think so!
Now that would be good.
Will it accept ipad playing music as well?
(I assume obviously it does).
      03-21-2014, 05:24 PM   #14
teaston
Drives: X3 M40d
Certainly does! Car becomes like a bluetooth speaker! And has a much bigger screen than the pro media!
      03-21-2014, 05:28 PM   #15
Drives: xxxx
Lol but it's a bitch to balance on the dash when driving
Well, I will definitely be getting mine coded.
Although by June, it will probably come with all options as standard lol.
J335D7.50
      03-21-2014, 05:41 PM   #16
teaston
Drives: X3 M40d
I have the snugg ipad cover, the front part hangs over the back of the steering wheel so the screen sits perfectly on the front of the steering wheel!
      03-21-2014, 05:49 PM   #17
Drives: xxxx
Otter box for me.
Means anyone tries stealing it, I can club them to death with it and my ipad will still work lol.
      03-21-2014, 05:51 PM   #18
teaston
Drives: X3 M40d
Otter box for me.
Should work with that case too by the looks of it!
      03-21-2014, 06:15 PM   #19
sms720
Drives: F30 335d
Great guide thanks a lot
Current: F30 335d xDrive MSport (EBII/Black Dakota)
      03-21-2014, 06:38 PM   #20
alex_chung
Scotland
Drives: 320d xDrive M Sport (Plus)
Sorry a bit late to this but does Pro Nav have EBT? I can plug my iPod in using the normal iPod cable and have the newer touchpad iDrive.
Alex
      03-21-2014, 06:44 PM   #21
teaston
Drives: X3 M40d
Alex
It only has EBT if you either added it as an option, or if you code it. Normal apple cable will work with pro nav regardless.
      03-21-2014, 06:46 PM   #22
alex_chung
Scotland
Ah I see...guess I will wait and see if the Scotland Coding Meet happens.
How is the car running?
Alex
