BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Apex ARC-8 agressive fitment
Studio RSR
      11-02-2016, 04:26 PM   #1
lukeiswright
Luke Wright
lukeiswright's Avatar
Drives: 2012 6mt 328i
APEX offers an 18 x 9.5 et35 wheel, but does not list it on their website as compatible for the f30. I've seen multiple members on the forum who run this wheel width and offset with no problems in the rear. How come no one runs arc-8's in this sizing?
I'm wondering because I was going to buy a set of ARC-8s in 18 x 8.5s et38 up front with a 12mm spacer and 18 x 9.5s et35 in the rear. I would run a square setup but I want the extra width in the rear.
I want to have the same setup as the f30 in the pictures below except replace the 8.5 et38 + 18mm in the rear with a 9.5 et35.
Sorry about the long question but your help would be greatly appreciated
      11-02-2016, 05:58 PM   #2
rswitch
rswitch's Avatar
Drives: 13' Alpine White 328i msport
The 18x9 fits well on my F30! i have the arc-8
rswitch ..
      11-03-2016, 02:26 PM   #3
lukeiswright
Luke Wright
Yes but what about the 9.5 wides? Especially with the aggressive offset
      11-03-2016, 03:09 PM   #4
theEZV
Russia
178
Drives: F30 335i; Looking for F80
Rears will fit fine. That car with the 18mm spacer is running 18x8.5 +20, which would translate to the same fitment as x9.5 +30.
      11-03-2016, 06:25 PM   #5
fhlh
fhlh's Avatar
Drives: 2013 BMW 335i M-Sport
2013 BMW 335i  [0.00]
What tire/size and any spacers involved?
I run 18x9 ET42 on all four corners and require a at least a 5 mm spacer (I run a 10mm Burger)for the 255/40 Pilot AS3+ to clear the strut.
Same wheel with a 235/40 dunlop direzza fits fine without spacers.
Another member is running 255/40 Pilot Super Sports with no spacers.
I will say, the AS3+ is a beefy tire.
2013 335i M-Sport 8spA
2011 M-B GLK350
2000 Dodge Ram 2500 QC 4x4 CTD
      11-03-2016, 06:36 PM   #6
lukeiswright
Luke Wright
Okay sweet! I'm excited because the 18 x 9.5's have face profile 3, which is the deep concave should look bad ass
      11-03-2016, 07:08 PM   #7
lukeiswright
Luke Wright
One last question.. What tire size would be ideal for the 18 x 9.5 in the rear? I was thinking either 255/40, 265/35, or 275/35. I would be running a 235/40 up front
      11-03-2016, 08:25 PM   #8
fhlh
fhlh's Avatar
275/35-18 should work just fine out back... MEATY!
2011 M-B GLK350
      11-04-2016, 01:35 AM   #9
rswitch
rswitch's Avatar
mines staggered.. 18x8.5 et35 front and 18x9 et42 rear with the stock rfs
which are 225/45 front and 255/40 rear.. with no spacers
rswitch ..
fhlh37.50
      11-04-2016, 03:49 PM   #10
Forgiven
Forgiven's Avatar
Drives: 22, X5 45e
My f30 has camber plates on front plus the 15mm spacers.
Wheels: four 17x9.5 35et
Tires: Nitto nt01 275/40/17
Had these wheels for two years now, balances well, zero issues.
G05 - M Performance roof spoiler
Appreciate 6
      11-05-2016, 12:50 PM   #11
lukeiswright
Luke Wright
How much negative camber are you running in the front?
      11-06-2016, 08:22 PM   #12
f30m
f30m's Avatar
64
Drives: 2008 E90 M3
Such a meaty fitment How have your handling characteristics changed from stock on that setup?
2008 E90 M3 - Sparkling Graphite Metallic / DCT / slicktop / single hump
fhlh37.50
      11-07-2016, 12:02 PM   #13
R32DBP
Drives: 2014 335i M Sport, 2004 .:R32T
sub'd for more info. I have been thinking about doing a 18x9.5 square setup all around on my F30. Ideally would like to run that width with maybe 265 or 275 size tires all around. I have 19x9.5 on the rear for mine now with 275s and I like that look. Just want to downsize to 18s for some more meat and rim protection.
      11-07-2016, 01:31 PM   #14
jjcools
jjcools's Avatar
43
Drives: 2009 - 335i 6MT
That looks beastly. Nice work and solid fitment.
2022 - X5 45e M-Sport, MGM over tartufo
2009 - 335i 6mt, Monaco over saddle (past)
2015 - 335i M-Sport, Estoril over black (past)
2005 - 330i ZHP, Mystic Blue over black (past)
      11-08-2016, 11:35 AM   #15
lukeiswright
Luke Wright
Apex has stated on their site that they attempted to fit an 18 X 9.5 in the front on the f30 but it was unachievable without rubbing. Although, with aggressive front camber and spacers it would most likely be achievable (see post above with the 17 x 9.5s)
There seem to be three options
1. Buy a square set of 9.5 wides + coilovers/camber plates + spacers and pray they fit
2. Buy a square set of 9 wides and have to go down to in tire size. Plus you'll lose the "face 3" concavity of the 9.5s
3. Buy a staggered set up with 9.5 in rear and 8.5/9 in front. You'll be able to have the concavity and width in the back plus the clearence in the front. However, you'll be sacrificing the reduction in oversteer and the longevity of your tires.
I'll most likely be going with option 3 as I don't want to risk buying wheels that don't fit. Just my two cents
      11-08-2016, 11:38 AM   #16
R32DBP
Ahh yeah I figured the 9.5 all around would be a tough fit especially in the front. I am running a 8.5/9.5 F/R setup now but in 19s. I don't rub and I don't run any spacers. I will probably stick with the same setup I have now but in 18s I guess.
      11-08-2016, 12:32 PM   #17
lukeiswright
Luke Wright
Yeah it's kind of a bummer but oh well. I was thinking I would run a 235/40 front with 275/35 rear or a 245/40 front with a 285/35 rear. I would like to run the 245/285 combo because that would be the closest to stock tire height but I'm not sure if the rear 285 would even fit. Gonna have to do more research
      11-08-2016, 01:36 PM   #18
R32DBP
245/285 combo would definitely be awesome. I run a 245/275 setup now and its nice to see the 275s from behind haha.
      11-10-2016, 03:34 PM   #19
fhlh
fhlh's Avatar
ok, I know have a question. Why wouldn't the arc-8 18x9 ET30 work all for corners without spacers? I currently run the 18x9 et42 with a 10mm spacer up front , so effectively that's et32 and a 12mm in the back for et30. I'd really like to run without spacers if possible, so that's why I'm asking
2011 M-B GLK350
      11-10-2016, 07:39 PM   #20
lukeiswright
Luke Wright
So 18x9 et30 up front would be really close to poking excessively. I'm actually considering it but I'm really worried about the tire poke. I actually just started another thread recently asking about the fitment because I would love to run 18x9.
      11-10-2016, 09:28 PM   #21
lukeiswright
Luke Wright
Post a pic of your front fitment!
      11-11-2016, 02:31 AM   #22
Forgiven
Forgiven's Avatar
Drives: 22, X5 45e
-3 sir
