06-18-2021, 12:21 PM | #1 |
Rep 732
Object stuck in 12 volt outlet
Hey all. I just realized my outlet has been like this from when I bought the car. Not sure what the previous owner did. Does anyone recognize what's going on here? I think maybe a tip of an adapter snapped off and might need tweezers
View post on imgur.com |
06-18-2021, 12:26 PM | #2 |
poopycat
266
Rep 791
That's what it looks like. I think of these cars energize the circuit when any door is opened or maybe disarmed or other triggers... just be very careful that you don't ground it on the sides.
Question is why is it stuck down there? Sticky soda maybe dried like a glue and held down the tip? Might be hard to remove. |
06-18-2021, 12:27 PM | #3 | |
Rep 732
06-18-2021, 12:32 PM | #4 |
Rep 6,222
Drives: 2018 340i M Sport
Garage List 2018 BMW 340i M Sport [9.38]
2020 BMW M340i xDrive [10.00] 2018 BMW 340i M Sport [8.00] 2006 BMW 330i Sport [4.50] 2004 BMW 330i ZHP [7.25] 2000 BMW 328i [6.00] |
Rubber handled needle nose pliers.
www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ |
tex26702411.00 |
06-18-2021, 12:48 PM | #5 |
Rep 562
Drives: 2017 BMW 330i xDrive
Disconnect the negative terminal on the battery, then grab a set of pliers and go to town.
2017 330i xDrive Imperial Blue Exterior / Venetian Beige Leather with Oyster Accent Interior / Anthracite Wood Trim |
06-18-2021, 12:56 PM | #6 |
Rep 923
If that's metal, your fuse is probably already blown. Took me a while to find the fuse number, but it's here somewhere. The graphics on fuse card don't help for lighters.
06-18-2021, 02:04 PM | #7 |
Rep 292
Drives: 2016 340i X Drive
It’s best to remove the panel, held on by two 10mm screws. Then you can disconnect the two cables and work on the outlet on your workbench. Here’s a link to the cabin filter change procedure, which shows you how to remove the panel.
06-18-2021, 02:17 PM | #8 |
Rep 732
Unfortunately it is in the cupholder not the underpanel outlet
06-18-2021, 03:13 PM | #9 |
Rep 4,870
You don't need to take it out. Just ensure there is no power at the outlet, and grab the end with needle nosed pliers.
If you look at your pic, its just the removable end from an adapter (where you unscrew the end to replace the fuse). It should come out really easy. |
06-18-2021, 03:23 PM | #10 |
BMW CCA Member
488
Rep 808
Disconnect the battery FIRST, then do whatever. If a metal tool or jewelry gets a positive and ground connection, they will get RED HOT within seconds.
Here's an idea of what happens. Imagine this with a tool in your hands or a ring on your finger. And this battery is smaller/less powerful than the one in our cars! FF to 2:00 Last edited by exE36M3; 06-19-2021 at 01:20 AM.. |
auburnf30x434.50 |
06-18-2021, 04:00 PM | #11 |
Rep 844
I had a penny stuck in there from the previous owner when I bought my car. The fuse was blown but it was a pain to get out. Either pull the fuse or disconnect the battery and then yank that sucker out with some needle pliers like others have stated. You'll be fine
2019 x5 50i - current
2016 340i THP stage 2 - gone but not forgotten. |
06-18-2021, 04:29 PM | #12 | |
Rep 562
Disconnecting the negative terminal on the battery takes all of 30 seconds and is the only correct way to safely work on vehicle electronics when there is a risk of shock or shorting the circuit. There is zero risk of electrical shock or damage to your car’s sensitive electronics with the battery disconnected.
exE36M3487.50 |
06-19-2021, 08:45 AM | #13 |
poopycat
266
Rep 791
I'm sure you got it done, but wow, just wow.
Rubber gripped needle nosed usually have exposed tips and can short the fused circuit. Disconnect battery - do you have a diag tool to reset module codes and possible CEL? Even pulling the battery, there can be electrons on the circuit waiting to unleash sparky hot dogs. Circuit appears wide open - test it with a fluke or test light, most homeowners have these things. Fused circuit - even if grounded, the fuse will pop. Assumes stock wiring, and no sparks in hot dog videos. |
06-19-2021, 09:21 AM | #14 | |
Rep 562
Disconnecting sooner may result in other errors, but they can be cleared. A short stomp on the brake pedal after disconnect can help discharge any residual stored charge.
06-19-2021, 09:30 AM | #15 | ||
Rep 16,054
06-19-2021, 09:42 AM | #16 |
Rep 562
How so? On mine, there’s a little panel release ‘knob’ to turn, and the panel comes quickly off to expose the battery. A few turns with a 10mm wrench, and the negative terminal comes right off. All of 30 seconds time, no exaggeration. Is it different on the GT?
06-19-2021, 09:55 AM | #17 |
Rep 16,054
It's totally different on the GT. There's a floor trim panel, a luggage compartment trim panel, and once they're pulled there's a bolted in storage compartment above the battery that has to be removed.
