07-03-2018, 12:38 PM | #1 |
Rep 60
Being paranoid about swirls...
I was using the Turtle Wax Max Power Car Wash from Costco with a microfiber towel to wash my brand new 530e, but then I realized it left with some swirls... I should have realized this car wash might be too tough on metallic paint. Then, I tried waxing and polishing (Meguiar's Ultimate Polish) off the swirls, but they don't seem to work. Is it normal to have swirls after car wash? How do I remove the swirls or do I have to take it to a body shop? Thanks a lot!
EDIT: How do I properly wash my car without making swirls and scratches? Last edited by boonkgang13k; 07-03-2018 at 10:53 PM.. |
07-03-2018, 12:57 PM | #2 | |
Rep 415
Drives: 2019 440i Coupe
Washing should be done with a microfiber or lambswool mitt. Also, when it comes to drying, not all microfiber towels are created equal. You might want to read some threads in the detailing forum here or check out the guides on Autogeek.net |
07-03-2018, 01:13 PM | #3 |
Rep 16
If they are minor swirls, just take a polisher to polish it off. I also like to use waffle weave microfiber towels and use the blotting technique to my car.
07-03-2018, 01:22 PM | #4 | |
434
Rep 884
The ultimate polish should take off light swirls. |
07-03-2018, 01:27 PM | #5 | |
Rep 63
07-03-2018, 02:20 PM | #7 |
Rep 1,043
Decent car wash soap generally doesn't damage paint. Although I've heard stay away from Turtle Wax as their products aren't ph neutral. There's an issue with your regimen.
What type of MF towels are you using? Did you remove the tag if it has one? Did you prerinse before actual wash? Did you properly rinse the towel to not drag dirt? If you're waxing and polishing, which did you apply first? Before attempting to polish, did you properly remove your sacrificial layers of paint protection to get a proper correction? |
07-03-2018, 03:00 PM | #8 |
Rep 1,358
Drives: 981CS/428/is250/JLU Rubicon
That what I love about Alpine White...it has swirls I’m sure, but you can’t see them
BennyJones23.50 |
07-03-2018, 03:10 PM | #9 |
25cent millionaire
252
Rep 1,219
Drives: 2020 m4 comp vert
if you see swirl marks after a wash in one spot they are all over the car.. how anal are you about the look of the paint.. at this point I would go over the whole car with a heavy polish like grups, start with the trunk lid.. see if it helps, if that works then due the rest of the car... if swirls are still there, step up to a rupes 2500 cut. this will take out light swirls, Then you will have to polish, then wax.... welcome to being insane about paint.. lol... great car by the way...
07-03-2018, 04:04 PM | #10 |
Rep 1,678
Drives: 2014 428i and 2018 X5
Stop drying with towels. Blow dry it with a leaf blower. An electric blower is cheap and can reach wind speeds of over 200mph. Your car will be dry in no time.
07-03-2018, 06:28 PM | #11 | |
Rep 10,473
Just finished washing and drying using this method an hour ago. |
07-03-2018, 06:47 PM | #12 | |
Rep 63
I've been washing my cars exclusively with Optimum No Rinse Wash & Wax, single bucket, and quality mf towels. https://www.amazon.com/OPT-Optimum-N.../dp/B00GG9FB8U https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 OR https://www.amazon.com/Chemical-Guys...uys+microfiber Wash a section at a time and spray this on before drying. http://opti-coat.net/opts/hyper-seal No scratches, no fancy equipment. |
07-03-2018, 06:49 PM | #13 | ||
Rep 10,473
07-03-2018, 06:53 PM | #14 |
Rep 63
kikcaffine46.50 |
07-03-2018, 06:55 PM | #15 | |
Rep 10,473
A foam cannon without 2000 PSI and a really high amount of water per minute will not clean your car. Even the foam cannon manufacturers admit that. Last edited by IK6SPEED; 07-03-2018 at 07:00 PM.. |
07-03-2018, 06:59 PM | #16 |
Rep 63
To answer the OP's question, to remove swirls, your best bet is to use something link a DA polisher. The Porter Cable 7424xp is a good budget option. From there you need pads, polishes and/or compounds, and sealants.
If all that sounds overwhelming, pay someone to correct and seal your paint with one of the many ceramic-type coatings. Professional correction and coating is expensive though. Be prepared to spend up to $1k or more for that type of work. Honestly though, if it's something you're interested in doing yourself, it's not rocket science and I can provide you a list of supplies you'd need to do it yourself. |
07-03-2018, 07:01 PM | #17 |
Rep 63
2800psi pressure washer. Touchless washes are a myth. Sorry bud.
07-03-2018, 07:02 PM | #18 |
Rep 10,473
07-03-2018, 07:09 PM | #19 | |
Rep 63
I use it as a pre-rinse during the winter when the salt comes out. I'm certainly not going to bust it out each time I wash. Mostly because it's less effective than a proper bucket wash. |
07-03-2018, 07:35 PM | #21 | ||
Rep 10,473
07-03-2018, 07:41 PM | #22 |
Rep 12
Lots of options for minimizing swirls. Some swear by rinseless washes and others use a 2 bucket approach. Foam cannons, quality wash mitz, microfiber towels, etc. Generally, swirls or light scratches will happen over time. I think owning a DA with good product and pads will help deal with these issues and good tools to have in order to detail your car.
