BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > B58 squeak - faulty tensioner/slipping belt
      08-03-2016, 05:11 PM   #45
buckybadger
BMW forever!
buckybadger's Avatar
Originally Posted by BeaminBimmer View Post
It started doing it again
This is why I am against buying new engine models for at least a couple of years.... but I do understand how you feel. Good luck
2020 BMW X5
2019 BMW M2C
2014 BMW 335i
2009 BMW 328i
      08-03-2016, 10:35 PM   #46
Jaghave
Drives: 2016 BMW 340i (Auto) RWD
I haven't experience this sound yet but I'm a pretty pedestrian Driver I'll keep my ear open next time I need to eat a fart can Honda at a red light.
Mr D19.50
      08-04-2016, 09:28 AM   #47
BeaminBimmer
Drives: BMW X5 M50i
Yea... it didn't do it since i got the car back... and yesterday morning it did it once...
Originally Posted by Spikey View Post
crap, even after they swapped parts?
Current:2021 X5 M50i | 2022 XB7
Old: 2013 335i x-drive |retired 05-2016 ||2014 320i x-drive | retired 03-2018 ||2016 340i x-drive |retired 03-2018 ||2018 X5 |retired 06-2021||2018 430i | retired 10-2021
      08-17-2016, 04:07 AM   #48
competition
competition's Avatar
Drives: '21 F87 M2C
my 340i does it pretty often as well.
1-2 and 2-3 only. my 340i is also 8AT
      08-17-2016, 08:01 AM   #49
insanecoder
Drives: 340isDrive
Are you taking it back to the dealership then cause they obviously didnt fix it?
      08-18-2016, 08:15 AM   #50
BeaminBimmer
Drives: BMW X5 M50i
Yea i've got an appointment next week... It only does it when the A/C is on... when the a/c is on i feel like the whole car struggles... i get a stumbling effect... and the squeak happens... when the a/c is off i got no issues.
      08-18-2016, 08:31 AM   #51
insanecoder
Drives: 340isDrive
Did they say/or can you tell if the squeak was coming from the A/C belt slippage or the A/C unit internals?
I doubt the whole car would struggle unless high loads were placed upon it via the A/C belt.. perhaps the A/C unit itself was struggling causing high resistance high load on the belts causing eventual slippage.. keep us informed thanks.
      08-18-2016, 08:48 AM   #52
BeaminBimmer
Drives: BMW X5 M50i
All i could tell is that the squeak is coming from the driver's side and i'm sure of that 100%.
When they replaced the tensioner and belt, they started with that because they didn't know what to start with. After i got my car back, I tried reproducing the noise with the A/C on and off and i wasn't able to. 2 weeks after i got my car back, the noise happened again.
This morning, cold start, floored my car with a/c off, no noise. Turned on the a/c, floored the car, squeak happened at first shift. Turned it back off, floored it, no noise, etc... once engine is warmed up the squeak doesn't happen again and that's what makes it hard to figure out. the timeframe is short to diagnose the origin of the noise. But it definitely only happens when the A/C is on.
      08-18-2016, 09:52 AM   #53
insanecoder
Drives: 340isDrive
Are you babying this puppy as its in the break-in period.. tranny included.
Dont drive it hard in low gears during breakin.
      08-18-2016, 01:38 PM   #54
BeaminBimmer
Drives: BMW X5 M50i
Lol break-in is done... i'm over 4000 miles.
      08-18-2016, 03:01 PM   #55
insanecoder
Drives: 340isDrive
4000 miles in 2 weeks.. nice
      08-18-2016, 03:18 PM   #56
RPM90
Drives: 340i M-sport AT
That almost sounds like an intake leak somewhere.
It could affect how the trans shifts, because depending on where the leak is it could disrupt the power flow, which can cause an odd shift.
My 340i AT doesn't do this.
      08-20-2016, 09:38 AM   #57
insanecoder
Drives: 340isDrive
BTW do you guys who have this squeal get this in conjunction as well?:
'stumble' or rough idle after initial start once the RPMs go below 1000 and how the engine acts like its a cold startup everytime the car is started, regardless of how warm the engine is
Also usually when the transmission squeaks like that the fluid is low or needs changing.. but these are almost new cars we're talkin about
      08-20-2016, 10:51 AM   #58
insanecoder
Drives: 340isDrive
BTW.. the M3 guys had an issue similar to this and the solution:
Dealer changed all belts and tensioners in the engine and the noise went away
Hopefully its just that.. let us knoww hat yer dealer eventually does
      08-21-2016, 05:02 PM   #59
BeaminBimmer
Drives: BMW X5 M50i
Yea I get that stumble
      08-25-2016, 04:02 PM   #60
BeaminBimmer
Drives: BMW X5 M50i
My car's back at the dealer. Said it's going to be a while.
      08-25-2016, 04:49 PM   #61
Eriphill
Eriphill's Avatar
2564
Drives: 340i
I stopped by a dealer today and spoke with the service manager. He said BMW was aware of the issue and was looking into it, but to date no one is sure what is causing the sound. He also mentioned that every one of their 340i demo/loaner's was making the sound. Said if a TSB was released they would call.
      08-26-2016, 01:05 PM   #62
BeaminBimmer
Drives: BMW X5 M50i
Does your car do it with the A/C on or off?
      08-26-2016, 01:45 PM   #63
cfm56d7b
Got an appointment on Wednesday at 8 AM. The deanship believes they've narrowed it down to a belt that has to do with A/C. Will keep you posted
What was the build date of your vehicle?
Good luck. Hope the dealer will find the root cause.
      08-26-2016, 02:09 PM   #64
insanecoder
Drives: 340isDrive
Just curious but do you guys get that stumble with auto start/stop off?
      08-26-2016, 06:38 PM   #65
Eriphill
Eriphill's Avatar
2564
Drives: 340i
I can`t really say. My car does it so rarely (maybe once a month) that I haven`t been able to narrow it down.
      08-26-2016, 08:03 PM   #66
Jaghave
I've heard the noise only once and that when I wanted to put a ricer in his place.
