BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N47 and N57 Turbodiesel Engine / Drivetrain / Exhaust Modifications > 328d Problems with Swirl Flap Actuator
      04-22-2024, 09:21 PM   #1
darkmagic
Drives: F31 328d
I'm having 2 codes;
2C3200 Swirl flap, plausibility: Mechanically defective (lever break detection)
264100 Swirl flap actuator position sensor, signal: interruption or short circuit to ground.
A little background story is: I was doing the valve cover gasket and removed the intake in the process. I had already cleaned it the previous time I took it off and cleaned all the gunk, so the swirl flaps were functioning properly. When I put everything back together, these codes popped out.
I checked the wire going to the swirl flap actuator and it seems like it's not getting enough power. ISTA says the voltage should be between 5V-9.5V, and I'm getting only 14mV to the wire. However, it randomly got 5V once, stayed for about a minute and went back down to 14mV. Also, when I try to reset the error codes, 2C3200 code doesn't go away, which is usually a case when something is unplugged or there is an electrical issue. Is there anyone know what might be the cause of this problem? Any help is appreciated.
