BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Retapping stripped threads on wheels
      11-02-2020, 06:49 PM   #23
dkreidel
dkreidel's Avatar
Drives: a lot of BMW's
If it were my car I'd try chasing the threads with a good bottoming tap, but if that didn't work I'd install Timeserts - I would not use helicoils on this application.
2020 X3 M40 Alpine White over Cognac • 20" BBS CC-R • Cerium delete
2017 440xi Estoril over Saddle Brown • 6-speed • Every stinkin' option
      11-02-2020, 08:25 PM   #24
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
I don't see why you'd want to use any type of insert. You'd have to tap the hub to a 16mm thread, so just use a 16mm bolt.
      11-02-2020, 08:38 PM   #25
jackstrath
Scotland
659
Drives: 16' F31 340i & 03' Focus RS
That would work on anything bar hubs, Wouldnt the wheels then need to be drilled out? You'd then have to jump up a socket size, is there room for a bigger socket in the standard wheel holes?
Replace all the hubs is the ideal solution, Thread chaser is next best thing if it was only 1 hole. Next would be to weld and re drill and tap the flange and then lastly a timesert.
Potentually expensive mistake forsure!
      11-03-2020, 11:02 AM   #26
jsouth
jsouth's Avatar
Drives: 2013 328i
I still want to know how this happened. What in hell were you using to tighten the lug bolts? I'm skeptical.
      11-03-2020, 03:24 PM   #27
BWbimmer
BWbimmer's Avatar
Drives: BMW F36, E36, E93
Didn't you read the whole thread?
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required
      11-04-2020, 06:56 AM   #28
diydoc
Drives: '19 G06 X6, '17 F30 335i
In addition to the centering ring, the lugs also play a role in centering the rim. I wouldn't mess with retapping/helicoils, you will never reach the level of precision needed to avoid vibration. Replace the hubs. Easy DIY with a hub+bearing puller.
Wires1645.50
      11-04-2020, 10:50 AM   #29
BWbimmer
BWbimmer's Avatar
Easy DIY? Hmm. Maybe at the front but you should be good with cars starting at the back. Especially with the tools needed
Such Fun
      11-04-2020, 03:00 PM   #30
diydoc
The process at the back is pretty much the same if you don't try to save the bearing. Just pull at the flange and replace the bearing. The output shaft simply slides out.
The better the tools, the less time and physical force will be required.. though this job is gonna require a fair amount of force in any case
      11-04-2020, 04:56 PM   #31
jsouth
jsouth's Avatar
Drives: 2013 328i
Actually, yes. But I missed the post about putting in the wrong lug bolt.
      11-04-2020, 06:10 PM   #32
CJKaz
Drives: 2021 X3, 1998 MB SL500
Betting not many of those who’ve replied have ever used helicoils. Widely used in many critical applications, including wheel hubs:
https://blog.fcpeuro.com/how-to-repa...ith-a-helicoil
Thoroughly clean the cutting oil out of the newly tapped holes. Apply red Loctite and let it cure. Light coat of oil on the studs to ensure they don’t contact/lock-up with the Loctite.
      11-10-2020, 05:25 AM   #33
Moffo
Drives: 2017 BMW 440i
Went to a shop, they explained that the whole were completely stripped. Probably just going to purchase new hubs and install them. Will try to do the fronts myself but if the rears are too difficult then I'll have a shop do them. Thanks for all the replies guys!
      11-10-2020, 05:59 AM   #34
BWbimmer
BWbimmer's Avatar
That's a shame...
And you didn't notice that the bolts went is very heavy in the first palce?
Have a look at FCP Euro maybe you find the manufacturer of the hub and get them cheaper?
Such Fun
      12-10-2020, 11:57 AM   #35
BWbimmer
BWbimmer's Avatar
did you replace your hubs?
Such Fun
