BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Bimmercode app iOS/Android
      10-23-2019, 08:34 AM   #507
19bis
Drives: 2016 328i; 2018 230i
Originally Posted by swan776 View Post
Hi everyone,
Does anyone know why I can't get to the section Exper mode in Kafas block?
Stephan has not programmed expert mode for all of the ECUs. He just recently added this for ICMQL, so I could code LIM at long last.
      10-23-2019, 09:29 AM   #508
eugene89us
Drives: 2018 BMW 328d
Originally Posted by J-RO View Post
Has ANYBODY been able to code Brake Force Display and have the rear brake lights flash on a 2018 4 series? This is driving me crazy. If you have please share the procedure. Thanks.
Coding should be same as F30. Did mine last week.
Change Expert Setting FEM > 3060 > ESS_AKTIVIERBARER_AUSGANG and change the setting to: bremslicht_blinkend
This will make lights blink. Then go to REM module.
Change blink frequency to 5 times per second in regular mode REM if LED. For halogen brakes, leave 3. In REM Expert, Change in option 3062,
MAPPING_BRAKEFORCE_L_OUTPUT to BL_L
Do the same for R output by picking Bl_r. That changes blinking from fog light to brake light.
      10-23-2019, 10:22 PM   #509
2014F32435iMsport
Drives: 2014 435i Msport
Does anyone know if coding with bimmercode will reset the dinan stage 2 I have setup? Not a big deal just want to know if I will have to go in and reset the right stage tune Thank you.
      10-26-2019, 01:36 AM   #510
2014F32435iMsport
Tried it myself. All good, dinan module was not touched so the tune was still the same.
      11-01-2019, 04:53 AM   #511
Kaisah
Drives: 340i F30 LCI
2017 340i  [0.00]
So just about to dive into the world of Bimmercode on my new 340i... read a few horror stories about it wiping peoples iDrive/Nav etc.. I only want to code a few basics such as start/stop memory and radio turning off when I open the door. Should this be fairly low risk?
      11-01-2019, 07:34 AM   #512
19bis
Coding in normal mode (all you need for the basics you describe) should not present any problems. Once you get into expert mode, you are confronted with lots and lots of parameters with cryptic names and unclear functions. Messing with these can have some unintended consequences - like when I changed my nav voice from American to British English and started getting traffic condition reports in Indonesian. Best to stick to what has been vetted in the cheat sheets available. And keep a log of what you have changed - so that you can undo changes that did not work as desired or so you can redo your coding when it gets wiped out by a dealer software update.
Kaisah71.50
      11-08-2019, 01:42 PM   #513
Kaisah
2017 340i  [0.00]
Coded a few things on my car today, one of them was "comfort closing delay" to 0... as I didn't want to have to press and hold the button on the key fob to fold in mirrors.
This works a treat and they fold/unfold as soon as I lock/unlock it.
HOWEVER. When I use the button on the door (the little ridges) to lock the car they don't fold in?
Do I need to change another setting for this or is it just not possible with comfort entry?
      11-09-2019, 08:03 AM   #514
bailey5
Drives: E90
hold your fingers there for like 2 sec and then remove your fingers and it should autofold
Kaisah71.50
      11-09-2019, 09:15 AM   #515
Kaisah
2017 340i  [0.00]
Yep thanks, doesn't work if you just quickly touch but if you hold it just a tiny bit longer it does.
Much better than having to hold it there for a few seconds as previous
      11-09-2019, 06:25 PM   #516
MetzgerMeister
Drives: F82 M4
There should be a way to code that so you just tap it and not hold your fingers there. Same things as no delay with the button.
      11-10-2019, 02:56 AM   #517
Kaisah
2017 340i  [0.00]
Even with everything set to no delay it still takes a brief pause to activate
      11-10-2019, 05:58 AM   #518
Lgb0250
Drives: 2014 F32 435i M Sport
Is there anyway to code the PDC to come on automatically in the front?
2014 F32 435i M-Sport
Kaisah71.50
      11-10-2019, 07:29 AM   #519
jared21927
Drives: 2016 550i
Would you really want that though? It would be beeping when you approached cars at a light or stop sign. I could see that getting really annoying as it's pretty loud even with the volume down.
Yungsta126.50
      11-10-2019, 11:40 AM   #520
Lgb0250
Not familiar with the BMW system but this works perfect in my Toyota Highlander. I would imagine if I liked to pull right up on the bumper of the car in front of me it would be annoying but that’s not going to happen very often.
Kaisah71.50
      11-11-2019, 08:00 PM   #521
bailey5
Drives: E90
      11-14-2019, 09:59 AM   #522
wilbur_the_goose
Drives: 2018 330ix Gran Turismo
Sure - just press the PDC button. I do it every time I drive into my garage
Billfitz8263.50
      11-18-2019, 07:22 AM   #523
nikkuu
Drives: bmw f22
Ciao,
i`m thinking if can high beam assist auto activate when headlight is on(on auto function), so no need to activate manually.
Thx,
      11-18-2019, 09:42 AM   #524
UnknownBeing
UnknownBeing's Avatar
Drives: 16 340i (22 M340i in-transit)
Does anybody know if the wired ENET adapter will be added to the Android app? I use a USB C -> Ethernet and it works fine with other applications.
      11-20-2019, 05:27 PM   #525
MetzgerMeister
Drives: F82 M4
A little something I learned this evening:
1. If you want to code launch control, go to transmission control unit / expert mode / 3000 Applikation / LC / aktiv
2. To code speed limiter (expert mode on each menu)
ICM > 3000 daten, > SLD_Funktion > aktiv (nicht_aktiv is the default)
ICM > 3000 daten, > C_Umschaltung_ACC_DCC > zugelassen (unterdruecken is the default)
KOMBI->3003 FZG_Ausstattung, 10->SLD_ENABLE->aktiv (nicht_aktiv is the default)
If you already have a button that says “LIM” then you already have the limiter. If you’re like me and you have the “SET” button (which sets the cruise control speed) this button will become your “LIM” button. Your “RES” button becomes your “SET” so you use this to set your cruise control speed.
There is another line of coding to toggle between “SET” and “LIM” but my car doesn’t have it, some do. From what I can see the option to resume cruise control is no longer available otherwise.
When using the limiter function it will engage at whatever speed you’re doing at the time you press it. If you’re at a standstill when you press it it will default to 20km or 30km. Therefore if you’re above it doing say 40km it will stick at that. Putting your foot hard down to the floor will allow you to override the limiter and it will return to the limiter speed when you ease your foot off again.
      11-29-2019, 02:38 PM   #526
F30zoom
F30zoom's Avatar
Drives: F34 330d xdrive
Originally Posted by CleanKM View Post
I can vouch for bimmercode. Used it on my 328d. Only issue is if you code FEM acouple of times, it throws down check engine code, but that's easily erased. I used an old iPhone of mine that I had laying around because I didn't want someone to call halfway or something and mess up the coding.
Highly recommended.
They can't as you need to put the iPhone into airplane mode to use the app, also its better using the ethernet adapter for the iPhone and cable much more stable and cheaper than the Bluetooth stuff. Word of warning V gate stuff is not recommended! States it on the app
      11-29-2019, 03:52 PM   #527
CleanKM
SQUEAKY
CleanKM's Avatar
Drives: 2014 328d
Highly recommended.
Post was two years ago... I've gone through two new phones, new adapters, and bimmercode started supporting new series....
Mind linking the Ethernet connector you mentioned?
      11-29-2019, 09:07 PM   #528
F30zoom
F30zoom's Avatar
Exclamation V-Gate not recommended
Guys
For those using IOS I would strongly suggest you buy the ethernet adaptor cable and ethernet to OBD cable. It is far more secure & stable than any other adapter and buying both is also cheaper. Both are available on Amazon.
