06-11-2019, 07:24 AM | #23 | |
poopycat
266
Rep 791
Mr Podman220.50 |
06-11-2019, 07:31 AM | #24 |
Rep 15,858
Similar thoughts when looking at the image. Why the chewed up belt? The application couldn't be simpler, I sense some sort of overload, or something else contributing to the failure.
06-11-2019, 07:33 AM | #25 |
poopycat
266
Rep 791
I've seen belts fail before, that IS a possibility, but the great explanation is that there's something physical that's out of spec.... if there's even a spec.
06-11-2019, 08:11 AM | #26 |
Father of Frankenfold
299
Rep 531
Drives: Yo daddy's 2014 X3 M Sport
You can find remanufactured racks for around $1000. Look on rockauto.com. If they're out of stock, search the part numbers they list and see who has them in stock.
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
Mr Podman220.50 |
06-11-2019, 11:10 AM | #28 | ||
Rep 10,473
Realoem lists as a Sport/TKP so suspect you are correct. Had already sent an email to them overnight. Last edited by IK6SPEED; 06-11-2019 at 01:01 PM.. |
06-11-2019, 01:30 PM | #29 | ||||||
Rep 134
IK6SPEED4490.00 |
06-11-2019, 02:02 PM | #30 | |
Rep 10,473
Why send me info on where to find a $25 belt when they can sell someone a $3000 part instead. They have confirmed to me the email is in support. We shall see. |
06-11-2019, 05:32 PM | #31 |
Rep 5,457
Drives: F30
Can't believe no one checked eBay. Is this a joke?
https://rover.ebay.com/rover/0/0/0?m...2F183752371716 M |
Poochie9104.50 |
06-11-2019, 05:34 PM | #32 | |
Rep 10,473
06-11-2019, 05:47 PM | #33 | ||
Rep 5,457
Drives: F30
What about this one? https://rover.ebay.com/rover/0/0/0?m...2F254156484710 Wonder if the ones listed out of Russia or Ukraine are any better? You could ask sellers for measurements... Id be shocked if all four sellers have the wrong belt. That has to be very unlikely. |
06-11-2019, 05:52 PM | #34 | |||
Rep 10,473
If you look how many different part numbers there are on realoem between diagram 1 and 12....VSS and non-VSS...and then part numbers that are RHD only of the above, clearly the same belts were not used in all. Look below....this is list of part numbers from only 3 different models of F30 335i. By my rough count eliminating dupes that's roughly 75 different parts. No telling how many more exist when all F3x models are considered. Thus it's an absolute crap shot....and clearly the sellers are unaware which fits what. But it's clear, one size does not fit all. |
06-11-2019, 09:39 PM | #35 |
Rep 526
Once new one is installed you can code with ESYS and then run some procedures with ISTA D. You need to import a FSC code for the EPS.
This is what i've been told. |
06-12-2019, 11:25 AM | #36 | ||||||||
Rep 134
Can you get the last 6 digits of the VIN to check which is required? |
06-12-2019, 11:59 AM | #37 |
Dr. BK 2010 E92 328i
Rep 20
I think your best bet in deciding what best approach to use would be examine the snapped belt. That can give you an indication of what happened. if the different covers are bad then dirt goes in there and may be affected the teeth of the ratchet or may be the ratchet thing moves. Luckily and unluckily I am in Africa. I have been to a workshop where they dismantled the entire rack to pieces and I saw the parts you are talking about. that entire work wont cost more than a 100 dollars here. the unlucky part is we dont get good spare parts. So in truth, the belt from a used rack will not be a bad idea, and if the components in there are fine, the used belt can last years. Instead of the US. let me recommend you check silverlake autos. based in the UK for salvage cars. you might get your rack way cheaper
Dr. BK
2012 335i F30 Previous E92 325i |
IK6SPEED4490.00 |
06-12-2019, 12:02 PM | #38 | |||||||||
Rep 10,473
Again, as proven from the eBay purchase, just because a seller claims it fits a F30 unit, doesn't mean it fits ALL 75+ F30 parts. As for the Car Vin, the results with the VIN show 13 different parts that would work in the car. However due to the 9/12 date, the part in the car is most likely the first one that ended 11/12 - 32106859250. Unfortunately, knowing that does not get this car....or anyone on Bimmerpost, closer to a replacement belt instead of a $3000+ repair. |
06-12-2019, 12:55 PM | #39 | ||||||||||||||||||||
Rep 134
But if you go BMW they will fit the superceeded version |
06-12-2019, 02:14 PM | #40 | |||||||||||||||||||||
Rep 10,473
But as parts are used in the different BMW plants, it was easy on this build as it was one of the first F30's to identify the first part number. But for all F30 owners built after 11/2012, the odds of correctly identifying which part is in vehicle without visual inspection decreases dramatically. And bottom line, it still does not help finding a replacement belt for anyone's steering rack as eBay purchase proves there are different belts in different part numbers. |
06-12-2019, 03:01 PM | #41 | ||||||||||||||||||||||||||||||||||||||||||||
Rep 134
Out of curiosity have you measured the length and width of the belt then contacted Ebay sellers to see if any match? |
06-17-2019, 12:00 AM | #42 |
Rep 10,473
Circling back around to this.
Spent several days with Gates in Denver investigating the QR Codes and the numbers on the belt. The numbers lineup with nothing they offer. The suspect it's a EU OEM special manufactured belt that they do not sell in their non-OEM channels. And of course OEM is TKP in this case - not BMW. So yes, a $3000 part is needed to replace a $20 belt on a steering rack. |
06-17-2019, 01:38 AM | #43 | |
Rep 776
...Though I have a 0% chance believing you can't find and adapt a used rack out of UK or other rhd spec area for a fraction of that. Key would be knowing the collision it came from. |
06-17-2019, 11:01 AM | #44 | ||
Rep 10,473
I would also note the steering rack that has been on the car since it came out of the factory is not even listed among the 75+ variations associated with the F30 in realoem.com In fact the sequence of the steering racks have no designation for any BMW models in realoem. Obviously this deepens the mystery even more....and makes a replacement more questionable and not as straight forward as you suggest for a part that has to go air freight half way across the globe. https://www.realoem.com/bmw/enUS/partxref?q=32106859302 or even the most recent in this sequence https://www.realoem.com/bmw/enUS/partxref?q=32106868887 (see below) |
