04-27-2018, 02:14 PM | #1871 |
Rep 41
ok here we go;
MCU Update: https://1drv.ms/u/s!Ak6qzpi2dqVMlXKBaoBeDcVUdIr_ Firmware (keep in mind, its older then the feb update, i think its a version compiled in jan 2018. They also told me that they are working on a new version. Firmware: https://1drv.ms/f/s!Ak6qzpi2dqVMlXYClx-z4Tam1Pgm Hopefully my replacement screen solves my issues, but that will take 2 weeks to come in(luckily send from germany, so no taxes). One thing I really appreciate and i didnt expect from an aliexpress seller, was/is the great support from them, until now. for a small Movie of the issue I have with the display of the idrive input: https://1drv.ms/v/s!Ak6qzpi2dqVMlW9WyU71S34E15Aj maybe someone else have a solution or some ideas why? already done; firmare update mcu update several cartypes.xml tried and all the options in them. thanks Bart |
04-27-2018, 02:47 PM | #1872 | |
Rep 45
04-27-2018, 03:11 PM | #1873 |
Danilo
Rep 43
NEW UPDATE
For the joy of everyone !!
New Firmware that eliminates error "no Signal" FROM TOMMY LINKS: https://drive.google.com/file/d/1p1A...-1xw3K9xh/view 10/04/2018 BYE |
CleanKM103.50 |
04-27-2018, 03:14 PM | #1874 | |
Rep 147
Does it fulfill my requirement? I hope it does.... Also can you tell me how do I open the back seat light cover to access shark fin bottom part? I have f30 320d efficient dynamics 2015 edition. Do you know whether it has gps antenna connection point? Should I just leave the receiver inside this shark fin and close or should I screw it up in shark fin? Thanks in advance. |
04-27-2018, 03:24 PM | #1875 | ||
Rep 21
Tks a lot!
04-28-2018, 07:31 AM | #1876 | |
Rep 147
04-28-2018, 07:38 AM | #1877 | |
Rep 45
Thanks. |
04-28-2018, 01:39 PM | #1878 | |
Rep 190
Does anyone have CCC MCU file to share? I have one but does not update. It stucks in wait to update but nothing happens. Last edited by koutsouk; 04-28-2018 at 01:45 PM.. |
04-28-2018, 04:03 PM | #1879 |
Rep 41
Hi,
Maybe a bit offtopic. But my screen issues are not solvable as stated so the supplieer gave me the option of getting it refunded or send a new one. I think i would try the new one because i really like the functionality. However next to the screen issue i have ( yellowish and bright colors in idrive or good colors, but wrong screen size) i have sometimes the issue that the unit wont boot and i dont see my idrive either.. this happens mostly after a short stop locking the car for ca 5 min. When reclosing for ca 15 min both start working again. Now my question is there somebody who encounters these issues ass well? If thats the case i would go for a refund. Hopefully my current unit is just faulty. Barr |
04-29-2018, 06:59 AM | #1880 |
Rep 63
Who mentioned wifi. No wifi being used
04-29-2018, 07:58 AM | #1881 | |
Rep 17
04-29-2018, 12:09 PM | #1882 |
Rep 147
04-30-2018, 01:10 AM | #1883 | |
Rep 147
04-30-2018, 04:16 AM | #1884 |
Rep 63
04-30-2018, 09:11 AM | #1885 | |
Rep 1,615
The second issue you have I never ran into but the screens saturation is a bit "different"
Originally Posted by jmg
That seat was meant to be used, are you going to deny it's purpose in life? |
04-30-2018, 01:09 PM | #1886 | |
Rep 41
so you are talking about the boot/startup issue or the screen yellowness/brightness issue? thnx for ur feedback just curious what car and what original display do you had/have? The strange thing when i select for example a 6.5 inch original cartype, the colors where good. i only got the issue when selecting a fullscreen 10inch cartype, which i obviously need for my original screen output. bart Last edited by beeee83; 04-30-2018 at 01:23 PM.. |
04-30-2018, 01:45 PM | #1887 | |
Rep 1,615
The issue that never got resolved was the screen and how it fit...the image was cut off on the left just like yours and since no one else was running into the issue at the time, AVIN didn't know what to do so I literally gave up on it all after trying a crapload of options. I originally had the 8.8 Pro NAVI setup before that. The colors were just bad all together when I installed the AVIN screen but I really noticed the quality issue when I plugged a new 10.2" OEM in from BMW. Having said that, I could definitely get over the color and audio issues if they upgraded/fixed several other bugs. It was a nice unit but not quite ready for prime time in my personal opinion whether it "works" for others or not; especially in a BMW. We have enough "issues" with our BMWs
04-30-2018, 01:58 PM | #1888 | |
Rep 41
Ok thanks for the info, so it was an avin version 1 monitor? Im thinking about going for the refund and trying the avin v2... Avin said they didnt encounter similar issues as i described with their units.. |
04-30-2018, 02:09 PM | #1889 | ||
Rep 1,615
04-30-2018, 03:10 PM | #1890 | |
Rep 41
jeffc83725.00 |
04-30-2018, 03:39 PM | #1891 |
Rep 1,615
Thanks and I hope that fixes it for you! If not, I would think it's possible that our istep versions are "somehow" unique as I wouldn't think this would be an issue with the HU. I even coded out the larger screen resolution in eSYS to no avail so it isn't a "simple setting"...you can tell this drove me nuts man and welp, it kinda still is!!!
04-30-2018, 03:44 PM | #1892 | |
Rep 63
