09-18-2020, 12:14 PM | #596 |
Rep 464
Already turned on but nothing showed up
Instagram:catpupu_f80 |
09-18-2020, 12:55 PM | #597 |
Rep 266
09-18-2020, 01:22 PM | #598 | |
Rep 464
09-18-2020, 01:26 PM | #599 |
Rep 766
These are the the options I changed - a couple where not available for my car but everything working
- [x] SLI (advances mode) Coding to be modified for KOMBI or DKMOBI ANZEIGE_NPI = aktiv KI_PIA_SPEED_LIMIT = aktiv SPEED_LIMIT = aktiv SPEED_LIMIT_GENERATION = sli_gen_2_npi RCOG_TRSG_APPL = aktiv RCOG_TRSG_TIMEOUT = aktiv - [x] Coding to be modified for HU_NBT or HU_NBT2 SPEEDLIMIT_INFO = aktiv SLI_NAVI_DISPLAY = nicht_aktiv |
yjypm219.00 |
09-18-2020, 01:30 PM | #600 | |
Rep 464
09-18-2020, 06:25 PM | #601 |
Schmollbraten
12512
Rep 1,985
No, you could turn the ignition on but that the engine has to run for coding too...I had never heard of it before.
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox |
yjypm219.00 |
09-19-2020, 03:24 PM | #602 |
Rep 464
I figured out where the problem is, most of the codings are under instrument cluster module rather than headunit -> kombi. Instrument cluster module somehow didn't show up on my BimmerCode until I started the engine. Now it's working! I couldn't be happier.
Update: Drove the car out, the speed limit display works perfectly. As soon as I passed a speed limit sign it changed the speed limit display (it doesn't read the sign, but it proves how good the navigation database is). On highway ramps it even shows a "no passing" or "pass with care" symbol on my HUD. Also I didn't encounter the problem of not showing 5s. 20, 30, 45, 65 all work like it should.
10-28-2020, 06:47 PM | #603 |
Rep 14
I got SLI emulator from bimmer8 also few days ago, tried to code it today but for some reason KOMBI does not remember any changes that I made and no icon is showing up in a cluster. Reading a forum I think I need to code 8TH option in order SLI to work, will try that tomorrow and post update.
10-28-2020, 07:14 PM | #604 | |
Rep 128
10-30-2020, 06:52 PM | #605 |
Rep 14
Got it to work, thank you. Once i did VO 8TH SLI icon showed up in a cluster and in HUD. When on the ramp additional info comes up next to posted speed limit like 'do not pass" and later "pass with care" . I drove couple miles and it works fine. The only thing is icon itself is different from original BMW, you can see it in the HUD picture, would be nice to highlight only number itself.
10-30-2020, 10:52 PM | #606 |
Great Teacher
1084
Rep 1,305
Drives: 06 e91 325ix
Nice. Wonder if I can get them to change mine out for one that does work for speed limits with 5s.
Edit. I just reordered another one since I had enough eBay bucks expiring in 2 days to cover the cost. Edit2. They asked if I don’t mind waiting a few day they’ll send me their newest version with a switch to change between mph and kph, plus between square and circle. So If you want the preset one at the lower $45 cost order it now...
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… Last edited by Onizukachan; 11-01-2020 at 01:32 PM.. |
11-01-2020, 03:00 PM | #608 |
Great Teacher
1084
Rep 1,305
See edit 2 above.
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
11-06-2020, 02:20 PM | #609 |
Great Teacher
1084
Rep 1,305
Received the new bimmer8 module with switches.
It does the 5mph limits fine. 2021-1 Next seems to have a few more streets with speed limits from what little I have seen driving the last couple of days.
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… Last edited by Onizukachan; 11-06-2020 at 06:21 PM.. |
raphaelpais6.00 |
01-13-2021, 06:48 AM | #610 |
Rep 26
Don't work China
Hello
I have F31 from 2013 with CIC I buy cheap emulator from China, other buyers wrote is working with CIC. But my not work. I'll coded everything and add to FA 8TH code. In instrument cluster I have only 3 dots , Anyone have working emulator in CIC, and can send a link to buy ?? |
01-13-2021, 06:50 AM | #611 |
Rep 26
01-18-2021, 12:37 AM | #612 |
Rep 7
Just ordered the Bimmer8 module. I've had the Chinese module for a couple of years now (2018 F33) and since I have the 6WB was pleased with it. Since the 6WB doesn't actually show MPH or KPH it worked fine. I have always really wanted the trailing red line showing when you're going over the speed limit though. Now that I see this Bimmer8 module does that, I jumped on it. Hopefully it won't take forever to get to me. Excited to test it out.
x-m4n148.00 Onizukachan1083.50 |
02-12-2021, 04:14 AM | #613 |
Rep 9
Hello good people, my first post on here so be gentle !! My problem is that I'm struggling to find an SLI emulator that displays mph. I got one from Ali express https://a.aliexpress.com/_mtsphQ5 which advertises both km/h and mph, but after installing it only shows km/h although the figure does represent the mph limit.
The only one I have found is the Bimmer8 one but due to Covid he is not posting to UK other than using a service that costs twice as much as the emulator itself. Any links to MPH displaying emulators would be appreciated, or if anyone has swapped one out and is prepared to post on I would be happy to pay the going rate. |
02-12-2021, 10:55 AM | #614 |
Great Teacher
1084
Rep 1,305
The Romanian one first mentioned or just wait till vivid is over.
03-31-2021, 10:38 AM | #615 |
Rep 766
There is a bimmer8 SLI module on sale if anybody interested:
https://f30.bimmerpost.com/forums/sh....php?t=1812059 I have this version on my car and works really really well (I use MPH here in the UK) |
04-06-2021, 01:37 PM | #616 |
Rep 150
Thank You for confirming this, went though all 26 pages in advance of this looking for confirmation lol. Can you post the link one the one you bought?
