01-14-2021, 07:31 AM | #23 | |
Rep 15,858
I note on latest BMW models a lot have additional damping elements fitted to the front struts to reduce NVH, help eliminate steering vibrations. |
01-14-2021, 07:46 AM | #24 |
Rep 5,210
ACS/Bilstein B6 dampers in the first instance before anything else. I hated the roll in the 335d and switched to uprated acs springs and bilstein b8 but ride was harsh and roads were shit.
I couldn't live with it and changed the car. In retrospect after over 3k spent on the car I realised if it doesn't handle the way I want oem best to switch to a car that does. |
01-14-2021, 02:31 PM | #26 |
Rep 724
01-14-2021, 06:20 PM | #28 |
Rep 749
Drives: F31 320d xDrive M Sport
I'd go for an M135 rear anti roll bar. In fact I did!
It's not too expensive, direct swap, and shifts the handling slightly more rear wards too, making it more fun, without being unpredictable or oversteery. I'd say it makes the xDrive feel more like the RWD F31s. If you do the front ARB then it'll make the car more understeery which is not ideal, and worse than body roll IMO.
McBeemer261.00 |
01-15-2021, 12:08 PM | #30 | |
Rep 548
I think your explanation of the result is exactly what i am looking for.
Current: 2017 F31 335d M Sport - Estoril Blue, ACS Sports Suspension (Springs & Dampers), Black Grill, HK Sound & some other bits'n'pieces
Gone: 2015 F31 320d M Sport Xdrive Auto |
01-15-2021, 04:11 PM | #32 |
Rep 8,498
Only if you fit the entire subframes as well.
01-15-2021, 05:14 PM | #33 |
Barge driver
8656
Rep 12,425
Goes to show just how bespoke the M3 is to the normal 3 series
730d/Z4C
01-15-2021, 05:24 PM | #34 | |
Rep 8,498
It's one of the reasons that people inadvertently screw-up the geo when fitting F8X front arms.
