01-12-2021, 09:16 AM | #1 |
Rep 101
F31 335d x drive - improve body roll
Hi Guys,
I've got a f31 335d with adaptive suspension and ACS springs. Handles great and body roll is much improved. Is there anything I can do to improve body roll and make the car sit more flat around the bends. Much appreciated Thanks |
01-12-2021, 09:59 AM | #2 |
Rep 815
Probably Birds anti-roll bars, albeit without ditching the run flats you might find a bit of a ride penalty. Another favourite on the forum seems to be fitting a stiffer rear ARB from the M135i/M140.
01-12-2021, 11:10 AM | #3 |
Rep 724
Yep, a rear arb makes the rear spot on with much much less roll, problem is though you still get roll from the front end, which is far more annoying, I'd love to know how to cure it, but not sure what to do !
01-12-2021, 12:01 PM | #4 | |
Rep 8,493
My recommendation, based on experience, is to fit Eibach ARBs front & rear. Stiffer than OEM but still retaining some compliance.
01-12-2021, 12:44 PM | #6 |
Rep 128
In terms of front stiffness are there options for strut brace bars? I'd be interested for my 440i
440i GC - Previous cars, I30n Performance, MKV GTi, E46 325i Touring, E46 320d Touring, E91 M Sport Plus Edition,
01-12-2021, 01:05 PM | #7 |
Rep 944
There's some about, but it won't do anything for body roll (the reason for this thread) and given the inherent chassis stiffness of the F36 it won't be anywhere near as obvious an improvement as it was on cars of 20 years ago.
For instanceWatseys comment on a strut brace Last edited by Techno 9000; 01-12-2021 at 01:15 PM.. |
01-12-2021, 01:33 PM | #8 | |
Rep 724
01-12-2021, 01:54 PM | #9 |
Rep 944
I'd be surprised that Watsey (with the springs/dampers he's running likely to be placing greater loads into the chassis and doing track days etc) would not notice an improvement - if one was to be had.
People running standard springs/dampers are putting lower loads into the chassis so, in my logic, would be even less likely to notice an improved chassis stiffness. |
01-12-2021, 02:43 PM | #10 |
Rep 724
Well, not in my logic, he may have a better feel for his car than many on here and most definitely better than myself and can feel very small movements. But surely when a car is lowered and stiffer than standard, you will feel less movement than a car that is higher and and has a much softer suspension, the softer car has more travel therefore it is likely to move more. The guy from Kies motorsport on YouTube thought the strut was one of the best mods he'd done to his car. So obviously different people have their own opinions.
01-12-2021, 02:56 PM | #11 | |
Rep 15,858
The softer 'more yielding' components will contribute much more to roll. Body with a defined 'stiffness' will be the last to give. Body will move more (torsional) as higher loads are applied, with stiffer suspension setups. |
01-12-2021, 03:03 PM | #12 |
Rep 2,048
My experience of every car I've ever played with is that on the roads ARB's make the biggest difference on softer suspension; as you get progressively stiffer so the relative effect of the bar drops. Obviously on track they can still have a dramatic effect as the loads can be higher, generally without such sudden surface changes as you get on a public road. Granted none of this is experience on the F30 chassis but a car is ultimately a car and the rules are generally the same even if the tools you use to achieve the solution of those rules might be slightly different.
01-12-2021, 03:52 PM | #13 | |
Rep 8,493
I've had the front strut brace connected/disconnected when trying to find the cause of persistent knocking on the car, and there's very little difference either way. It was a cheap mod but it also makes very little difference. I can only feel the difference because I've had the car as my DD for 8 years, but it's imperceptible even with a much stiffer sprung and damped suspension setup than OEM. As for roll resistance, it won't make any difference at all.
01-12-2021, 03:56 PM | #14 | |
Rep 8,493
Connecting the turrets on these cars does increase the steering precision a smidge, but you'll only feel the benefit if you also replace the hydro bushes in the radius arms. The OEM bushes are very soft and they rob steering precision and feel.
01-12-2021, 04:09 PM | #15 | |
Rep 724
01-12-2021, 04:54 PM | #16 | ||
Rep 8,493
SuperPro do a poly bush SPF4306K for that location and it has lasted OK on my car. I've had several problems with SuperPro components, so I certainly wouldn't attest to its reliability or customer service. Millway Motorsports have a sealed monoball press-fit bush for the same location (https://www.millway.se/front-control...0-x-drive.html) which should provide very good steering precision.
APJ245.00 |
01-12-2021, 05:20 PM | #17 | |
Rep 15,858
Stiffer ARBs are a compromise, like all suspension tuning. You may gain in one area or function, lose in another. Single wheel bumps are one of our biggest problems in the UK, where our road edges are typically irregular. We can lose comfort and induce cross axle oscillations, and unpleasant 'roll-rock'. |
Ennoch2257.00 |
01-12-2021, 05:20 PM | #18 |
Rep 7,032
Drives: 335xd Msport +
From experience trying to reduce the body roll , biggest change was to replace the standard adaptive dampers with Bilstein B6 damptronics.
Not for everyone and probably not the most focused option but work for me. Already done the ACS springs , rear ARB upgrade and added the rear underbody brace of a F31 not to mention the front strut brace.
01-12-2021, 06:20 PM | #19 | |
Rep 2,048
In contrast, the single biggest improvement in handling to any car I've owned with ARB tweaks was when the front drop link snapped on my '02 CRV. Turn in was massively improved, at the expense of roll, but well worth the downside of scraping door mirrors on the tarmac - the thing could be pushed so much harder. In fact it snapped 1 week after an MOT and the only thing that made me replace the link was the following year's MOT! ARBs can definitely improve roll control but so can digressive or adjustable low speed compression valving and spring changes. I've never been too bothered by roll and tend to focus on balance and handling - the cars of mine which have handled best on the public road are invariably not the ones with the flattest cornering but the best control of the wheel travel, as well as actually having a decent amount of travel (hence returning to struts and playing with the rake on the Impreza). Given I've got a warranty with the F31 and already have modified cars to play with I've not even looked at what options there are for this car other than to know that the ACS springs are allegedly warranty safe. |
Techno 9000518.00 |
01-13-2021, 05:51 AM | #20 | |
Rep 548
Last mod I am considering too is the Alpina gearbox map
Current: 2017 F31 335d M Sport - Estoril Blue, ACS Sports Suspension (Springs & Dampers), Black Grill, HK Sound & some other bits'n'pieces
Gone: 2015 F31 320d M Sport Xdrive Auto |
01-13-2021, 06:53 AM | #21 | ||
Rep 128
So reading through this thread it seems to be that the rear ARB upgrade is the best bang for buck? And bracing the front could help but less impactful? Sharpening the steering response would be great so which bushings & other mods would aid this?
01-14-2021, 06:37 AM | #22 |
Rep 724
Looks like the Bushing for the radius arm to chassis kit is out for any of those with an Xdrive, not sure whether OP is rear wheel or all wheel drive.
Watsey had kindly supplied the code of SPF4306K for the bushing kit, so i looked it up, and noticed it was recommended for rear wheel drive only, so last night i contacted Super pro who replied back this morning with this - 'Thank you for your email, unfortunately the T4306K does not fit the X-Drive platform BMW’s. The original BMW bush is a hydro bush which is designed to adsorb vibration, one of the things SuperPro take into account when designing a bush is can they ensure NVH is not going to be increased if this is the case then they will advised best to stick with OEM bush. Other PU manufactures may make bushes for the X-Drive because they do not worry to much about increased Noise, Harshness and Vibration.' Just thought I'd mention it on here, as i imagine there's possibly a few on here who are interested in this bushing kit, i certainly was !, but its only suitable for the rear wheel drive cars and not the Xdrives. (I did email him back about the T4306K, and he apologised and said it was a typo, it is SPF4306K) Last edited by APJ; 01-14-2021 at 07:15 AM.. |
