BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > B58 Log Review Thread
      02-03-2020, 02:37 PM   #331
kern417
Cheapskate
4445
Drives: 2018 440i |2016 340i | 2010 X5
Originally Posted by Sµpreme View Post
Actually had new NGK 94201 plugs installed right before I did the pump and tune. Had them gapped to 0.022 by 'my guy', friend of mine that is a professional mechanic and does all the work on the car. (Except for the pump, I installed that all by myself! )
I don't think I'd want to go narrower than that, do you?
I'm just looking at F80 guys that run 0.018-0.020 on E85 tunes. Not a guarantee and like I said your timing doesn't look bad, just showing corrections for some reason.
Youtube/Instagram/TikTok: @kern417
      02-03-2020, 03:31 PM   #332
janea1207
Drives: BMW 340i
b58
Yesterday tried to run on 102ron map with 100ron fuel+octane booster. It was a little bit slower than on 98ron map. Can you see the my logs on 102ron and 98ron.
102ron map log: https://datazap.me/u/janea1207/bmw-3...&data=5-24
98ron map log:
https://datazap.me/u/janea1207/340is...&data=5-24
      02-03-2020, 05:04 PM   #333
OzBMR
OzBMR's Avatar
Australia
575
Drives: BMW M140i
Some new logs running the Wedge Rev 2 E50 map. Boost seems nice and consistent, close to target. Any concerns with these cylinder timing corrections?
https://datazap.me/u/tnilson/4th-gea...og=0&data=4-18
https://datazap.me/u/tnilson/3rd-gea...og=0&data=4-18
https://datazap.me/u/tnilson/bonus-0...og=0&data=4-18
Looks great, must feel nice.
Here's a Virtual Dyno of your 4th gear runs
Tesla Model 3 Performance 0 - 60mph 3.1s
M140i LCI Mineral Grey
Dorch Stage 2 HPFP, CG Precision DS-1, XHP, MHD Stage 2 HPFP E30 @ E42 100 - 200 6.96s
Quarter mile 10.93@127mph
Supr3me551.00
      02-03-2020, 05:13 PM   #334
OzBMR
OzBMR's Avatar
Australia
575
Drives: BMW M140i
102ron map log: https://datazap.me/u/janea1207/bmw-3...og=0&data=5-24
98ron map log:
https://datazap.me/u/janea1207/340is...og=0&data=5-24
The 98RON map is a nice 4th gear pull with 100% accelerator from 2300 RPM.
The 102 RON run is a 2nd to 3rd gear log that is not useful as you seemed to have a lot of wheel spin and DSC intervention.
Go and do a 4th gear run for the 102RON map like the 98RON map and post it up, then we can see the real difference.
kern4174445.00
      02-03-2020, 05:27 PM   #335
Supr3me
Supr3me's Avatar
Drives: Your mom crazy
Real nahice. Feels smooth and strong.
I'm AWD, did you set up this virtual dyno with that factor, or RWD?
2020 X3M
MG Flasher; Wedge Performance E50 tune
MSS Urban; Rohana RFX11
      02-03-2020, 05:40 PM   #336
OzBMR
OzBMR's Avatar
Australia
575
Drives: BMW M140i
Used a 340i X drive profile, same gearing, just a bit more weight, 70 additional pounds, car weight of 3710 lbs then used a nominal 176 lbs for driver weight.
Looks like you've got about 460 whp and should be good for about 11.6@121mph
Supr3me551.00
      02-03-2020, 06:01 PM   #337
boosted
enthusiast
boosted's Avatar
Drives: 2018 340i x-drive 8AT
Latest log. Thoughts?
Click here
2018 340i x-drive 8AT - MP (Mission Performance) stg 3 DME tune, Xhp stg 3 EGS tune, catted AA downpipe, NGK plugs, E30 blend - 11.4@120mph.
      02-03-2020, 06:59 PM   #338
OzBMR
OzBMR's Avatar
Australia
575
Drives: BMW M140i
Click here
Looks like a strong 93 octane tune 19 - 20 PSI and AFR's on the lean side. How much ethanol are you running?
      02-03-2020, 07:20 PM   #339
baldeagleman
Drives: 2018 M4 6MT
https://datazap.me/u/dparadis21/test-1?log=1&data=4-16
https://datazap.me/u/dparadis21/test...og=0&data=4-16
MHD Stage 2, 93 Octane. No clue really how to log just did some quick pulls after I did the flash. Any insight would be appreciated.
      02-03-2020, 07:41 PM   #340
boosted
enthusiast
boosted's Avatar
Thanks!
2 gal E85 (not sure winter ratio), 8 gal of 93 Shell.
      02-03-2020, 07:42 PM   #341
OzBMR
OzBMR's Avatar
Australia
575
Drives: BMW M140i
The bits you've captured aren't great for reviewing, but everything looks OK. Getting some good timing, up to 15 degrees on that fuel.
You really need to have the car in Sport+ manual and at least 3rd gear, ideally 4th gear, steady at about 2300 RPM then go 100% accelerator through to about 6800 RPM.
      02-03-2020, 08:02 PM   #342
baldeagleman
Drives: 2018 M4 6MT
Ok, cool, I will try to out tomorrow when I get a chance. Thanks.
      02-03-2020, 08:59 PM   #343
Supr3me
Supr3me's Avatar
Cheers mate, I appreciate the data!
2020 X3M
      02-03-2020, 09:53 PM   #344
baldeagleman
Drives: 2018 M4 6MT
Just did another run right now. 4th gear.
https://datazap.me/u/dparadis21/mhd-...og=0&data=4-16
Will this work better? Also, how did you make those virtual dyno runs. I downloaded the program and It just gives me really weird results.
      02-03-2020, 10:50 PM   #345
OzBMR
OzBMR's Avatar
Australia
575
Drives: BMW M140i
That's a better log to look at. When did you flash the tune and how many miles since flashing it?
The car is having some persistent timing corrections throughout the run, indicating not enough octane for the boost and timing in the map. Timing Delta for knock should be at 0 and by the end of the run is at -1, indicating some knock is occurring.
Can you get better fuel? What are you using?
The other unusual thing I noticed was your fuel rail pressure dropping quite a bit below target from 2400 RPM through to about 5500 RPM. Should stay at 2900 PSI on that map unless you're blending some ethanol, but then your timing should be a lot better.
The car got to 16 PSI at 2400 RPM, which is really early.
The Virtual Dyno should look like this if you save the data file correctly.
      02-03-2020, 10:55 PM   #346
baldeagleman
Drives: 2018 M4 6MT
I am using Citgo 93 octane (I think contains 10% ethanol). I have had a drivetrain malfunction error a couple times in the last two months when I was running JB4 + MHD BEF. Today I swapped to just MHD stage 2 for 93oct/98 RON so I literally did this flash a few hours ago. I haven't ever done anything to my sparkplugs and I wonder if they were the culprit in the drivetrain malfunction.
Side note, the MHD stage 2 flash seems way faster than my JB4/MHD BEF setup. I reckon I mustve messed up somewhere along the process of setting that up. Is there anything else I should look at to fix these logs?
      02-03-2020, 10:57 PM   #347
OzBMR
OzBMR's Avatar
Australia
575
Drives: BMW M140i
The CSV file data must look like this. I have custom heading for boost "PSI"
      02-03-2020, 11:08 PM   #348
OzBMR
OzBMR's Avatar
Australia
575
Drives: BMW M140i
If you've only just flashed the car it may be just an adaptions issue. You can try resetting adaptions in the MHD Flasher>Codes>Reset Adaptions with the ignition on, car not started, same as when you flash the car. Alternatively, disconnect the battery for a while.
Do you have access to 93 that doesn't have ethanol?
93 octane that has 10% ethanol starts as poor quality gas that they add ethanol to to get the octane up. If you can, blend some high quality 93 with some E85 once the gas in your tank is gone, then re-test.
      02-03-2020, 11:13 PM   #349
baldeagleman
Drives: 2018 M4 6MT
The CSV file data has look like this. I have custom heading for boost "PSI"
View post on imgur.com
This is what I'm getting now. Wasn't able to get the AFR in the spreadsheet, not sure if that will make the difference. I am getting between 418-441 depending on if I put my tires as 225/40/18 or 245/40/18 so this one is 235/40/18 (I run staggered 225s and 245s so I put the average?).
Would running the car like this have any potential for damage? I had my JB4/MHD BEF for like 6 months and I never did any type of logging until now. I'm kind of worried since the car seems to have way more power and is way more responsive with just the MHD stage 2 and you're saying I'm getting rail pressure drops and some knock which makes me think the JB4/MHD BEF might have had more serious issues. I probably drove 3k-5k miles on the JB4/MHD BEF combo.
      02-03-2020, 11:57 PM   #350
OzBMR
OzBMR's Avatar
Australia
575
Drives: BMW M140i
The rail pressure drop and bit of knock is probably because of the fuel you're using. The car is doing a good job of managing itself, don't worry, just get better fuel when you can.
In car editor, change the drag co-efficient to 0.34, this is what is in the specifications for the car.
Add driver/passenger weight(s) as this will influence the output.
Tire height should be as per the rear tires 24.08 inches, this works with the gear ratios.
In Virtual Dyno>File>Options go to the columns and profiles tab and make sure it looks like this and you'll get your AFR and Boost as well
      02-04-2020, 12:01 AM   #351
alyabiev
Drives: BMW M3 Competition Touring
With that deep drop in fuel pressure you can just lean out anytime when requested injection amount should go up. Leaning out would lead to immediate knock events occuring and cracking piston ringlands. (that's the worst scenario)
Kirill @ OdinTuned
      02-04-2020, 12:20 AM   #352
baldeagleman
Drives: 2018 M4 6MT
Wow thanks for all the help guys. What should I do to "get better gas"? Is CITGO not high quality? I also have a sunoco near me if that is considered better. Do you think I should replace the spark plugs? Couldn't that be part of the cause of the knocking? I dont think they've been replaced for awhile.
