01-15-2021, 08:20 AM | #111 |
No 55mph
1621
Rep 8,476
Were these all PnP for the F3x series?
01-16-2021, 07:55 AM | #112 |
Rep 611
Absolutely, exactly the same dimensions, mounting and connectors for both mids and tweeters. Just be aware the B&W tweeters have shorter cables - no problem for dash, no problem for front doors (just need shorter cable path), little bit tricky for the rear doors, as the tweeters are clipped in the doorboards. No big deal, just remember that for the future, as it requires very careful operation in case you need to remove the doorboards later. Not for this reason, but I suggest to make a proper door soundproofing (and damping of the rattling door pins) with installation of the speakers. A significant improvement both for the sound quality and the sound isolation of the entire car.
01-16-2021, 11:02 AM | #113 |
Rep 1,565
Yeah I don’t recommend this mod with HK. As an audiophile for over 30yrs it quickly reveals that the standard BO setting is basically Logik 7 Surround turned off and expanded is turned On in comparison.
Next you will notice a big drop off in bass and high end with either which requires a great deal of tweaking to get a better sound IMO. I went back to HK setting menus and right back to my regular tweaks. Clearly the only path to better sound is new drivers and amp with this setup. The BO is clearly designed for that system whatever this setting does. Without equipment do t know exactly to monitor it, but the quick listen and tweaks I tried just weren’t cutting it for me. Cool for some maybe, try go yourself. |
01-16-2021, 05:09 PM | #114 |
Rep 611
01-16-2021, 11:03 PM | #115 | |
Rep 67
When used B&O DSP on HK you can hear that the front center has more volume comparing to HK DSP profile, it is something that you immediately pay attention. So there is some difference. |
J555568.50 |
01-17-2021, 06:21 AM | #116 | |
Rep 54
View post on imgur.com |
01-17-2021, 08:15 AM | #117 |
Rep 16,079
European base audio has no separate amp, it's contained in the HU. The under seat woofers are 6.5 inch. There's no point in having 8 inch as the meager HU amplification is too weak to justify them.
01-17-2021, 02:18 PM | #118 | |
Rep 54
Will i notice any diference? |
01-17-2021, 04:04 PM | #119 |
Rep 16,079
There's no point in changing any of the speakers as the HU doesn't have enough power to drive them. Adding tweeters wouldn't hurt. How to do that is shown in this thread. https://f30.bimmerpost.com/forums/sh....php?t=1475424
01-23-2021, 02:59 PM | #120 |
Rep 785
does the stock hk logic7 profile have the 7 band equalizer?
does the stock hk logic7 profile have the 7 band equalizer in idrive?
I've been running the b&o profile on my car for so long I forgot... That's my favorite feature of the b&o profile and I believe it goes away if I revert back to logic7. Can anyone confirm or deny? Thanks
335i rwd auto, 2015 with m performance LSD and Dinan stage 2. Cts charge pipe, mad 5" stepped intercooler.
01-24-2021, 10:06 AM | #122 |
Rep 785
Many thanks!
06-04-2021, 05:54 PM | #123 | |
Rep 22
N26Ghost496.50 |
12-30-2021, 05:02 PM | #124 |
Rep 141
Drives: 2019 440i | 2020 X3 X30i
I changed to B&O on my F36 and it definitely improved but something wasn't quite right, I did not like the sound at higher volumes..
Just did B&W and the sound is greatly improved over the other two, i'm honestly surprised how much better it sounds with just coding. I had to temporarily replace my center mid with a spare alpha one speaker I have because the stock HK dash speaker started to blow itself up shortly after B&O. I'm planning on replacing all the speakers and tweeters with B&W, I was searching to see if there's any way to get that ambient lighting at least on the tweeters and i've seen some china kits, has anyone ever installed these and can chime in how they hook up to the regular ambient lighting?
2019 F36 440xi B58 | 2011 E90 328xi N51 | 2010 E92 335xi N54 (sold) | 2015 F32 435xi N55 (sold) | 2020 G01 X3 30i B46 | 1996 E36 328iS M52 (RIP)
02-11-2022, 10:33 PM | #125 |
Rep 237
Drives: 340i xDrive Stage 1
Thank you so much man, I just did this to mine. It sounds better, I even got my friend to sit in it and they confirmed that I'm not imagining things, pretty damn noticeable improvement. And here is the EQ I used with it, very balanced for most genre of music. I'm finally satisfied with my H&K system. Was considering bavsound pro amp for $1800, nah, this is good enough.
Bass +4 Treble +1 100hz +4 200hz -2 500hz -4 1khz +5 2khz -3 5khz +3 10khz -1 |
sashankc7.00 |
04-26-2023, 11:01 PM | #126 |
Rep 149
Just switched from HK L7 to the B&O system. So far it sounds really good. Im still experimenting but what I can for sure say is that I seem to have the volume nob higher to max than before.
Both speakers are really loud at the halfway mark, but I think HK is louder if both volumes are meant in the middle. This doesn't mean it sounds better though. I think the HK base is a bit deeper, but overall I think the audio is clearer and better quality from the B&O coding. In a few days, I'll have my mind set to which one I should keep. |
