11-28-2021, 02:44 PM | #1 |
Rep 705
has anyone done a MPPK airbox mod to N20 lower box?
just wondering if anyone has done MPPK airbox mod from the f30 n55 to the N20 lower airbox...
curious if it makes any difference |
11-29-2021, 12:53 AM | #2 | |
Rep 5,392
The MPI modifies the lower half of the airbox under the airfilter by adding an extra air hole facing the front grill. In photos it is outlined by a piece of red plastic trim. Originally I assumed that the purpose was to allow more air to enter. But then I became familiar with the air intake system and the fact that the air opening to the turbo housing is relatively small. So the purpose of the extra hole in the airfilter box may be more to allow sound to come out. A small performance bump can be had by installing a drop-in free flow air filter such as aFe or K&N. This is how other aftermarket intakes provide a small performance bump as well. It's from the cone shaped free flow airfilter, not from the big air holes that are allowing sound to escape. Attached are some photos of the N55 airbox modification. Hope this helps! |
11-29-2021, 01:10 AM | #3 |
Rep 705
thank you, john. i see that the snow valve is also removed in addition of creating a front grill hole.
what do you think of afe pro dry s performance vs oem air filter when both are in stock airbox/intake? would the pro dry s gain hp/tq or won't matter? |
11-29-2021, 10:56 AM | #4 |
Rep 1,058
With the n20 it's almost unnecessary to do this as we have 3/4 of a ram air intake for the n20. The intake into the air box for the m20/n26 is in the grill already. One biggest things you can do for intake is add an afe grill intake scoop to the factory "intake vent" which extends the air box connection into the factory grill and replace the intake pipe after the air box.
You won't dyno more power, but throttle response is night and day when on a roll. https://afepower.com/afe-power-54-12...amic-air-scoop Check the install instructions, you'll see what i mean, and you don't have to cut up your stock intake box.
MY13: TTE400 Stage 2 turbo, Spec Single Mass flywheel + Stage 3+ Clutch, FTP V2 Turbo Inlet, Evolution Racewerks Charge pipe + Boost pipe + Intercooler, Turbosmart Recirculating Diverter Valve, aFE grill scoop + aFE Magnum Force Cold Air Intake, B58 coil retrofit, eBay Downpipe, Active Autowerke muffler, DW400 LPFP, B58TU HPFP, M5 s63TU injectors, Bimmermilvs, e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block
11-29-2021, 11:13 AM | #5 |
Rep 705
yes, already bought that scoop, intake pipe is the inlet, right?
just curious, what afe intake do you have? i m still considering whether i should use oem paper air filter, drop in afe pro dry s air filter, or just buy a new intake. i don't care about sound, i care about performance and gain. what do you think? thanks. |
11-29-2021, 12:51 PM | #6 | |
Rep 1,058
I have no idea oem vs afe or whatever air filter will give a "gain" in the box, just choose one and replace/clean as needed.
11-29-2021, 12:57 PM | #7 | |
Rep 705
11-29-2021, 01:31 PM | #8 | ||
Rep 1,058
11-29-2021, 02:48 PM | #9 | |
Rep 5,392
According to my butt dyno the aFe Pro Dry air filter definitely provides a small performance bump. It the first mod I added years ago |
11-08-2023, 12:59 AM | #10 |
Rep 3
geometry dash world Yes, some people have done the MPPK airbox mod from the F30 N55 to the N20 lower airbox. The general consensus is that it does make a difference in terms of sound and performance. The MPPK airbox has a larger opening, which allows for more air to flow into the engine. This can result in a slight increase in horsepower and torque. Additionally, the larger opening can also cause the turbo to spool up more quickly, which can improve throttle response. |
11-09-2023, 07:41 AM | #11 |
Rep 10
I've done this to my N26 air box along with an ECS high flow drop in filter. I have noticed a little more sound and throttle response. Should have taken pictures
