08-19-2022, 03:31 PM | #46 |
Rep 7,607
08-19-2022, 08:53 PM | #47 |
Rep 4
Ill try to find it. In my case that seems unlikely, I've smoke tested everything and found no leaks. Engine ran perfect but had a permanent 133E10 valvetronic system deactivated code. Replaced the Valvetronic motor first, issue was still present, replaced the Eccentric shaft next, same issue. Engine still ran and idled fine after these repairs but still had the valvetronic code. Determined my DME to at fault. Replaced the DME, was then able to clear the 133E10 fault and perform the valvetronic adaptation / run in process. After this I now get the 101F01 intake absolute pressure too high code as soon as I start the engine, followed by a very rough idle.
11-09-2022, 03:10 PM | #48 |
Rep 2
Hello there does the problem persist? If it is solved, can you tell me how it was solved? I have the same problem for 1 year and the engine is vibrating excessively. you tried all the ways like you but it still continues
04-17-2023, 11:11 PM | #49 |
Rep 11
Hi guys, I was really excited following audi01 and Karolx80 exchange in this thread, because I am having the same code and the same issue, however, it was really sad to reach the end of the thread and find no final update from Karol.
While Audi's final update gives me hope to find a leak somewhere causing this, I've gotten kind of frustrated after several smoke tests that show nothing, however, his logic about it being a leak and not something else makes a lot of sense to me, besides, I remember hearing a wistle coming from the engine bay at the exact same time I got the valvetronic system deactivation error. In any case, I've found quite a few posts online related to this, but most of them are just abandoned without a final update or have updates that do not make sense to me. If anyone has information that may help me and many others with the same issue, please do share them and I will make sure to spread them around other forums, sites and facebook groups, to make sure that something as common as this, does not become a money pit of unneccesary part swaps. Thanks! |
04-22-2023, 04:57 PM | #50 |
Rep 14
If you hear a whistle, I suggest to check your crankshaft gasket.
You can also check by removing oil cap and doing smoke test through oil filler hole. Check around crank pulley for any smoke |
04-28-2023, 07:30 AM | #51 | |
Rep 26
DME active codes - 101F01 - Air mass system, plausibility: calculated air volumes in air intake system implausible. 1F0525 - DME, internal fault, safety function: Plausibility check, relative fuel mass. Car idles fine and starts fine too on cold starts. Heres my symptoms: When i WOT the car or push the car to around 4-6k RPM, then suddenly I lose power as if something stops me. Then it just barley pushes at all almost like limp mode. I then get drivetrain malfunction. I then park while limping slowly then turn car off then back on and it runs fine again until i push car hard again then it happens again. Ever heard of these symptoms? Seem like something is stopping my car from going too crazy and turns off power for safety or something |
05-22-2023, 11:57 AM | #52 | |
Rep 14
Hi Did you check for vaccum leak? Like smoke testing the vehicle? After VCG replacement you mayhave a small leak somewhere now. Common place are turbo inlet and outlet, Intercooler cold and hot side connection turbo to charge pipe, and also vaccum line between charge pipe and fresh air pipe (coming from air filter box) if you drive an automatic |
06-06-2023, 02:01 PM | #53 |
Rep 6
Drives: 11' 535i 6MT, 18' 330i, 17' X5
Same Codes different car
I see you had the 101F01 and 104301 on your n55. I have these same codes just on a 2011 535i manual. I cleaned the MAP sensor, no luck, I also ordered one fro ecstuning.com and still now luck, but when I changed it, the codes switched to 101F02 and 104302, is it possible that my sensor is the issue and I just used the incorrect one?
06-15-2023, 11:20 AM | #54 | |
Rep 11
Most likely a leak
Anything related to "airmass" errors is most likely a cracked hose, either in the intake or somewhere else. In my case, these sensors were working fine but I was unable to find any obvious cracks in my smoke test, so I asked the dealer to run a second one and they found two hoses with thin cracks. For a long time I thought my Valvetronic had gone bad, but it seems that it simply deactivated itself due to the increased air pressure, as these cracks allow additional air to be sucked in. First, we reactivated the Valvetronic through ISTA+ and it worked fine, but the airmass errors popped up right away. I tried doing the adaptation procedure from this bulletin (BMW TSB SI B11 09 19) but the CEL would come back. I wanted to deactivate the Valvetronic again to prevent any damage, but I was told by the dealer that it was not possible, so I simply used to car at low revs while the new parts arrived. After changing the cracked hoses, everything is now back to normal (AT LEAST FOR NOW! ). In any case, make sure to run proper smoke tests for any 101F01 or similar codes, and then work your way through other codes from there. In fact, if you get (133B04: Valvetronic system: no adjustment possible) or (133E10: Valvetronic system: deactivated, too frequent adjustment errors), I would recommend trying to reactivate it through ISTA to see if it works and if other codes pop up afterwards like it happened to me. |
06-15-2023, 03:52 PM | #55 | |
Rep 182
06-19-2023, 07:33 PM | #56 |
Rep 11
These two were the ones in my case, but others may cause similar symptoms
06-21-2023, 12:14 AM | #57 |
Rep 182
06-24-2023, 10:38 AM | #58 | |
Rep 134
I am having the same exact issue.
My intake pipe vacuum after throttle valve is about 50 hPa different than before the throttle valve. Based on what you are saying it would appear my manifold pressure sensor needs to be replaced. I removed it (covered in oil) and cleaned it, but the readings did not change. Quote:
07-02-2023, 10:00 AM | #59 |
Rep 134
Under Idle, my pressures were correct as the throttle valve changes the pressure. However with the car off and the ignition on they read the same, which is how you can check the sensors. My 101F01 was caused by the MAF.
Happy to report I solved this code and reported 100 miles with no CEL. The culprit was a bad MAF, even though the MAF did not throw a code itself. Looked good and I cleaned it, no change. After looking at the values, the air mass would range 8-22 kg/h. I figured this could not normal, and it wasn't. New $40 aftermarket MAF on Amazon no varies 13-14 kg/h at idle and the car runs much smoother! |
08-31-2023, 07:11 AM | #62 |
Rep 14
I have this same 101F01.
No vaccum leak identified, no boost leak. Car drive fine except rough idle and intake manifold pressure at 0,91 bar (91 kPA) no matter what at idle. When I accelerate, the pressure will go 100 or more but when I take out my foot from accelerator, pressure drop back to 91. When I disconnect valvetronic motor, I have normal vaccum pressure at idle, around 38 kPa. The idle is very smooth, no misfires, no vibrations. When I accelerate with valvetronic disconnected, pressure rise to 1 bar or more and drop back to 25, 30.... Now why with valvetronic, pressure is constantly around 91 kPa even at idle? I sometimes think the valvetronic doesn't lift valve high enough and pistons are sucking very low air ( I already got low air message fault code). I read from Karolx80 and some guy with same issue replaced VVT motor and Eccentric shaft but this didn't fix the issue. Any ideas? |
09-01-2023, 12:45 PM | #63 |
Rep 134
I do not think so, but I haven't had a chance to replace it. I have the 101F01 stuck in permanent code, so it takes a few runs cycles to determine the issue. Just replaced the vanos solenoids. Doing a smoke test today..... The issue is my car is underboosting. Have the BM3 requesting 17psi and I am getting 11psi. However, no hesitation or stuttering at WOT.
09-02-2023, 05:10 AM | #64 | |
Rep 770
09-02-2023, 10:03 AM | #65 | |
Rep 134
Smoke tested the car.... no leaks. I had already gone through every connection.
I tried another boost solenoid, no change. Not sure what else to do. Blocked cat? Leaky Injector? Quote:
09-02-2023, 10:26 AM | #66 |
Rep 134
Here is a 3rd gear log: https://www.bootmod3.net/log?id=64e7...729b872c827af9
101f01, 104301 |
