BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Bm3 Stage 2+ Car doesn't start
      10-14-2020, 11:25 AM   #1
Hkilla00
Drives: Bmw 340i
Flashed stage 2 e30 the fuel pump was too loud so I flashed back to stage 2+ now the car turns on but shakes and ends up dying like there's no gas or something
Mods
Hpfp stage 2
Dp
CSF rad
Intake
Charge pipe
Ngk colder plugs
Codes
11AC02 - cold start pressure too low
118401 - Mixture too lean
      10-14-2020, 11:29 AM   #2
dawidd3
Drives: F30 340Xi B58
Stage 2+ is for cars with HPFP with B58TU, do you have such a modification?
      10-14-2020, 11:30 AM   #3
Hkilla00
Drives: Bmw 340i
I have a dorch stage 2 pump
      10-14-2020, 12:17 PM   #4
jackstrath
Scotland
659
Drives: 16' F31 340i & 03' Focus RS
Did you drive around on stage 2 e30?
      10-14-2020, 12:20 PM   #5
Hkilla00
Drives: Bmw 340i
I was before but I needed a new bumper so it's been parked for almost a week know I tried starting it today and on the e30 tune the pump was ticking too loud so my mechanic told me to flash back to 93 after I did that the car wouldn't start
      10-14-2020, 12:30 PM   #6
jackstrath
Scotland
659
Im not sure if its possible to damage the fuel pump running stage 2 softwear, E30 Does go off but not a week quick, i wouldnt of though that would of made the fuel pump louder but i guess could do if its gum'd up.
Just to be doubly clear here, you drove around with Stage 2 E30 (not stage 2+ E30) Sorta driving??
You should only be running the Stage 2+ maps with a upgraded HPFP, i wouldnt of thought damage would occor unless you were doing some hard pulls but maybe someone who has more experiance will hopefully chime in.
Edit - The codes defo point to a fuel issue, assuming you have checked for leaks around the pump.
      10-14-2020, 12:32 PM   #7
Hkilla00
Drives: Bmw 340i
I have a stage 2 hpfp I've been driving around with e30 for a month now but something hit my bumper and its been parked up in my garage since last week
      10-14-2020, 12:37 PM   #8
jackstrath
Scotland
659
Yes i see that but your first post isnt very clear,
Was the Stage 2 E30 actually Stage 2+ E30 ? And going to assume Stage 2+ is Stage 2+ 93
Need to know exactly what you were running if anyone over the forum is to try and understand and help.
Flashed stage 2 e30 the fuel pump was too loud so I flashed back to stage 2+ now the car turns on but shakes and ends up dying like there's no gas or something........
      10-14-2020, 12:38 PM   #9
Hkilla00
Drives: Bmw 340i
Oh sorry it was stage 2+ e30
      10-14-2020, 12:42 PM   #10
dawidd3
You edited the post after my reply.
Errors from low fuel pressure, either a leak or the HPFP is defective.
      10-14-2020, 01:04 PM   #11
Hkilla00
Drives: Bmw 340i
My guy is telling me it's the lpfp
      10-14-2020, 02:20 PM   #12
G.Newt
Drives: CT4-V Blackwing 6MT
Did you select Dorch as your HPFP in the map config?
2022 CT4-V Blackwing 6-speed
SOLD: 2016 340i xDrive 6-speed
DAW v2.5 turbo E40 | Dorch S2 | VRSF DP | MST intake | AWE catback | 335is clutch | CSF heat exchanger | RK Autowerks intake manifold | Orange M Perf Brake Kit | KW Street Comfort coilovers | GTS taillights V2
      10-14-2020, 02:21 PM   #13
Hkilla00
Drives: Bmw 340i
Yes for the new calibration
      10-19-2020, 08:18 AM   #14
kern417
Cheapskate
4450
sounds like it could be a failed lpfp if the car won't start. Do you hear it prime when you open the door
      10-19-2020, 09:48 AM   #15
Hkilla00
Drives: Bmw 340i
Primes for too long
      10-20-2020, 09:13 AM   #16
kern417
Cheapskate
4450
Primes for too long
So probably either a leak or a bad pump (low pressure in tank)
      10-20-2020, 09:14 AM   #17
Hkilla00
Drives: Bmw 340i
Primes for too long
Yup got a stage 3 lpfp from Vader solutions ! Thanks for the help
kern4174449.50
