BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Avin USA 10.25 android system install DIY
      07-13-2020, 06:30 AM   #2993
matze19999
Drives: BMW x1
Originally Posted by F20_M135i View Post
only for snapdragon can be ... because for PX6 Rockchip, you must be root to access System \ Media and place the files splash.img + bootanimation.zip = which correspond to your unit /!\
Do you know how to root the device with PX6 cpu?
      07-13-2020, 12:28 PM   #2994
F20_M135i
France
101
Drives: BMW F20 M140i Xdrive
https://f30.bimmerpost.com/forums/sh...postcount=1363
Do not install MAGISK & R EXPOSED
      07-13-2020, 02:24 PM   #2995
aakash2aki
Drives: 2014 bmw f30 msport
Andream 10.25" Wireless Apple CarPlay Screen
Hi Guys,
Have anyone tried this 10.25" Wireless Apple CarPlay Screen for BMW F30 listed here:-
https://www.android-car-dvd.com/prod...33378247508104
not able to find much info on this.
Thanks
      07-15-2020, 08:32 AM   #2996
Vexxus
Drives: BMW F30
For anyone experiencing bad sound quality, unplug the aux cable in your armrest. Simply remove the plastic cover and disconnect the aux cable, all fixed now.
      07-24-2020, 07:51 PM   #2997
AGONXF30
AGONXF30's Avatar
Drives: 2012 335i S-Line/Melbourne Red
I have not gotten one of this due to the fear of bad sound quality. Do you have HK? Can some else also confirm this is a fix?
      08-18-2020, 01:34 PM   #2998
Sparky68
Sparky68's Avatar
684
Drives: 2016 M2 Alpine White
2016 BMW M2  [0.50]
2017 BMW F30 330D  [0.00]
2014 M135  [0.00]
2007 BMW 335i  [0.00]
Does anyone know if my unit can be updated.
rkpx3-eng 4.4.4 KTU84Q ENG.ZXW.20170830.121722 test-keys
OG M2 7sp DCT Masata FMIC - Masata Boost Pipe - Cobra Catless DP - Powervalve Exhaust - Devilsown Methanol Injection BM3 Stage 2
      08-18-2020, 02:23 PM   #2999
makowb
Drives: BMW X1 2017
Is it possible to simply use the android system as a new monitor and have it boot directly to the car's head unit? I think I want to do NBT EVO retrofit, but I currently have a 6.5" screen.
Purchasing a 10.25" screen from another BMW is generally more expensive (700+ for touch on ebay) than one of these head units and I'm not even sure it'll fit correctly where I know this will fit on my F48 X1.
      08-20-2020, 11:21 PM   #3000
M4GUY2018
M4 GUY
Drives: 2015 M4
i would like yours i have them once when i first installed but now they are gone and my screen looks simple
My M4's Log/Journal
[VSRF down pipes | AA mid pipe | VSRF Front Mount Intakes | BM3 Stage 2 | | VRSF charge pipes | CSF Heat Exchanger| CSF Air-Intercooler|20 in Vossen|Stoptech|RW Carbon Accents|Brembo Brakes|
      08-26-2020, 03:03 AM   #3001
Frankly30
Drives: F30
Can confirm this worked on mine (PX6). Though doesnt work on every car I read. Greets!
https://f30.bimmerpost.com/forums/showthread.php?p=25311599#post25311599
      09-02-2020, 06:33 PM   #3002
EvntHrzn
Drives: BMW F10
For those that use Avin units, or their apk solution/dongle for carplay: There was just an update to the dongle itself that added support for separation of volume control between media/navigation/microphone. It's in options, under "Additional Settings".
I don't know how it is on other units, but finally being able to lower or raise the navigation voice independently of the main volume was one of the last quirks I've been waiting for them to add/fix.
To summarize: This is regarding Avin units (but not necessarily just), and the app called AutoPlayBox which they use for their wireless carplay integration via their dongle.
      10-02-2020, 06:08 AM   #3003
stroker15
Drives: 2013 328I Sportline
Questions about wiring.
Hello, sorry I tried my best but couldn't read all 100 pages of this post. So if this is already answered, I apologize in advance.
1. I just got the new Avin Android 10 screen for my F30. I have the CIC head unit and I'm hoping I have the 6 pin NBT LVDS plug, fingers crossed, but I haven't started the install yet. I'm guessing if I have the 4 pin CIC plug then I'll have to return this. Does anyone know if the 4 pin CIC plug will fit into the 6 pin plug of this unit?
2. I noticed on the harness that the 3.5 Audio out and Audio in on the wiring harness is plugged in together. Should they be plugged in together or do I need to unplug it? Of course that's depending on if I get sound or I need to run the aux cable under my arm rest.
3. What is the long flat thing with the double sided tape? Is that an LTE or 4G antenna?
4. My harness came with a small external speaker. What is that for? I've never seen any install videos where that little speaker is included. Could that be for the vehicle chimes and dings?
Thanks for the help. I wish these things came with instructions, or an owners manual at least.
ER Catted Downpipe| K&N Drop in Air Filter| FTP Charge Pipes| CSF Intercooler| Bootmod3 Stage 2| Michelin Pilot Sport 4S| Carbon Fiber Trim| 30% Ceramic Tint| Audio Control DM-810 DSP| Audison Bit DMI Digital Interface| Pioneer Amps| Rockford Fosgate T3-BMW1| Earthquake Subs.
      10-03-2020, 12:17 AM   #3004
daxtor
Drives: EBII F30 335i
1. I don't think the 6 pin and 4 pin plugs are compatible. If they don't match you'll probably need to return the unit.
2. I don't recall doing anything special about the audio cable, but I did remember having to move over the green sound cable over to the new plug to get sound.
3. No idea, as I didn't intend to use the LTE capability of the unit I didn't install that flat strip.
4. I recall someone saying the speaker is for navigation voice when you are ni BMW iDrive mode while you have a navigation software running on the Android side. Don't quote me on this though.
      10-03-2020, 03:56 PM   #3005
Mjam
Drives: E87, i3, Taycan Cross Turismo
Yes. Try reception in different places to find the perfect location for the 4G/LTE antenna.
      10-05-2020, 11:47 AM   #3006
stroker15
Thanks for the replies Mirjam and Daxtor. I did have the 6 pin NBT plug. I got everything plugged in. Problem is, now the android side reboots every minute or so. I'll start a new thread since this one is over 130 pages long.
      10-15-2020, 04:20 PM   #3007
n2siast
Drives: E93 335i M-SPORT
Quick question, I just installed the 10.25 snapdragon Avin unit and so far very pleased with it.
One issue is that I only have 1 UI option, the Avin_AV8, which I curiously selected when I was in the Factory Setting, and that changed the layout from the original tile view in the first pic, to the enlarged view in the second pic.
Any idea how to change it back to the original? I tried selecting the UI again, but to no avail.
Appreciate any input.
      10-16-2020, 11:32 PM   #3008
daxtor
I haven't seen the layout in the first pic at all (I have the Avin screen as well, but it is the Android 9 version and I bought it quite some time ago). Are there any options in the factory settings menu to change it back to the other layout?
      10-17-2020, 02:53 AM   #3009
Kri
Austria
1084
Drives: E87
If you have a Snapdragon 625 HU you can use the Full Feature factory_config file, for Android check 9 here and for Android 10 here.
Kri
      10-17-2020, 04:32 AM   #3010
n2siast
Kri
Thanks, Gents. I initially only had one option for the UI, but reading through this thread and finally getting a response from AVIN, I was able to load the factory XML File and now have the option for the additional UIs. Changed back to the way that I wanted it.
Overall pretty pleased with the unit and sound quality. I'm no audiophile by any means, but it sounds pretty decent via AUX and Premium Sound.
Just a few minor gripes with the unit that I can live with.
      11-06-2020, 06:23 PM   #3011
Doug Dimmadome
Drives: BMW F30 330ix
Sorry if this has been asked but I can't find this topic anywhere:
So while installing my new headunit from avin, I noticed I didn't have the green and black optical cables. It seems like because of this I can't connect to the original idrive and don't have any sound.
Any help is appreciated. Thanks.
      11-08-2020, 11:37 PM   #3012
daxtor
You may need to use the AUX cable in this case. My headunit does have the optical cable so I don't need to use the AUX cable.
      01-26-2021, 12:27 PM   #3013
angel212
Drives: X5 Diesel
Apple Car Play and Radio
anyone have this problem, every time i`m using Apple CarPlay my radio stop working so I cant use Fm radio/carplay at the same time.
Im missing something? any setting to make available audio from the radio and car play.
Bmw X5 with 10.5 avinusa head unit . (lates unit)
      01-30-2021, 10:31 AM   #3014
Migz71
Drives: Bmw 1 series (F20)
Hi all,what is the best 10.25" android screen for the f22? RHD Cheers
