BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Sport+ Coding
      01-19-2014, 12:36 PM   #45
carzaddict
Drives: 2015 Cadillac Escalade ESV
Originally Posted by Timur View Post
Good job
Did you code LC as well ?
i did not, im a little scared to try the i-step upgrade lol.
2015i Cadillac Escalade ESV
      01-19-2014, 01:17 PM   #46
Tim@codemybimmer
Tim@codemybimmer's Avatar
Drives: 2022 X4 M Competition F98 LCI
I just coded it this morning. Software was already updated to one of the more recent I-Step (F020-13-11-502)
Tried it by putting it into Sport+, Shifter in DS, foot on brake and on throttle but I wasn't able to get the checkered flag to pop-up. Maybe still needed to drive it a bit longer before it would enable.
BTW in addition to the 2TB in ICM, I coded EGS > 3000 > LC (Launch Control).
My car already had Sport+ as it's the Sportline, and I had coded Sportschaulter_alt + Sportschaulter also.
Will give it a bit more testing though
      01-19-2014, 01:19 PM   #47
Timur
Russian Federation
Drives: BMW 320
Originally Posted by marcoac14 View Post
How does launch control work?
What I usually do is turn DSC fully off, hold brake, press the throttle pedal and release brake pedal.
Is it any better than "my launch control"?
I do not really think that it's any better. It decides for you which RPMs are good for optimal start. Other that that I do not know the difference. And it only activates if the engine and transmission are ready for it.
To activate LC you put sport+ , DS, hold the brake and hit full gas pedal, then engine puts optimal rpm for start, you see the flag on dash board and have 5 sec to release brakes.
This is how mine works:
www.youtube.com/watch?v=nMOFsX4v-p0
      01-19-2014, 02:12 PM   #48
Tim@codemybimmer
Just tried it again, still no checkered flag.
But it does hold the RPMs at 2500 before I let go of the brake.
But as long as the Sport Auto part of it works, that's all good. Not like you launch your car every other drive, just wanted to see how it worked
      01-19-2014, 03:54 PM   #49
carzaddict
i wish there was a way to display the gear while in normal drive...it would be interesting to see that
      01-19-2014, 07:36 PM   #50
kapkanimd
Drives: 2020 M8 Competition Gran Coupe
It took me a couple of tries. You have to be at a complete stop. Pop it in sport plus, then the shifter into sport, jam down the brake, and literally push the accelerator ALL the way to the floor past the little click you feel. It seems like a bad thing, but the rpms should be hovering around 2.5k and the flag will appear. Count like 3 seconds and release the beast.
I drive for at least like five miles to warm the car up, maybe longer if you are in an even colder climate that I am (Florida).
      01-19-2014, 11:11 PM   #51
Tim@codemybimmer
Yeah... just realized that haha, gave it another go and...
      01-21-2014, 05:39 PM   #52
Bvt13
Drives: 2016 AW M4
2016 M4  [0.00]
Just did this on my 2013 Sportline 335i and it worked perfectly. Shifts are noticeably sharper and I am glad the car will hold redline in manual mode.
One question, if I get a f30 steering wheel with paddles, can I just swap it with my current wheel and go? Or is there more coding that needs to be done to get paddles to work?
      01-21-2014, 06:08 PM   #53
momo3605
Drives: M340i LCI, 718 GTS 4.0
Okok guys, how do I get LC on my 2013 328i? This looks awesome!! I already have sport auto and sport+. Does that mean I already have LC, or do I have to code it? If so, where do I buy the cable from? There was a link in one of these forums, but it's dead now
      01-21-2014, 06:53 PM   #54
Frogman
Drives: 2012 F30 328i
Yes, you have to code it, assuming you have new enough software on your car for it to be available.
Send a PM to shawnsheridan and he will direct you to where you can get one, plus the software and token.
      01-22-2014, 06:46 AM   #55
Timur
Russian Federation
Drives: BMW 320
Yes, just swap it and set:
FEM- 3190 -> Paddles_verbaut -> aktiv
      01-22-2014, 06:54 AM   #56
Bvt13
Drives: 2016 AW M4
2016 M4  [0.00]
Great thanks. And I just want to reiterate for anyone viewing this thread, coding for SAT is absolutely worth it, there is a definite change in the character of the 8AT with the sport auto programming.
      01-22-2014, 07:09 AM   #57
Timur
Russian Federation
Drives: BMW 320
All yo need is to set EGS/3000/LC = aktiv
But keep in mind that you I-level supposed to be I-level .50 (F020_13_07_501) and above.
If it is not then you will need to update it, eather with e-sys (risk involved) or go to your local BMW dealer and update it there.
(in my city dealer took abt 45 USD to renew everything, no idea now much it is in the US)
      01-22-2014, 08:55 AM   #58
Tim@codemybimmer
Or for us North Americans, just ask them to program ASS to remember last setting, which involves updating it to the latest software.
OR
Tell them there's some electrical gremlin that's out to haunt you and a software update might help!
OR
Just ask your service advisor nicely
      01-22-2014, 09:57 AM   #59
carzaddict
Hey Timur,
My I-Step is F-020-13-11-502.
1) Is that equal to or higher than what I need to activate LC?
2) Is I-step the same as I-level? if not, how do I check my I-level?
      01-22-2014, 11:43 AM   #60
Saildave
Drives: 2014 BMW 335ix
It is possible . I have done on on my 320i.
Do the following:
Kombi => 300C ECO_FDS =>Function
FDS_MENUE_TEXT_1=> menue_3
FDS_MENUE_SIGNAL_1=> menue_3
FDS_MENUE_TEXT_2=> menue_3
FDS_MENUE_SIGNAL_2=> menue_3
FDS_MENUE_TEXT_3=> menue_3
FDS_MENUE_SIGNAL_3=> menue_3
FDS_MENUE_TEXT_4=> menue_3
FDS_MENUE_SIGNAL_4=> menue_3
ICM Module/ 3000 Daten/ IcmKod_B_Sportlenkung/ verbaut
EGS/3000 Applikation -> Sportschalter_alt -> aktiv
EGS/3000 Applikation -> Sportschalter -> aktiv
ICM/IcmKod_B_S2TBA -> verbaut
It will activate sport+ and sport transmission )))
Or you also could add 2TB option and delete 205 in salapa element
So I just want to confirm before I code. If I follow the instructions (I have a new 2014 BMW 335) I will get Sport Plus plus Sport Transmission? This is great news
      01-22-2014, 12:00 PM   #61
carzaddict
yes you will
      01-22-2014, 01:21 PM   #62
Timur
Russian Federation
Drives: BMW 320
Hey Timur,
It is higher ! Activate your LC, it supposed to work
      01-22-2014, 01:22 PM   #63
Timur
Russian Federation
Drives: BMW 320
Positive. You will get sport+ and sport transmission
      01-22-2014, 01:26 PM   #64
momo3605
How do I check my I-level? I have a 2013 and had BMW code the auto start/stop memory feature. They also updated my Control Unit software under a recall. So I would guess my I-level is ok. But just want to make sure
      01-22-2014, 01:29 PM   #65
Timur
Russian Federation
Drives: BMW 320
I am gonna try it next time I go to a dealer
      01-22-2014, 01:34 PM   #66
carzaddict
thanks! im on a project in pittsburgh and wont be home until friday....its going to suck waiting
When you make a successful connection and you read your VO, select Coding under the Expert mode menu and on the right side you'll see I-step.
From my understanding I-Step = I-Level
