BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > 435d xdrive on square setup 400m alloys
      11-08-2021, 11:05 AM   #1
eyespider
Drives: bmw 435d xdrive convertible,
Hi I planned to get a cheap set of alloys for winter so I could get my factory fit alloys refurbed over the winter.
I was thinking M Star-Spoke 400 - 18'' 36117845880
Is it ok to get 4x 8JX18 ET:34 and put 225/40/18's on them? (I've had dunlop winter sport in the past)
Its a F33 435d xdrive
regards
      11-08-2021, 11:24 AM   #2
alohasurftoad
Originally Posted by eyespider View Post
I was thinking M Star-Spoke 400 - 18'' 36117845880 Is it ok to get 4x 8JX18 ET:34 and put 225/40/18's on them? (I've had dunlop winter sport in the past)Its a F33 435d xdrive regards
OEM tire diameter is 26"...225/40/18 is 25.1" and it's smaller diameter and sidewall will cause speedo read to higher than actual, accrue more mileage than actual and further increase the unsightly x-drive wheel gap. if these shortcomings do not bother you post some pics after it's installed.
personally, i'd get 235/45/18 like this...
https://f30.bimmerpost.com/forums/sh...+235%2F45%2F18
and this
https://f30.bimmerpost.com/forums/sh...6&postcount=19
or 225/45/18, which is OEM F3/4 front or square tire size
      11-08-2021, 11:56 AM   #3
eyespider
Hi thanks for replay
ideally I don't want any discrepancies on the speedo or odo,
so 225/45/18 or 235/45/18 will be fine for all four alloys?
As I'd like to be able to swap the fronts and backs periodically to even wear.
regards
      11-08-2021, 12:10 PM   #4
alohasurftoad
ideally I don't want any discrepancies on the speedo or odo, so 225/45/18 or 235/45/18. will be fine for all four alloys? As I'd like to be able to swap the fronts and backs periodically to even wear.
regards
225/45/18 is the standard OEM tire size BMW installes on 18x8 ET34 400M square setup.
as shown in the links in my previous post. 235/45/18(26.3") fits better on 18x8, provides 10mm more tread width, comfy ride, impact protection and reduces some of the unsightly x-drive wheel gap, without any problems.
      11-08-2021, 01:07 PM   #5
eyespider
many thanks you've been very helpful
kind regards
36117845880, 400m, alloys, f33 4 series, square set up, winter tyres
