12-11-2020, 12:27 PM | #1 |
Rep 4
Memory/electric/heated seats retrofit Guide (I need your help)
BMW F30 320ed 03.2013
From the factory I have leather manual adjustment/heated seats I decided to retrofit: -leather memory/electric/heated driver seat (SM production year 06.2012) -leather electric/heated passenger seat (no SM) Wiring I did: Driver side wiring PIN 1 (X14*1b) -> Z7(front fuse box) Fuse 27 PIN 5 (X14*1b) -> K-CAN L FEM A173*8B PIN51 PIN 6 (X14*1b) -> K-CAN H FEM A173*8B PIN52 PIN 15 (X14*1b) -> Z7(front fuse box) Fuse F65 PIN 16 (X14*1b) -> Z10*3B Passenger side wiring PIN 1 (X12*1b) -> Z7(front fuse box) Fuse 27 PIN 8 LIN Bus -> REM A174*14b PIN18 PIN15 (X12*1b) -> Z7(front fuse box) Fuse 64 PIN 16 (X12*1b) -> Z10*5B PIN25 (X12*1b) -> Z7(front fuse box) Fuse 64 PIN26 (X12*1b) -> Z10*5B CODING Added 459 to VO VO code FEM, HU, REM, IHKA, SM Inject CAFD to SM RESULT Driver side memory working, adjustment working, heating working Passenger side adjustment working, HEATING NOT WORKING ISTA-D errors REM (E58C47) Seat heating passenger side (LIN): missing LIN slave FEM (D90D06) Operating unit switching center door (SCT) (LIN): wrong version installed FEM (D90D0A) Wing mirror on the left (LIN): missing LIN slave FEM (D90D0D) Outside mirror right (LIN): missing LIN slave PS BTW mirrors are working perfectly, control buttons on the driver door working perfectly Still trying to figure out the root of the problem and how to fix it all If you have any suggestions or another help is WELCOMED |
12-11-2020, 04:05 PM | #2 |
Rep 817
Drives: bmw M3 F80
Hello
Add a mass (negative) you need 2 negative as in the photo on the socket A244 * 1b (pin 1 et 8) I'm talking about the small passenger module |
12-12-2020, 05:54 AM | #3 |
Rep 4
So I've checked this two wires, and they are placed and connected from the factory
I also made some photos of both modules, one big on the driver's side and one small on the passenger side Unfortunately the problem is still te same( |
01-06-2021, 06:12 AM | #4 |
Rep 5
Sorry to jump in but I’m going to be attempting this also in a week or so.
So I’m collecting as much info as poss before I start. Mutuax:What are you using to do the coding? Still getting an understanding of the abbreviations (🤯 some are not listed on the site. Vo,vem, cafd and hu? David seems to be the guru of retro fits 👌🏻 |
01-20-2021, 04:39 AM | #5 | |
Rep 8
I have a 2014 F30 with factory Front seat heating Im getting the E58C47 seat heating Missing Lin Slave fault code,and the seat heating isnt working, I you found out how to fix it please let me know |
altezza0.00 |
12-29-2021, 08:44 AM | #6 |
Rep 22
I just completed this retrofit successfully and got a driver missing LIN error to begin with. It seems there are two flavours of this error:
1) if the missing LIN is on the passenger side i.e. without the big white seat module (which itself is only on the driver side for F30), your car probably didn't have heated seats to begin with and you probably had to add wiring to passenger side. Therefore there is likely a power/ground/LIN signal wiring issue preventing the small black passenger module from being recognised - tl;dr: check wiring. 2) The error I got was not the above; it was for the driver side, which since retrofitting the memory seats is no longer controlled by the LIN bus, but KCAN2. If you're getting this error you probably started out with manual heated seats. This was solved by VO coding in my case: I figured the old LIN control at the REM wasn't being overwritten when I VO-coded 459 (electric/memory) only. Therefore, after VO-coding 459 to all relevant ECUs, I uncoded 494 (heated seats) from REM and coded it back again. And no more error! tl;dr: VO code 459 to all ECUs, uncode 494 from REM and code it back, Hope this helps all of you - this seems to be an issue that's not been widely solved on various forums, and indeed was the cause of much anxiety for me. But the fix was simple (for me at least) |
07-09-2022, 03:25 AM | #7 | |
Rep 211
After doing this coding the passenger seat still does not work, I have done these 2 FDL coding. Everything works perfect. REM/ HW_OPTION BODY LIN SH/ Aktiv REM/ SEAT HEATING_LOW_FRONT/ LIN BF |
