05-23-2024, 01:44 AM | #1 |
Rep 84
320I N20 automatic transmission fluid capacity
im the 6th owner, mileage is now 180,000KM
was thinking of doing the atf change but dont know how many L it needs sometimes I can feel like the clutch slips |
05-24-2024, 01:01 PM | #2 |
Rep 1,709
Drives: 2014 428i and 2018 X5
It holds 7 quarts total, but at most you will drain / fill 5 quarts during the process with the rest being kept up in the torque converter.
05-26-2024, 03:16 AM | #3 | |
Rep 84
my local shop sells it in a 1L bottle @ $20 SGD/bottle do I get 5L? also, do I change the sump with filter? |
05-26-2024, 06:20 AM | #4 |
Rep 6,089
There’s a whole kit for the zf transmission. You need to replace the entire pan as it has the filter built in. The process is rather involved and you need a lift. If you are at a higher mileage and it wasn’t done before you may not want to do it.
alohasurftoad3316.50 ctdriver320i71.00 |
