05-08-2024, 10:06 AM | #1 |
Rep 18
Confusion over ZF8 servicing
I’m taking my 340i F31 to Foxtails near Faringdon, who have a good reputation with BMW work and have been recommended to me by friends. I asked for a transmission fluid service because the car is up to 75k miles now, and they recommended a full flush (ie over 8L of oil) and a chemical cleaning of the pan filter. This is at odds with what I was expecting and had seen online, which was 1-1.2L of oil with a pan change. They explained that as long as there hasn’t been any mechanical wear, or metal filings found in the filter, cleaning them and refitting is perfectly fine. I’m hesitant to say they’re wrong based on my internet searching, but have seen many people saying that a full fluid flush is not a good idea. Who’s right? Help!!
For context my driving has been largely motorway miles, with some day trips into town a couple of times a week, but much of the mileage is easy on the trans. |
05-08-2024, 10:11 AM | #2 |
Rep 8,641
ZF specifically advises against fluid flushes - I know, because I discussed it with ZF Technical personally.
The torque converter holds a significant amount of fluid, therefore, the fluid needs to be changed 2-3 times (with the car driven between each change) to make sure that as much of the old fluid is diluted away as possible. The pan should always be replaced when the fluid is changed.
danb19792316.50 fortythirtyfive690.00 |
05-08-2024, 10:41 AM | #3 |
2317
Rep 2,497
As above; it just needs to be a fluid change & new filter
No flushing needed/required
05-08-2024, 11:09 AM | #4 | |
Rep 18
05-08-2024, 11:39 AM | #5 | |
Rep 8,641
As for whether the labour / effort / cost is worth it, that’s subjective but in my mind it’s a clear yes. Never trust BMW’s Sealed For Life” BS. ZF recommends fluid changes in these units at 60K mile intervals.
05-10-2024, 02:31 AM | #6 |
Rep 1,467
It sounds like they are more used to working with older traditional slush boxes. The ZF8 was designed to be low maintenance and easy to service, so literally all they need to do is follow the instructions included in the ZF service kit and they can't go wrong.
danb19792316.50 |
05-10-2024, 12:10 PM | #7 |
Old Fart
364
Rep 701
Tbh I wouldn't go near them if they say clean the filter. It's a one time use and a new one comes with oil as a kit. Find someone else to work on your expensive gearbox.
The doctors said it's OK to listen to the voices..... just don't do what they tell me
danb19792316.50 jackstrath663.50 |
05-14-2024, 09:28 AM | #8 |
Rep 203
If it helps I had mine done on Saturday, using genuine ZF filter/sump with 5L of genuine ZF oil for £152.
There was nothing wrong with the car or how it drove but after having F series cars on and off for ten years and having never serviced a ZF box before I regret not doing it to every car, the car drives so differently now it has become by far my most favourite 'mod' . . |
danb19792316.50 |
05-14-2024, 10:54 AM | #9 | |
Rep 525
ZF8 gearbox servicing
danb19792316.50 |
05-14-2024, 01:55 PM | #10 | |
Rep 203
A good friend of mine is a mechanic at a Garage in East Barnet, he will look after you if you would like to get it done. |
05-15-2024, 02:51 AM | #11 |
Rep 525
ZF8 gearbox
Yodi, if you can give me your friends details, I'll give them a call, though East Barnet from where I am in Harrow is about 40minutes and my car is going in to the dealer next week for a service and I will ask them for a cost.
