08-03-2020, 09:30 PM | #45 |
Rep 1,065
you need to verify the back of the front 4 piston front calipers to ensure it states the following:
380/370mm the rear two piston brembo calipers are all the same M Sport across all lines (235i/335i/340i/M2/M3/M4) I did the conversion as well: Last edited by sqwinny; 08-03-2020 at 10:36 PM.. |
08-03-2020, 09:33 PM | #46 |
Rep 1,065
Please read the back. the "caliper is the same as well as the pads" however the mounts are different (longer, look and compare the amount of metal from caliper to bolt holes) from the m235i compared to the m3/m4. This allows for a different sized rotor to be installed.
340mm caliper (pistons, pads and surface area) are the same as the M-Sport package but not M Sport Performance Package which allows for a larger rotor. It's clearly marked and I hope whoever searches for this in the future understands this marking to not get mixed up. rear of M Sport calipers stamped for 340mm taken from the linked eBay listing previously: rear of M3/M4 stamped for 370/380mm: Last edited by sqwinny; 08-03-2020 at 10:54 PM.. |
08-03-2020, 10:58 PM | #48 | |
Rep 1,934
As I said the listing is wrong about M3/M4 applications just for the front. They technically WPULD still bost on, but you'd need custom sized rotors at 350mm (340+10). Brake bias would also be effected. Anyway good luck op.
08-03-2020, 11:10 PM | #49 | |
Rep 1,065
08-03-2020, 11:30 PM | #50 | ||
Rep 1,934
09-30-2020, 10:46 AM | #52 |
Rep 1,065
10-17-2020, 02:37 AM | #54 | |
Rep 126
https://f30.bimmerpost.com/forums/sh...4&postcount=23 |
10-17-2020, 08:46 AM | #55 | |
Moto Lover
187
Rep 591
Drives: '19 BMW S1000XR
Just waiting on rotors and I’ll be set! |
10-17-2020, 09:59 AM | #56 | ||
Rep 1,119
Drives: 2015 BMW 435i Xdrive MSport
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
10-17-2020, 06:21 PM | #57 |
Moto Lover
187
Rep 591
I understand. But what I was asking is when switching to the M3/M4 brakes (same as M performance), can I use the backing plates from my silver brake setup or if I need to swap them out. Based on his video and part #, I should be fine and not need to swap the backing plates.
10-17-2020, 06:35 PM | #58 |
Rep 3,022
Drives: 2019 M2 Competition
I didn't change the backing plates. Just calipers and rotors
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
itsrichierich186.50 |
10-17-2020, 10:53 PM | #59 | |
Rep 1,119
10-19-2020, 02:40 AM | #60 |
Great Teacher
1088
Rep 1,305
Drives: 06 e91 325ix
Depends. All iX have the big bearing aka big parking brake aka big backing plate.
So do ePost 07/2014 rwd. It’s only the pre July 2014, small engine, rwd, non convertible ones you have to worry about. If you check real OEM and have the small rear parking brake then you might need the larger Backing plate. If you don’t, then you don’t. Badabing babda boom .
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
Boostedphil698438.00 Alpine-F80200.50 |
11-30-2021, 01:21 PM | #61 |
Rep 9
Bringing this back from the dead here .
Anyone know if the rear carriers/hubs from the F80/F82 M3/M4 will work on the F30/F31 chassis with the larger rear parking brakes already equipped? Doing M5 front calipers w/ 400mm M2 Comp rotors, and would like to try and upgrade to the large M2/M3/M3 drilled 370mm rotors. I understand I can use the blue msport rear calipers as they are, since they are the same caliper as the m3/m4, just that the caliper mounting point on the carrier/hub is what allows you to run the larger rotor on the M2/M3/M4. I'm just unsure if the control arms and axle size differ between an Xdrive f30/f31 and the m3/m4 which would be the initial concerns as far as fitment goes. If anyone else sees issues with fitment do to other items I'm not considering I'm all ears. It seems the rear carriers for M3/M4 are pretty inexpensive on ebay. |
09-02-2022, 12:01 PM | #62 |
Rep 59
Just reviving an old thread hopefully i can get more info on the rears.
I did the 370mm 345mm non M upgrade. Now i want to do the full M upfrade for the brakes. I found the company with the brackets to make it happen but its only for the front. Anyone have info how to make the M 2 piece rotor fit in the rear? https://www.seemslegitgarage.com/pro...-big-brake-kit |
05-29-2023, 11:46 AM | #63 |
Rep 1,370
I found this screenshot on BimmerWorld that explains all the variations. I'd say there is a typo there. Is there a Blue 1-piston Brembo?
https://www.bimmerworld.com/About-Us...-Sport-Brakes/ While I can see the bolt holes matching I am concerned by the fact that the F8X rear rotors are 370mm. If that's the case doesn't it mean the caliper has to be set back by 25mm compared with the M-performance rear caliper meant to handle a 345mm rotor? It seems if a 345 mm rotor is mounted, the F8X rear caliper brake pads won't fully clamp onto the smaller rotor. It seems it would only clamp onto a part of it.
05-30-2023, 09:43 PM | #64 | |
Rep 1,370
05-31-2023, 08:51 AM | #65 | |
Car Hypochondriac
335
Rep 901
The bolt holes for the rear calipers are further inward on the F3X hubs than on the F8X. This is why they work with the smaller rotors.
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327 Last edited by Eschmacher; 05-31-2023 at 09:03 AM.. |
06-04-2023, 08:50 AM | #66 | |
Rep 1,370
As for parts, I noticed that on the pre-LCI M3 (up to 2015) the left and right part numbers are 34216799461 and 34216799462, the same as on S2NHA optioned cars. On LCI cars, the part number are 34218046261 and 34218046262. Clearly there was a change but what did not change was the rear rotors on both pre-LCI and LCI cars were 370mm. How could the pre-LCI cars use 34216799461 and 34216799462 on 370mm rotors? BMW would have to change the location of the bolt holes, as you mentioned. Wonder what the differences are between 34216799461 and 34216799462 vs 34218046261 and 34218046262?
