09-23-2015, 12:10 PM | #1 |
Rep 338
Is anyone running a 255 front?
As the title says, is anyone running a 255 front and lowered without rubbing? I fit a 245/35/19 up front, lowered no prob.
switching to 18s and a beefier tire..square setup on 18x8.5 et 35. winter is coming!!!!!!!!!!!! |
09-23-2015, 01:00 PM | #2 |
Rep 3,947
I run a 255 up front half the time when I do my tire rotations. Also, it helps on the track because when you go wider up front and narrow in the rear it reduces the amount of understeer.
09-23-2015, 03:39 PM | #3 | |
Rep 823
If you're adding an extra 10mm to your tire size, it may rub a little, especially if it's a wider tire like a MPSS |
09-23-2015, 03:46 PM | #4 |
Rep 338
09-23-2015, 03:47 PM | #6 |
Rep 338
09-23-2015, 03:48 PM | #8 |
Rep 338
09-23-2015, 03:49 PM | #9 |
Rep 823
My offsets are 7mm more aggressive, but the tread width is 10mm wider if you go 255....depends on the tire you're gonna run too. I'm running V12 Hankooks, but MPSS will run much wider
09-23-2015, 07:27 PM | #10 |
Rep 444
I test fit factory 400M 18x8.5 rears w/ 255/40-18 conti rfts on the front and it clears the strut, fender, and fender liners with a 12mm spacer (which puts the offset at effectively a et35) of my F31.
I didn't drive the car outside of the neighborhood but no rubbing was apparent. Car is lowered on ACS springs -- similar to factory M sport suspension. |
09-23-2015, 08:31 PM | #11 | |
Rep 338
did you try left and right turns at a full lock? thats the only thing im worried about tbh. |
09-23-2015, 08:35 PM | #12 | |
Rep 338
shouldnt be too different from you. |
09-23-2015, 10:36 PM | #13 |
Rep 823
09-23-2015, 11:30 PM | #14 |
Rep 766
255/40/18 on an 8.5 with ET35 will not rub. works just fine.
Well weathered leather, hot metal and oil, the scented country air.
Sunlight on chrome, the blur of the landscape, every nerve aware! 2014 328ix EBII - Sport AT, Light Pkg, Blk Dakota, Moonroof, Navigation, Heated Seats, HK Audio, Driver Assist, Sport Pedals, Dinan Springs, Bilstein B8s, M-Performance BBK Last edited by MickAv8r; 09-23-2015 at 11:38 PM.. |
09-24-2015, 09:10 AM | #15 |
Rep 84
09-24-2015, 04:47 PM | #16 | |
Rep 444
Also to note, the 255 Conti RFTs are decently wide... Actual section width was measured at 10.1" on the 8.5 wheel. |
09-24-2015, 04:51 PM | #17 |
Rep 823
Treadwidth on MPSS will be around half an inch wider than the Contis
09-24-2015, 05:12 PM | #18 |
Rep 444
Should have noted i have the summer contis and not the all seasons. I think they measure out similarly to the mpss (tire rack inflated section widths on 9" wheels are 10.2 for both the conti and the mpss). Would be interested to know measured widths for the mpss in the wild for comparison to see if it is in fact that close.
09-24-2015, 09:52 PM | #19 |
Rep 18
255/40ZR18 Michelin Pilot Super Sports on 18x9 et42 Apex ARC-8s with a 3mm spacer up front here.
The car is my daily driver and I've also had it on track for a time trial event and there is zero rub. |
09-25-2015, 08:51 AM | #20 | |
Rep 766
If you are rubbing with a 245, what is your height ratio. what tire are you running a 35/40/45???
Sunlight on chrome, the blur of the landscape, every nerve aware! 2014 328ix EBII - Sport AT, Light Pkg, Blk Dakota, Moonroof, Navigation, Heated Seats, HK Audio, Driver Assist, Sport Pedals, Dinan Springs, Bilstein B8s, M-Performance BBK Last edited by MickAv8r; 09-25-2015 at 08:57 AM.. |
09-25-2015, 01:40 PM | #22 |
Supreme Leader
2283
Rep 6,548
Drives: G80, 996GT2, 996TT, 991RS 356b
Haven't seen it on stock wheels, but we did put 255/30/20 + 275/30/20 on VFF 103's for a 435i
No issues with rubbing
SupremePOWER
1562 Kimberly Ave Fullerton CA 92831 Contact: sales@supremepower.com :: Shop# (714)632-1951 Sales & service of BBS Street & Motorsport products. BBS Highest Volume Dealer 2015 thru 2022 All the top brands at the prices and service you can count on. Professional installation. |
