08-19-2018, 01:47 PM | #2 |
Rep 121
I ended up buying this one from Amazon...
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 ... just followed the instructions on the Amazon page. They give you the link for getting the most up to date APK right there, once that's installed you can update the hardware over wifi using the Avin and the newly installed Autoplay app. Works like a champ so far! All apps that we use (Maps, Pandora, etc.) now have reliable data and are speedy, unlike with the Avin |
Sherry4772.50 |
08-20-2018, 02:03 AM | #3 | |
Rep 116
Hi, what about the idrive knob? when you are in the CarPlay app and you click it does it work? or you cannot use it to open the apps and you still have to use the touchscreen? |
08-20-2018, 04:53 PM | #4 |
Rep 121
The idrive knob does work within CarPay and when you click it, it does work on all screens. Has this been a problem for the Avin supplied adapter?
08-21-2018, 01:55 AM | #5 | |
Rep 116
Basically, when I use CarPlay, I can use the knob's wheel to scroll apps, but if I want to open them I must use the touch screen. If I click the knob nothing happens. Could you please send me a video of you using the knob with carplay? So I can forward it to my supplier, and maybe he'll start to give me some assistance! Update: I would also need a screenshot of the Andorid/MCU/CarPlay/Dongle versions, so I can check if everything is ok! Last edited by Bosley; 08-21-2018 at 02:53 AM.. |
08-21-2018, 01:34 PM | #6 | |
Rep 121
Overall this is a perfect experience so far. So much better than relying on the Avin to do Nav and Music. Last edited by brikabrak; 08-21-2018 at 01:46 PM.. |
08-23-2018, 02:10 AM | #9 |
Rep 116
08-23-2018, 10:09 AM | #10 |
Rep 121
08-24-2018, 01:20 AM | #11 | |
Rep 116
Because I've just checked and I've got a more recent version than your :S |
08-24-2018, 09:36 AM | #12 |
Rep 606
The Android 4.4 and 7.1 are different systems also from hardware point of view.
Really dont know if its possible with 7.1.... you rely on the software developer if its possible with the hardware.. |
08-27-2018, 04:45 AM | #13 | |
Rep 116
Just to be sure I'll try to update the android version and the MCU.. Anyway.. brikabrak When you go to factory settings, did you find your Car Type? I cannot find the CIC 6.5" f20.. Maybe that could be the problem.. Could you please check which car type did you select? and also which idrive (A or B), also the the factory setting.. Thanks a lot for your support |
12-17-2018, 02:20 PM | #14 |
Rep 13
Just wanted to re up this thread. Not being able to click with the iDrive controller on the CarPlay side is driving me crazy. I'm tempted to purchase the adapter brikabrak has to see if that changes anything. Has anyone found a solution for this?
12-19-2018, 03:48 PM | #15 |
Rep 271
any update here? I have the same problem. I can scroll, I can't click.
I have an e90, with CIC. I have an "avin" unit with android 7.1. I also bought a zbox dongle and that one doesnt work with the idrive controller at all. IF anyone wants to buy it from me for touch only use please PM me. |
12-20-2018, 01:43 AM | #16 | |
Rep 116
Then when you open the app (without connecting the phone), you click on "Settings", you search for the app version, you click on it, hold it and scroll up for about 3-4 times and an hidden menu will open. Then there you have the possibility to set the "back" button as select button... So when you are using CarPlay you just click "Back"instead of clicking the idrive, but once you get used to it, it's not that bad |
12-20-2018, 02:52 PM | #17 | |
Rep 13
