05-24-2022, 11:26 AM | #1 |
Rep 19
2016 340i B58 hesitation during cranking
Hey all, I'm experiencing some random hesitation when starting my unmodified 2016 340i with 60k miles. When i press the start button, the car will start to crank very briefly, hesitate for about 1/2 second then start up like normal. I've had it happen during cold starts and after a long highway drives. It starts normally 90-95% of the time but this seems to be getting more frequent.
I'll be getting my battery tested this weekend but i don't think that's the issue. I found some similar, but not the same, issues on this forum where a grounding strap was broken or corroded. Has anyone experienced this? If this is the issue, does anyone know the part number and location for the engine grounding strap? I'll be doing routine maintenance this weekend and if the grounding strap is a possible issue, I might just order it and go from there. |
05-24-2022, 04:22 PM | #2 |
Rep 1,457
More than likely your injector(s) are leaking. I had a rough hesitation start up when it was cold and warm until my cylinder walls got scored up. I'm not saying this can be the case, but it's well possible and just be careful. Its cheap insurance to drop in 6 injectors with the mileage you're at as a preventative maintenance. It could also be a weak high pressure fuel pump. Lots of things can cause a hesitation start up and it's best to have it checked out by someone that actually knows about bmws and has worked on the B58.
2024 X3 M40i
2014 BMW M5 |
mountaineer106.50 |
05-24-2022, 09:49 PM | #3 | |
Rep 19
05-25-2022, 08:05 AM | #4 |
Rep 3,877
Can you make and post a video of the phenomena? Would be interesting and useful to actually see/hear what it is doing. This will allow others who had similar behaviour to recognise it easier.
06-07-2022, 10:11 PM | #5 |
Rep 19
It turned out that the battery was bad. It was strange to me because i hadn't experienced a battery going bad gradually over several weeks while still working perfectly 95% of the time. Guess I was used to old school technology where batteries seemed to go bad with little notice.
cfm56d7b5886.00 |
06-07-2022, 11:00 PM | #6 | |
Rep 10,256
06-08-2022, 11:22 AM | #7 |
Rep 370
I had the same problem with the same remedy. The Car would take an extra second or 2 to crank over. Got checked out by BMW stealership and about $600 later had a new battery and everything was like clock work again.
mountaineer106.50 |
06-08-2022, 12:10 PM | #8 |
Rep 3,877
But is it a classic slow starter noise or does it sound normal, just takes extra attempts and time to crank?
06-08-2022, 12:24 PM | #9 | |
Rep 950
FlappyGoose3.00 Fizzius33.00 |
06-08-2022, 03:13 PM | #10 |
Rep 1,454
2016 with 60k miles and your battery lasted this long? Mine went out around 45kish or so last year lol. I think replacing it every 4 years/40k as preventative maintenance is a good idea.
2022 CT4-V Blackwing 6-speed
06-08-2022, 03:17 PM | #11 |
Rep 950
06-13-2022, 04:32 PM | #12 | |
Rep 19
Then it would go back to normal starting like usual until about a week later, it would do the "video on pause" thing again. It would usually do this on the first crank after a 30+ minute highway drive (like after stopping at a convenience store). This is why it stumped me. I expected the battery would be fully charged after a long highway drive. |
06-13-2022, 04:35 PM | #13 |
Rep 19
Oh man. I guess I got lucky. My car mostly sat around for a year or so during 2020-2021.
07-03-2022, 08:44 AM | #14 |
Rep 75
Interesting... I have a 2016 340i xdrive with 84k on it and I am the 3rd owner. Car was always serviced at the dealership that I purchased from and done all items that were recommended including oil every 10k. However, I do not remember seeing that the battery has ever been replaced. If what you guys are saying is true, I may be looking at replacing before winter hits here in the midwest.
340i, b58, cranking, slow crank |
