proTUNING Freaks
      11-12-2021, 10:39 AM   #16061
shawnsheridan
shawnsheridan's Avatar
Originally Posted by CaptainLockdown View Post
...But it's all working now! Was much easier than I thought. Thanks for the help again.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      11-19-2021, 06:44 AM   #16062
barni320
Drives: BMW 428i F32
HI
I have few questions about esys backups.
I made FDL Coding, before that i saved FA and SVT and I thought that are my backups. Now I read that to revert my changes I've should save CAFD NCD files after reading coding data.
That's procedure I've found:
Restore .NCD:
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Right-Click CAFD File => Select New FDL => Navigate to C:\ESysData\CAF and select matching .NCD file => Left-Click on Inserted CAFD => Select FDL Code.
1)So now my question is, can I do something with FA or SVT files to restore my changes without CAFD (.NCD)? Or maybe I Can load SVT and then code it somehow?
2)I have one NCD file in E-sys CAF folders, but this data is before FDL coding (automatic backup?) or it's overwritten file by me?
Edit: I don't want to VO code whole module, because i made some changes before that i want to keep.
      11-19-2021, 10:21 AM   #16063
shawnsheridan
Originally Posted by barni320 View Post
HI
Restore .NCD:
If you want to backup modified .ncd files (post FDL Coding), simply read ECU Coding Data after FDL Coding, and copy the corresponding ECU .ncd file from C:\Data\CAF to backup location.
If your plan to do so though is so you can restore FDL Coding if ECU is upgraded via programming, I would not do so as if dealer programs the car, ECU will get a new CAFD, and restoring backed up coding data from old CAFD "A" into new CAFD "B" is not wise. They may not be aligned.
Why bother anyway, when you can recode car in 10 minutes.
      11-19-2021, 10:42 AM   #16064
barni320
If i knew it before that backups are in NCD files there were be no question. I thought SVT are backups, my bad. Now i have corresponding .NCD but I'm not sure if that appeared in esys folder after changes or before i made them. Can I check it somehow? "Read coding data" creates NCD or I created it by saving my changes?
The problem is I forgot what i coded 6mths ago . During this period was no ECU upgrade, so I assume restoring data from NCD is safe.
      11-19-2021, 12:22 PM   #16065
shawnsheridan
Saved FA is backup of Vehicle Order (e.g. Build Date, Type Code, Option Codes, etc.)
Saved SVT is back of installed ECU's and their Hardware and Firmware versions.
Any time you Read Coding Data from an ECU, it creates a fresh .ncd file which contains all current ECU Coding, whatever that may be. So long as ECU has not been updated with a newer CAFD file, then restoring coding data from a backed up .ncd file.
You can Open .ncd is in E-Sys FDL Editor, and spot check it to see if it contains your FDL Code changes or not.
      11-19-2021, 12:44 PM   #16066
barni320
Thank You!
That FDL Editor clarified me everything. It's modified .ncd, so I can assume that saving changes overwrite created earlier .ncd.
Thanks for explanation.
      11-23-2021, 09:51 AM   #16067
cjn
Drives: 2021 F40 M135iX
Sean, would you be kind enough to send the latest ESys package. I'm now a couple of years out of date.
Also, which F-series data set is used for a 2021 F40 M135i car?
Thank you.
      11-23-2021, 10:51 AM   #16068
shawnsheridan
Thank you.
PM sent.
      11-25-2021, 12:21 PM   #16069
diem
Drives: BMW F31 2015
Hi Shawn
Could you also send me the latest e-sys PM?
I've got a cable but would be my first time setting it up.
Thanks
      11-25-2021, 12:22 PM   #16070
shawnsheridan
Originally Posted by diem View Post
Hi Shawn
Thanks
Your Receive PM function is disabled. PM me when working.
      11-29-2021, 04:29 AM   #16071
Mch81
Drives: bmw e61
Hi guys,
I am new to Esys coding. I used NCS expert for E series, but planning to buy G31 and I want to have same ability to do small changes.
1) I have problem with Launcher. I have MAC and I virtualise WIN1903 via parallels.
E-Sys_Setup-3.27.1_RC_b44813
E-Sys Launcher PRO 2.8.2_Build_162b BFU Edition
ESysLauncherPremiumSetup_2.8.2_Build_155
PSDZDATA 4.27.22
I did all installation but when I run Launcher Preminum, it did not start at all.
I figured ou that for virtualisation I need Launcher PRO.
All is good until providing password and activating. App falls down and when I want to open activation window again it falls down.
Do you have any clue what could be the issue?
I have installed JAVA 8, C++ version 2010 x86/64, WIN 20H2 and nothing helped.
I have read that there is version 3.x to use, but TM has disappeared and don't know how to activate it.
2) does any of you any have cheat sheet for G31?
3) if I mess anything with car. Will I be able to return back with backed up ECUs?
4) If I talk only about coding ECUs, is Bimmercode good alternative with same options (especially expert mode)?
Thank you for any help.
Michal
      11-29-2021, 02:22 PM   #16072
shawnsheridan
Originally Posted by Mch81 View Post
Hi guys,
PSDZDATA 4.27.22
Michal
Launcher PRO does NOT support VM use anymore than Launcher PREMIUM does. With MAC, you need to use Bootcamp or VMWare VM with modified .vmx file.
Cheat Codes are built into E-Sys Launcher.
I can't comment on "mess anything with car". That would depend on what if anything got messed up. Generally speaking, if just coding, it can always be set back to factory just by VO Coding.
I also can't comment on Bimmercode. I don't use it myself.
      11-30-2021, 05:23 AM   #16073
Mch81
Drives: bmw e61
Thank you Shawn! really appreciate what you do here.
OK, I will have to use my wife's laptop
Just to confirm - to fix via VO coding you mean remove VO and add it back. right?
for that I need full version od PSDZData, don't I?
What version of Esys and Launcher would you recommend?
Thank you.
Michal
      11-30-2021, 08:05 AM   #16074
shawnsheridan
Thank you.
Michal
I mean VO Code the ECU using original unmodified FA. Full needed ONLY for flashing. I use LE-Sys 3.27.1 and Launcher PRO 2.8.2 for FDL Coding.
      11-30-2021, 10:45 AM   #16075
Mch81
Drives: bmw e61
thank you
      11-30-2021, 11:56 PM   #16076
AriZoNaiCe
Drives: 2014 335xi M-Sport
Hi Shawn -- would you mind sending me the most current Esys and psdzdata info? I have an F30 that I'd like to code.
Using what I've found around the web seems to tell me that 3.27.1 is the "best" version to use, but that with a newer psdzdata results in an error in KisAlAdapater "Unsupported major.minor version 52.0", which I guess means that was compiled against Java 8 and we depend on Java 7 for Esys 3.27.1.
**Update**
The above error is the result of running Esys Launcher in a VM. There are published workarounds that require using VMware (not VirtualBox) and editing the .vmx file for your VM. In a VM, Esys is a bit slow and requires slightly more effort to get functioning, so it's recommended not to use a VM unless you are pretty comfortable with what that may entail.
      11-30-2021, 11:59 PM   #16077
shawnsheridan
I'm posting this here in hopes I can post a reply once I get figured out to help others, in case they run into the same. :-)
Thanks!
I FDL Code with E-Sy s3.27.1 and latest PSdZData. PM sent.
      12-02-2021, 08:03 PM   #16078
brokaens
Drives: BMW 320d
Is there a way to code out the auto start stop so it's default is off?
      12-02-2021, 10:07 PM   #16079
shawnsheridan
Depends on car.
      12-05-2021, 03:40 PM   #16080
AriZoNaiCe
Thanks, Shawn -- correct, as usual! If anyone else is struggling with this, another thing you can/should check is local firewall (Windows Defender Firewall in Windows 10). Once I disabled that, I was able to connect with no problem.
This is also true if using a VM, in which case you need to disable the default Firewall on *BOTH* the Host machine and the VM.
Thanks to Shawn and the entire community -- hugely helpful!
      12-05-2021, 03:48 PM   #16081
shawnsheridan
      12-08-2021, 05:10 PM   #16082
mmmm_beer
Drives: 2019 430i Convertible
Hi Shawn,
Could I also get the latest E-Sys package? My car is a 2019 F33 if that makes a difference.
Thanks!
Copyright ©2000 - 2022, vBulletin Solutions Inc.
