08-28-2023, 04:17 PM | #1 |
Rep 32
Unable to Tune - WGDC Boost Drop (Update: Solved)
2016 340i xdrive
Vargas GC 93 oct custom tune AA Catted Downpipe TU pump New injectors and plugs Hey guys, I've been working with my tuner since the beginning of the year, but can't seem to dial in the tune. Every time he brings the boost up, I keep getting WGDC dips around 5500-6k and boost seems to drop. I'm fairly confident it isn't the tune as he's got a lot of experience with the gc. Would anyone know what might be causing the issue? No loose clams or intake leaks, compression test passed, no cel. Logs (newest to oldest, last 3 maps): https://www.bootmod3.net/log?id=64e4...90c6b3c3d87d0f https://www.bootmod3.net/log?id=64e1...90c6b78d1401f6 https://www.bootmod3.net/log?id=64c9...729be572fdafb6 UPDATE: So it turns out it was tune related even though the previous tuner had me convinced it was something mechanical with my car. I switched tuners and now working with OdinTuned and am extremely happy with the results on the first few revisions. Not sure why the previous tuner was having trouble, but I definitely recommend OdinTuned for anyone looking. Great communication, fast turn around and even gives you a breakdown of what he adjusts. No hard feelings against the previous tuner, but definitely looking forward to the next revisions from Kirill! Experience with Vargas: I do want to add for anyone looking at any Vargas product to STAY AWAY AT ALL COSTS. Even though I'm happy with how the turbo performs now, their customer service is beyond horrendous. I can confirm first hand that all the negative reviews and comments are true and the only reason we don't see more, is that they actively remove or suppress anything negative whenever possible (probably why most of their products have no ratings). They are quick to blame the customer and will not take any responsibility whatsoever, just read their responses to anything critical. It's unfortunate because I wanted to like and use their products, but never again. I hope this helps anyone considering and If you do decide to purchase from them, good luck! Update Part 2: Final Logs from OdinTuned Just want to share my final logs. I'm very happy with how the car is performing now and can't recommend Odin enough, thank you again! https://www.bootmod3.net/log?id=64f5...0b4309cddc75dd https://www.bootmod3.net/log?id=64f5...0b4306799c32d6 https://www.bootmod3.net/log?id=64f5...0b4306799c32f8
VTT GC | TU HPFP | AA Catted DP | BMS Intake | OdinTuned 93 oct | XHP Stage 2 |
08-28-2023, 11:50 PM | #2 |
Rep 1,454
Have you gotten your intake and exhaust smoke tested? 90%+ WGDC for 22psi. You're underboosting most of the pull and load actual% is always a bit under load target except for a few spikes.
2022 CT4-V Blackwing 6-speed
08-29-2023, 02:30 AM | #3 |
Rep 3,877
Sorry for using the thread but I am trying to understand how intake and exhaust leakages can possibly influence boost!? Whether air is sucked in partially from a leaky intake or exits partially from a leaky exhaust shouldn't have any influence on boost itself!? Leaky charge-pipe is of course a different story.
08-29-2023, 07:27 AM | #4 |
Rep 32
I've checked the intake a bunch of times and there are no leaks. Everything is clamped down, filter is new and piping is solid (nothing flimsy that could suck in on itself)
08-29-2023, 11:49 PM | #5 | |
Rep 950
Long story short, scale up the base WGDC a bit and you shouldnt see those drops in the higher rpm range. Edit: I think its the tune if you've checked everything else and I can kind of see it in the logs that the base wgdc hasnt been touched. |
Catman411519.50 |
09-01-2023, 08:29 AM | #7 |
Rep 950
Catman411519.50 M2C40.00 |
09-01-2023, 08:53 AM | #8 |
Rep 32
I couldn't agree more, it feels like a whole new car!
WrxToBeamerGuy492.00 |
09-04-2023, 12:38 PM | #9 |
Rep 32
Updated with final logs from OdinTuned
WrxToBeamerGuy492.00 kern4174449.50 |
09-13-2023, 01:38 PM | #10 |
Rep 118
This is so good to hear. Congratulations! Your tune is looking absolutely fantastic. Starting by already around 5,200 rpm you're having around 500hp all the way until redline. This must be fast for only 93 octane.
I'm so happy that you found help, because I'm facing more or less the same issue as you can see here in my post at the other (log) thread: https://f30.bimmerpost.com/forums/sh...postcount=3814 I've already been told several times about the high quality and especially great communication of Kirill, too. That's what I'm missing with my actual tuner completly. No transparency at all. So for me, the big question now is, when to stop the trial and error process with the old tuner. Especially, because I guess he won't refund anything. So I would have to pay twice for the same aim. Btw, how did you handle this? Edit: Just one more question - How many revision did Kirill need? Last edited by M2C; 09-13-2023 at 01:58 PM.. |
09-13-2023, 07:37 PM | #11 | |
Rep 32
Thanks! I can attest to that too, Kirill is great and it only took 5 revisions. With the previous tuner I was at revision 30 before I gave up. I would reach out to him with the logs and see if he can help. His communication is great and should be able to give you a straight answer: https://f30.bimmerpost.com/forums/member.php?u=463794
09-14-2023, 12:57 AM | #12 |
Rep 329
where is odin im trying to get my pure850 tuned but he doesnt respond
2018 340i - MHD CUSTOM TUNE, PURE850, DORCH STG2.5,MHD-FLEX-FUEL, M-PERF LSD, XHP Stg 2, CSF Heat Exchanger, M-Perf EXHAUST Mid Pipe BACK, Ross Racing Oil Catch Can, Evo Race Work Downpipe, PURE Inlet, DINAN Intake, VRSF Chargepipe
2011 335is - SOLD |
09-14-2023, 04:26 AM | #13 | |
Rep 118
Thanks a lot for the informations. |
Catman411519.50 |
93 octaine, 93oct, b58, vargas, vargas gc, vtt, vtt gc |
