BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > B58 Log Review Thread
      11-17-2020, 01:48 PM   #1651
shovell242
Drives: 2017 M240i
Originally Posted by SlavTheCommie View Post
Ok good to know and I did read about a lot of throttle closure complaints. Unfortunately I'm not looking to do the HPFP yet (thanks COVID) and would like to just get in a good spot with the OEM one if possible. Also not interested in running E85 because I need to do more research and I'm assuming it's not very practical on a daily driver.
PTF also adjusted the map I was running as a test and I just sent back logs for their review. Timing looks better but the wonky HPFP readings and throttle closure is still there and will probably remain there. Is there anything threatening about that, or concerning?
https://www.bootmod3.net/log?id=5fb2...0b435a85f0be6a
Nope, the throttle closures are a way of the DME reducing air to deal with lack of pressure from the fuel and safeguarding your engine from a dangerous lean condition. DME is simply doing its job, I would be more concerned if it wasn't.
      11-17-2020, 03:13 PM   #1652
Cobra358
Drives: bmw 335i
As a note, I was getting dips in rail pressure down to 2000 with the stock pump and throttle closures. I went to the Supra pump and the dips went away as did the throttle closures, same fuel in the tank. i do think the DME seeing lower rail pressure at some point, compensates with throttle closures.
      11-22-2020, 01:35 AM   #1653
cxmplex
Drives: 2018 340i GT
'18 340ix GT, AA Catted DP, BMS Intake
MHD Stage 2 E30 & xHP Stage 3
5th gear pull
https://datazap.me/u/cxmplex/b58-f34...-45&solo=12-13
4th gear pull (afr is everywhere on this one prior to flooring it?)
2018 BMW 340i GT | BMS Intake | Autowerke Catted DP | MHD E40 Mix Stage 2+ Tune | FX-150 HPFP
      11-25-2020, 03:15 AM   #1654
eluded
2JZ-GTE
eluded's Avatar
Bulgaria
3032
Drives: 340 6MT, 50e, others
Originally Posted by 340iNL View Post
everything looks ok IMO except cyl 1
What's up with cylinder number one? Mine does the same thing.
      11-26-2020, 04:32 AM   #1655
N420i
Drives: 2016 420i lightly modded
A "feature" of these engines...cyl1 tends to be the one pulling the most timing. I've read some say that the PCV vents right over cyl1 which causes it to pull timing more than the others, but I haven't read a definitive anwer.
      11-26-2020, 06:43 PM   #1656
Jnat
DisplacementReplacement
Jnat's Avatar
406
Drives: 2020 X3M
I see the same thing, cylinder one first to pull timing most of the time, even in some not wide open throttle situations. Pcv, is that the consensus?
2020 X3M /// MHD Tune
Prior Bimmers
2017 240XI Hybrid / FBO / MHD E40
2015 235XI FBO / MHD E30
2009 335XI FBO / COBB / E30
      11-27-2020, 06:05 PM   #1657
Tkent818
Drives: 2018 340i
Can you guys take a look please
https://www.bootmod3.net/log?id=5fc1...729b348f4a37ae
I went back to the 91 stage 2 map because of winter blend e85 but just swapped back to stage 2 e30. Been having some real issues with the OBD2 to enet with the lightning cable adapter. It works when it wants to, it's really weird so I hope I captured the log, I'm not sure. Car is feeling a lot less powerful and the other night sitting with the heater on during idle it started making a weird noise and I was getting some smoke and it turned itself off, just dropped RPM's and died. I limped it home and it's been fine since but the power hasn't felt the same. Let me know if you guys need another log. Thanks
2012 335is-stage 2 plus VTT turbos, catless, DCI, stage 2 LPFP, 2 inch inlets and outlets, VRSF CP with Tial BOV, VRSF 7.5 inch race intercooler, 3.5 bar map sensor, RB PCV valve
      11-28-2020, 08:15 PM   #1658
shovell242
Drives: 2017 M240i
STFT is very high throughout the rev range, could be a vacuum leak as it's positive. Maybe inspect your aftermarket intake?
      11-28-2020, 08:28 PM   #1659
Tkent818
Drives: 2018 340i
Ok thanks man I'll definitely check it. What happens if there is a vacuum leak? The DME adds more fuel to compensate for more air? STFT is short term fuel trim, correct?
      11-29-2020, 02:16 PM   #1660
Ifellapart
Ifellapart's Avatar
57
Drives: BMW 340i
I just purchased bootmod3 and will be going stage 1 soon, but wanted to datalog my car before I even cracked the DME.
This is a completely stock car, aside from the MPPSK.
https://www.bootmod3.net/log?id=5fc3...729b17859a820e
also I forgot to log the timing corrections, ill get out and do another run in the afternoon.
2016 340i / M-Sport / Track Handling Package / MPPSK / AA DP / CTS Intake / Bootmod3 e30
      11-29-2020, 06:18 PM   #1661
Mr. 340
Drives: 2016 BMW 340i
Greetings,
I am still learning how to read and understand logs, I know some basic stuff but would like to know someone else's opinion on how my engine is performing.
Got a Bootmod3 OTS Stage 2 91 oct map with a small meth nozzle. In my country my gas sucks, they claim it's 91 octane but in reality they say it's like 90 or 89 oct so instead of running the 91acn map I run the 91oct map with a 50/50 meth injection.
https://www.bootmod3.net/log?id=5fb0...729b6940614f8e
Here is one log with no meth. Same OTS 91oct map.
https://www.bootmod3.net/log?id=5fb0...90c668ff8168e0
Thanks!
AFE Filter | BMS Intake Pipe
CTS DP | CTS CP | CTS Heat Exchanger
PTP Turbo Blanket | AEM WMI Kit | Custom Exhaust
PJ ACN91 + Meth tune| XHP Stage 3
      11-29-2020, 08:04 PM   #1662
jackstrath
Scotland
659
Drives: 16' F31 340i & 03' Focus RS
Originally Posted by Alan340 View Post
Greetings,
Thanks!
Im no expert but the meth log is better as you'd expect.
The no meth log does have a knock count which in turn looks to pull timing from cyl 6.
Its your car at the end of the day but knock isnt good, if your always running meth not an issue i guess.
      11-29-2020, 09:05 PM   #1663
Mr. 340
Oh wow I did not see that. And yes, I do run meth all the time, I just did that one no meth run to see the difference with and without it. Thank you for pointing that out!
      11-30-2020, 11:17 AM   #1664
Ifellapart
Ifellapart's Avatar
57
Drives: BMW 340i
Another run with just MPPSK:
https://www.bootmod3.net/log?id=5fc4...90c66f39291361
this is one is after I went stage 1 ACN. The log looks fairly clean at least to me...I wonder if I can push it a bit and go for the "regular" stage 1.
https://www.bootmod3.net/log?id=5fc5...729b7b06af3c74
      12-23-2020, 08:17 PM   #1665
citrinblack340i
Drives: 2018 340i
Could someone please take a look at the below logs? This is on BM3's stage 2+ E30 OTS map in 3rd gear. Other mods are TU pump, catless downpipe, and XHP stage 3.
Timing seems to be all over the place. Could this mean it's time to replace spark plugs? The current plugs have about 21k miles on them. The car has not thrown any codes.
https://www.bootmod3.net/log?id=5fe3...0b431a1b66a599
https://www.bootmod3.net/log?id=5fe3...90c67d0648b37f
      12-24-2020, 04:46 AM   #1666
tpoddar
Drives: BMW 320i B48
Your logs on the MPPSK look extremely unhealthy timing wise. The 91ACN log is much cleaner although not perfect. I would recommend that you try and get better quality fuel.
      12-26-2020, 10:44 PM   #1667
Wannarace
Drives: E90 artic metallic
I have a m240i car doesn’t feel right bm3 ots stage 2+ 93oct with a stage 1 hpfp and catless downpipe 3rd gear log https://www.bootmod3.net/log?id=5fe8...90c67c6b3669a1
      12-27-2020, 12:27 AM   #1668
shovell242
Drives: 2017 M240i
Short term fuel trim (STFT) seems a bit high and your timing is shitty, probably just some bad gas.
      12-30-2020, 07:22 AM   #1669
enemigo13
Drives: F32 LCI 440xi citrineblack
stage2 + B58TU hpfp :
https://datazap.me/u/enemigo/f30-340...14-15-17-18-19
      01-01-2021, 07:37 AM   #1670
SlowMo
Drives: E90 N54 and E36 M52B28
340i rwd
MHD stage2+ Hpfp
TU pump
catless dp
XHP stage 3
~E50
HIGH altitude (+- 6000ft)
Very hot (32 degC)
if turbo is not maxed out here, then i don't know what is
Please can you take a look.
is the turbo being choked? would i benefit from an intake since its high altitude?
https://datazap.me/u/slowmo/340istg2...data=3-6-17-34
      01-02-2021, 10:30 AM   #1671
Jnat
Jnat's Avatar
406
Drives: 2020 X3M
Is there a consensus with which is the stronger MHD map, stg2 95 or stg2 e30 (not the hpfp maps)? Looking at logs and feedback in this thread i'm not seeing it other then the 1 lb difference in boost + with the 95... thoughts???
Prior Bimmers
      01-02-2021, 08:38 PM   #1672
Cobra358
Drives: bmw 335i
I would change plugs to be safe, but I am not sure that is the issue. I have the same set up as you and I would get timing pull and erratic timing running E30. I am running E37 now and my timing is clean. I would try E35-E40 and see if the timing cleans up. Good luck!
