10-19-2019, 09:14 AM | #2884 |
Rep 15
First post: been struggling (like some others) to install the Avin 10.25 Android 9 display for my CIC F30. Currently I get 'no signal' on the iDrive, no audio anywhere, and I can't eject my CD.
Today I disconnected the Avin unit and wiring harness, restoring the 'native' CIC display and wiring, and I just get a 'BMW' logo on the screen. Something is horked - it is all original wiring back in place. Question: do I need to re-connect ALL the wires to make iDrive 'connect', e.g. the hazard lights and the temp control? I just have the head unit and the display connected right now Last edited by addikt; 10-19-2019 at 03:01 PM.. |
10-20-2019, 08:28 AM | #2885 | |
Rep 15
Wrong MCU?
I'm still trying to troubleshoot here .. wondering about the right combo of MCU and CIC vs NBT. My old/factory display says CIC right on the sticker, but it's a 6-pin LVDS connector and a MCU that references NBT in it (023042bGS-NBT-HW7-19074[B1280_170325]. What's the magic combo of MCU, NBT/CIC, and Avin display? |
10-20-2019, 03:56 PM | #2886 | |
Rep 15
10-22-2019, 04:26 AM | #2888 |
Rep 67
No signal problem occur due to cables which are not fitting perfectly. I had this problem too and my seller said that I should unplug and plug in again, the quadlock has to fit right. At first it seems that it sits right but it doesn't. After that everything worked fine
10-22-2019, 05:42 AM | #2889 | |
Rep 15
10-23-2019, 09:10 PM | #2890 |
Rep 15
Attaching a photo of my original LVDS. Is it CIC or NBT? Will this Android display and iDrive even work with it (so far, no)?
Edit: AVIN support confirms this is NBT, despite my factory display saying 'CIC' on the sticker ... Last edited by addikt; 10-23-2019 at 09:35 PM.. |
10-24-2019, 04:57 AM | #2891 |
Rep 67
This is nbt cable (purple) like mine so if you have cic you can not connect of course because this are two different cable types and of course if you do not put this cable into the head unit you will get no signal. Which car you have? Give me exactly model and producing time not the time the car was delivered.
11-20-2019, 02:40 PM | #2892 | |
Rep 18
1 - can you listen to the original radio and an Android app at the same time? Like, have waze on the screen, receive audio directions from waze, and also still have FM radio running? Hello. How is this set up? |
11-21-2019, 10:12 AM | #2894 |
Rep 18
Hello. I have a problem with sound, listening to the radio entering google maps, I do not have voice commands from the map. Switching to AUX voice commands from the map are, but there is no radio. I have a Harman Kardon sound amplifier, through which the sound goes through an optical cable, only from the amplifier to the speakers.
Maybe there is a problem here. I'm posting a video from Youtube |
12-05-2019, 02:47 PM | #2895 |
Rep 76
What do these android units show at start up? I want it to look OEM, where at start up all I get is BMW logo up, without an Android logo popping up. I’ve searched videos but can’t seem to find one. Please let me know, thank you all!!
12-05-2019, 02:57 PM | #2896 |
Rep 3,022
Drives: 2019 M2 Competition
it starts where you last left it.. so if on idrive, there is zero startup delay and shows the normal car info
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
12-07-2019, 08:26 AM | #2897 | |
Rep 79
If starting on the Android side, you can select a built in boot-screen logo to display (BMW, Audi, Mercedes) - when done, this is all you see on boot-up, until it lands in the menu. I leave mine on the Android side 99% of the time (for CarPlay use), unless I was over on original BMW side and forgot to set it back for Android boot. On a side note (mine is a gen-2 unit), to force it to boot to Android, I have to have it run the default built-in Music app for 30 seconds at shut-down. Once set, don't need to do that every time, only if it got toggled back to booting to old BMW. This quirk may have gone away in newer units. |
12-16-2019, 10:05 AM | #2898 |
Rep 63
I am trying to update to the latest firmware and it will not recognize the zip file, I have tried renaming using format and update and neither work. Any other ways to install the firmware?
12-16-2019, 11:30 AM | #2899 |
Rep 220
Drives: MINI Cooper, 2020 X1
what firmware on what unit?
12-18-2019, 03:55 AM | #2900 |
Rep 43
You need to make sure you have relocated and plugged the green fibre optic cable into the quadlock connector that goes into the back of the headunit. This will be your issue.
12-18-2019, 09:27 AM | #2901 |
Rep 63
12-18-2019, 01:55 PM | #2902 | |
Rep 220
Download it, rename it to px6.zip, upload it to the root of FAT32 formatted USB stick. Insert it to USB, reboot unit and wait patiently. Try both USB slots. If it fails, try FAT32 fotmated SD. If that doesn't help, rename px6.zip to px6_format.zip and repeat the procedure. (this will clear everything to factory default). If that doesn't help either, be glad the unit works at all and leave it that way. https://mega.nz/#!FEUmja5C!2oU7UfXOh...em4bwOYZxF6mh4 |
fletchf69.50 |
12-19-2019, 07:09 AM | #2903 | |
Rep 43
12-30-2019, 08:18 PM | #2904 | |
Rep 15
