12-23-2020, 11:59 PM | #1 | |
Rep 3,539
KermaTDI Stage 2 Dyno
I was fortunate enough to get some dyno time today and got some really good data on my 328d with KermaTDI Stage 2 tune!
Max dyno was 224whp/356wtq on a Mustang AWD dyno. When the car was stock, I dyno'd it on another Mustang AWD dyno and got 143whp/217wtq, so that's an increase of 81whp/139wtq. Plots and video below: KermaTDI Stage 2 Dyno Stock Dyno Dyno Video Quote:
haagm58809.50 swissarmyknife29.50 shiftdnb376.50 bigshooter52.00 triax37130.00 MustGoFaster1.50 AmuroRay2267.50 Jim E.91.50 Onizukachan1086.00 RobE300.00 AndrewC198910931.00 |
12-24-2020, 01:24 AM | #2 |
Rep 906
Awesome post!
I was actually eyeing this tune for my car and wondered what some real world numbers would be like. Looks like you answered my question. That said, I got the BMW extended warranty, so I figure a tune might not be a good idea?
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World |
haagm58809.50 |
12-24-2020, 09:27 AM | #3 |
Rep 919
Drives: F30 328d Sport Line
Incredible results, FaRKle!! Thank you for posting this, it definitely cements my decision.
12-24-2020, 11:22 PM | #6 |
Rep 3,539
What on the drivetrain are you worried about? The 328d shares a lot of drivetrain components with vehicles that have higher power outputs. For example the transfer case is also used on the 340ix and 335dx, front diff is used on the new G30 M550dx, rear diff is the same as 340ix, ect.
12-25-2020, 04:47 PM | #7 |
Rep 79
FaRKle! - Thanks for posting these Dyno results. Seems like the stage 2 results have proved to be a great gain against stock. Tempting me to jump from Stage 1 > Stage 2 just to see how the differences feel.
01-06-2021, 07:27 PM | #9 | |
Rep 3,539
From what I've seen I think DUDMD's tunes are similar to JR's. Based upon how they advertise, and comments from those that have those tunes, the methods they use are benefitted by deleting emissions systems, and thus appear less refined than KermaTDI's to me. In some other tuner cases, they also modify BMW stock safety limits either by spoofing a reading to never go above a certain level (even if it is), or applying the tune map to things like the limp mode map.
haagm58809.50 Collins_F314.50 |
03-14-2021, 09:32 AM | #10 |
Rep 40
I'm looking at going from stock to Stage two with the KermaTDI on my 328d. I noticed they send you a loaner computer? From stage one to stage two did you change anything with the tune or just the power increase?
03-14-2021, 03:37 PM | #11 | |
Rep 40
Also just got the CV joint recall which is so funny because I had my mechanic in Morgan Hill perform the Loctite hack that was posted by another member here from the spline wearing out, possibly from the inferior CV design. So curious if BMW Monterey is going to give me a hard time about it. But once this is out of the way I am all for Stage 2 fun ;-) BTW, I checked your video on youtube and in the prephase you mentioned that others had the opinion that in RWD it might help with fuel economy. Can you tell me how you can switch off the Xdrive on our Wagon's since my impression was it's always on? Is there an add-on that can disable FWD via the transfer case?
2014 328xd Sport Wagon, Kerma Stage 1 tune, xHP with shift point adaptation, 45MPG
2003 Jetta TDI Wagon, EGR delete, 43MPG no -> went to my daugher 2002 Tacoma TRD overland build 2014 Ram 1500 EcoDiesel, tuned, 24MPG Last edited by swissarmyknife; 03-14-2021 at 03:55 PM.. |
03-16-2021, 11:02 PM | #12 | ||
Rep 3,539
BTW the fuel economy change with RWD was absolutely none. Comparing my fill ups between RWD and AWD the averages were surprisingly the same to the 2nd decimal point. Since COVID changed my driving habits I only included data points post that, which was n=7 for AWD and n=14 for RWD.
haagm58809.50 |
03-19-2021, 08:08 AM | #13 | |
Rep 40
So I see this is an app (andoid in my case). Can the full version of bimmercode achieve this as well? I have that already as I am making headlight mods with LED's so bought the full version to code out all the errors. Since our car is not compatible for the sport and winter mode anyway it would be nice if I didn't need to spend more on another app and just code it out if that even exists. Some other posts suggests in expert mode there is option 'all-rad deaktivieren' though in that thread nobody was brave enough to try - don't blame them.
2003 Jetta TDI Wagon, EGR delete, 43MPG no -> went to my daugher 2002 Tacoma TRD overland build 2014 Ram 1500 EcoDiesel, tuned, 24MPG Last edited by swissarmyknife; 03-19-2021 at 08:28 AM.. |
03-19-2021, 10:20 AM | #14 | |
Rep 3,539
swissarmyknife29.50 |
03-20-2021, 03:40 PM | #15 | ||||
Rep 40
The KermaTDI website claims 80whp and +140wtq for stage two.. that's almost double the power increase from stage 1.. is this just because of the transmission tune ? |
03-20-2021, 08:15 PM | #16 |
Rep 1,800
Correct, the transmission tune and the engine tune go together as one set for their stage 2
03-22-2021, 08:58 AM | #17 |
Rep 40
Also, just a heads up. If you already have the stage 1 tune the guys at Kerma will let you upgrade to stage 2 at a differential cost, meaning not the full stage 2 price is charged. Just give them a call and they can look up your original order and work out the other details since they need to ship you a computer to do the transmission tune anyway.
I need to get my recall taken care off then I will upgrade to this tune as well.
2003 Jetta TDI Wagon, EGR delete, 43MPG no -> went to my daugher 2002 Tacoma TRD overland build 2014 Ram 1500 EcoDiesel, tuned, 24MPG |
haagm58809.50 Onizukachan1086.00 |
04-05-2021, 10:37 PM | #18 |
Rep 40
The data I am about to show here isn't completely verified but was a direct attempt to see how tuning the shift points can affect when the optimal gear changes occur after an engine tune from the change in torque characteristic.
Basically knowing the ZF 8HP gear ratios and the final drive ratio we can make some calculations using a dyno chart with stock and tuned values. Where my math is not going to be 100% is that I had to use intersect values and approximations from the graph in the thread and then interpolate more refined values to be able to apply the math. The outcome is such that with the tune the shift points move down (-100 RPM in most cases) ever so slightly to carry on a little extra torque from one shift to the next. This first graph is using the stock dyno numbers and show speed and torque tables below. Where torque numbers intersect at the highest point is the optimal shift point to the next gear with the least amount of torque loss. The first column is the RPM, then the next 8 are each gear speed, then the second 8 are the correlating calculated wheel torque numbers (remember this is engine torque multiplied by the transmission gear ratios and the final drive ratio). The second graph is based on the higher torque, in this example from the Kerma tune at the top of this thread. The idea behind this would be that if you got a Stage 1 tune from a tuner and then dyno'ed your car and got the calculated engine torque you could calculate backwards and determine if xHP could be used to refine shift points for better acceleration. This is all just theory and I am sure there are some holes in my theory but it was fun carrying through the math and see an actual change.
2003 Jetta TDI Wagon, EGR delete, 43MPG no -> went to my daugher 2002 Tacoma TRD overland build 2014 Ram 1500 EcoDiesel, tuned, 24MPG Last edited by swissarmyknife; 04-05-2021 at 10:43 PM.. |
07-04-2021, 11:19 PM | #19 | |
Rep 420
07-18-2021, 05:42 PM | #20 | |
Great Teacher
1086
Rep 1,305
Drives: 06 e91 325ix
I drive in Manual mode and in town 98% of the time, except when on long highway vacation trips, so unsure if tinkering with the trans tuning is worth it.
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
07-18-2021, 08:23 PM | #21 |
Rep 4,551
Drives: 2015 328d xDrive
FaRKle! Any supporting engine mods other than the tune? Are you running the stock charge pipe?
NYC Bimmer259.50 |
07-18-2021, 08:30 PM | #22 |
Rep 4,551
Onizukachan1086.00 NYC Bimmer259.50 |
