04-02-2015, 06:35 PM | #48 | |
National Championship #17 and Counting!
793
Rep 1,508
I love buying new, good tires! |
04-03-2015, 10:23 AM | #49 |
Rep 3
I just installed 4 on my 328i M sport 2014, they work simply awesome, just wondering about the tyre pressure since the Pzero´s were Tun Flat, I don't know if the door label should apply yet.
04-03-2015, 06:07 PM | #50 | |
Rep 1,805
I'm running 20s and this seems to be ok. 35 PSI Front 38 PSI Rear What is everyone else running?
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is 2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3 2017 Alpina B6 22 Ram Trx / 22 M5 CS |
04-03-2015, 06:17 PM | #51 |
Rep 1,436
Running 245/45 R17 square setup, they are great very gripy in corners less noise than prev. rft's 225/50 and great comfort but a little harsh on bumps and can't handle straight line acceleration even on map 0 !!!
F30 328i - 8 auto.. JB4-EWG harness, OCC, Injen Intake, AFE Scoop, AFE dp, AA axle-back - H&R springs, H&R Rear SB, Front Strut, F&R BMS spacers..
04-03-2015, 08:34 PM | #52 | ||
793
Rep 1,508
2018 i3s - Melbourne Red, Tera World, Ceramic Film all windows
Packs: Technology, Driver Assistance, HK Audio, Park Distance Control |
04-03-2015, 10:40 PM | #54 |
Rep 25
True story-- I had not had a flat tire in 29 years of driving. Bought a 335 and changed the RFTs to PSSs. The next day while driving home from work at night I hit a metal object in my lane on the interstate and blew out a rear tire. Fortunately thanks to this forum I had purchased a sealant/compressor kit and limped home. No regrets, but if you do switch make sure you have an emergency plan.
04-04-2015, 08:43 AM | #55 |
2006 TIME Person Of The Year
9720
Rep 6,445
I believe the increased tire pressure in the rear is when the car is loaded to maximum cargo capacity. Track time proved to me that I want to run something near equal pressure all around with my staggered 18" set.
04-04-2015, 10:37 AM | #56 | |
Rep 918
In any event, I went ahead and got the Mobility Kit AND the DynaPlug setup (OCD) for peace of mind when on longer trip. When my existing RFT's are due for replacement, I'll likely switch to the Michelin PSS tires. |
04-04-2015, 11:46 AM | #57 | |
793
Rep 1,508
30 psi is low if you have an F30 Sport Line. On my F30 square set up I ran 35psi all around. At speeds faster than 80mph, 30psi will be extremely dangerous. If you have PSS tires, not much possibility of you losing traction unless doing some hooliganism. |
04-04-2015, 12:16 PM | #58 | ||
9720
Rep 6,445
04-04-2015, 01:49 PM | #59 |
Pace Car Driver
1548
Rep 3,164
04-05-2015, 10:12 AM | #60 |
@obriennathaniel_f30 on Instagram
515
Rep 1,063
Drives: 582whp/596wtq '13 335i
I have Nitto Invo's and they have terrible road noise so I cant wait to switch to MPSS. I'm hoping they help with my road noise.
04-05-2015, 05:56 PM | #61 |
793
Rep 1,508
04-05-2015, 05:57 PM | #62 |
Pace Car Driver
1548
Rep 3,164
04-05-2015, 07:01 PM | #63 |
793
Rep 1,508
04-07-2015, 06:32 PM | #64 |
Rep 498
When my 435GC (lease car) arrives, I'm likely going pull off the 19" RFTs and replace them immediately with PSS'. Then when it comes time to turn the car in, I'll slap the RFTs back on.
For peace of mind I'll want emergency gear in case I have a blowout. What specific mobility kit do you guys recommend? |
04-07-2015, 06:47 PM | #65 | |
Pace Car Driver
1548
Rep 3,164
As much as I like OEM in some instances, the OEM mobility kits were $$$$. |
04-07-2015, 07:38 PM | #66 |
Rep 204
My 335i is on order, but I plan on getting this kit: http://www.amazon.com/dp/B000YMP1SA/...I2UIG86L4A3N2A
Looks like it has everything for emergency and at home, longer term repairs. |
