BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > UK - Off Topic > Why does this radiator need bleeding regularly?
      01-13-2021, 03:31 PM   #1
Gillespie
Drives: Vauxhall Grandland X
It’s a relatively new system circa 4 years old, it was fitted when we did our extension and the end guest bedroom needs bleeding regularly, there’s no leaks or anything and it’s only this one, seems bizarre, any ideas?
      01-13-2021, 03:32 PM   #2
Sennen
Sennen's Avatar
1731
Drives: UP, Alpine & Caterham
I bet its bleeding annoying.
      01-13-2021, 03:35 PM   #3
robbiep
Drives: VW e-Golf !
If it's at the end of the run, or at the highest point on the system, then that is where all the air in the system will end up.
Basic physics really
      01-13-2021, 03:37 PM   #4
Tengocity
Tengocity's Avatar
Scotland
8566
"I don't have time to bleed"
One of the best lines from one of the best movies of all time!
bishbosh838.00
      01-13-2021, 04:08 PM   #5
Gillespie
It is the end one but I’ve never had this problem before, I’ll get somebody out.
      01-13-2021, 04:50 PM   #6
HighlandPete
Drives: BMW F11 535i Touring
Are you running with an inhibitor, to help prevent sludge and corrosion?
'Air' (hydrogen) can be generated due to corrosion and oxidisation.
      01-13-2021, 04:51 PM   #7
Gillespie
Yes I am.
      01-14-2021, 01:55 AM   #8
G50
G50's Avatar
Drives: G31
Is it the fiesta driving footballers bedroom?
      01-14-2021, 02:13 AM   #9
Gillespie
Yes
      01-14-2021, 02:21 AM   #10
G50
G50's Avatar
Drives: G31
Yes
Ahh, all is right with the [forum] world once again!
      01-14-2021, 02:28 AM   #11
JustChris
JustChris's Avatar
Drives: Tesla MYRWD
We've a radiator like this too. annoyingly it's the one in our bedroom. Seems to only take a few weeks before it needs bleeding again.
It's bubbly as F on full heating, barley need an alarm in the morning.
My car made front page of Bimmerpost
      01-14-2021, 03:56 AM   #12
Ronstein
Ronstein's Avatar
England
416
Drives: 2019 640i GT MSport
This ^
2019 640i GT MSport & 2016 X3 3.5D X-Drive MSport
Previous
- 2016 530D MSport
- 2016 335D Touring M Sport X-drive
- 2014 335D GT X-Drive MSport
      01-14-2021, 05:42 AM   #13
Harryg
Drives: BMW 4series Grand Coupe
Had the same problem with a leak driving me barmy went at it and eventually found it was a seal on a union, cleaned area renewed seal and no more problems.
Al I got off the better half was seems fitting a turnip looking for a leak.
      01-14-2021, 06:46 AM   #14
Watsey
Drives: F31 330D sDrive M Sport
If it's a sealed system for heating and hot water you could also check whether it's sufficiently pressurised. Being well into the operating pressure range will help to reduce the likelihood of vapour forming in the boiler heat exchanger and remaining in the circulation system - higher pressure increases the boiling point of water. If the pressure dial on the boiler is indicating towards the low end of the range you can use the top-up circuit from the mains supply to increase the pressure.
Expansion vessels, normally an inflatable bladder in a rigid housing (often integral to the boiler), do leak air into the system over time. Just one of those things. I know how to inflate mine, but it's one of those things that a heating engineer would check/correct as part of a service.
      01-17-2021, 08:40 AM   #15
ZedsRedBaby
Drives: M440i Convertible
The easiest way to check for this is to hold a match or lighter to the vent when you bleed it. If it burns or pops, it's hydrogen generated by corrosion, if not it's just air in the system.
      01-17-2021, 12:18 PM   #16
jenshb
Drives: 2016 340i MSport
Be very careful holding open flame to a source of hydrogen. Hydrogen gas and air is a rather explosive mixture.
      01-17-2021, 12:58 PM   #17
ZedsRedBaby
Don't worry, the amount that comes out of a radiator won't blow your roof off
      01-17-2021, 01:20 PM   #18
EvilDrPorkChop
EvilDrPorkChop's Avatar
Drives: Porsche Cayman
A good system once settled down shouldn't get Air in - maybe a tiny bit but if it's continuous and a fair bit then there's an issue. Mine at home gets very little in.
If it's a sealed system - which seeming it sounds fairly new then you've probably got a very small water loss somewhere or corrosion (Or in some very rare cases, plastic pipe without the barrier in it which absorbs oxygen - from about 20 year ago). How often are you topping your pressure up?
If it's Open Vented (Where you have a small header tank in the loft) then there's the possibility it's drawing Air in through the Vent.
Hope that helps.
Resident Bimmerpost Plumber
1 AKY459.00
      01-17-2021, 01:39 PM   #19
Gillespie
Hope that helps.
Could it be that it’s a new system coupled to an old pipe network, we have solid floors so to replace the whole system would have meant digging it all up? The old part is steel imperial pipes.
      01-17-2021, 01:50 PM   #20
Goneinsixtyseconds
Drives: Q7 & Clubman JCW on order
Mine was doing this for ages, combined with a pressure top up every 6 weeks or so.
About two weeks ago the pressure started dropping every 12 hours. The most obvious sign at the boiler was not present, so worried it was a leak somewhere under the floor, as nothing obvious anywhere else.
Short version of story, turned out it was a cracked heat exchanger in the boiler, which luckily for me was still under warranty. 3 moths left of 7 years. He also said expansion vessel was flat and replaced that. Zero pressure loss and no radiator bleeding since it was done.
      01-17-2021, 02:16 PM   #21
EvilDrPorkChop
That's probably your issue then. Sure you've get Steel connected onto your new system? More than likely some corrosion going on. How often are you topping up the pressure?
Certainly something i'd of been replacing.
      01-17-2021, 02:26 PM   #22
JR1664
Drives: F30 340i
Father in law had similar. A combi on an old system but fortunately the leak was under floorboards.
You'll eventually find out if you have a leak under solid flooring ..in the next few years, so suggest you check your insurance as it ain't pretty.
