BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Sport+ Coding
Studio RSR
      04-22-2014, 09:05 AM   #111
carzaddict
Drives: 2015 Cadillac Escalade ESV
Originally Posted by FanboyBMW View Post
woah man!
ok i know i heard it can malfunction the CPU unit and sounds like most people with bimmers down in USA like to code so I think I can trust you guys
I am a little confused about one thing though; I have a luxury line xdrive 328i can I still code the SAT into the car along with sport +??
Another question to you guys then; Have you guys had malfunctioning issues after installing the sport + mode? warning lights, all that stuff?
I am planning to install the DINAN suspension kit, will it affect the adding of sport + ???
what year is your car? the model and line dont really matter, but the software version in your car does. SAT can be programmed...but if you have an older software version it may be harder to do.
some people have experienced warning lights but went away after restarting
2015i Cadillac Escalade ESV
      04-25-2014, 11:44 PM   #112
FanboyBMW
Drives: 2013 BMW 328xi
is it useless to code SAT into the car? what does it do?
      04-26-2014, 02:36 AM   #113
FanboyBMW
does it actually work to code the sport + into the car, or is just for looks? when you code are you basically installing information that wasnt there before or are you activating something that was blocked by bmw?
      04-27-2014, 11:12 AM   #114
mech888
mech888's Avatar
Drives: 320i & 335i
Has anyone successfully gotten launch control to work on a 320? Just curious. The 320 is looking to be the best bang for your buck bmw of the decade!
2016 M2 Gone
2014 320i Gone
2009 335i Gone
2011 328i Gone
2009 335i Gone
      04-27-2014, 10:19 PM   #115
ardyer
Drives: 2014 320xi
I had it coded, but I haven't had a chance (or a place) to try it out yet.
      04-28-2014, 09:06 AM   #116
carzaddict
its not useless to code it. SAT will make your shifts (slightly) faster and more aggressive when in Sport mode
      04-28-2014, 01:52 PM   #117
FanboyBMW
is that with the paddle shifters? or just in general? i heard SAT is just to code when youre adding paddle shifters? is this true?
      04-28-2014, 02:05 PM   #118
Frogman
Drives: 2012 F30 328i
+1. I coded this on my car this weekend. No issues.
In addition to faster / sharper shifts in sport mode, it also adds Sport+ to the list of modes selectable by the mode button.
      04-28-2014, 02:15 PM   #119
Frogman
That's without the paddle shifters.
Full SAT is the paddles, a different shifter, and coding. I just did the coding.
      05-05-2014, 04:29 PM   #120
kervanoglu
Drives: f30 328i
I did SAT coding and car shifts like somebody kicks from behind. It is like smg shifting. I think this is not people talk about. I cannot say "sharper" it is more than that. It feels like there is a problem about transmission.
Is there anybody have an idea?
      05-07-2014, 12:02 AM   #121
Timur
Russian Federation
Drives: BMW 320
Kicks are normal for SAT, you will get uset to it
      05-08-2014, 05:54 PM   #122
FanboyBMW
I am also getting that kicking and i was worried about transmission
      05-30-2014, 01:08 AM   #123
Ashil
Drives: Bmw 116i
I've tried to code the SAT into my 116i sport , but it still drives the same and doesn't show s1,s2 etc when the gear selector is switched to the left. Is there anything i've missed? i've coded the following:
ICM Module/ 3000 Daten/ IcmKod_B_Sportlenkung/ verbaut
EGS/3000 Applikation -> Sportschalter_alt -> aktiv
EGS/3000 Applikation -> Sportschalter -> aktiv
ICM/IcmKod_B_S2TBA -> verbaut
      05-30-2014, 01:57 AM   #124
Frogman
Those are the right ones. Re-read the values from the car and make sure they took.
I code SAT as follows:
1. Change the FA option code 205 to 2TB.
2. VO Code ICM, EGS, and KOMBI.
This also adds the Sport+ display to the cluster.
      05-30-2014, 06:26 AM   #125
marcoac14
Drives: E90 M3
My father has a 118i and I coded the SAT into his car becasue I added paddles and also wanted the sport+ mode. As many reported it was supposed to shift faster but it feels the same after coding.
      05-30-2014, 08:48 AM   #126
carzaddict
yeah i dont really notice a huge difference either.
the biggest difference i notice is when im shifting from 1-2-3 with my foot down on the floor.
      05-30-2014, 09:08 AM   #127
Ashil
Drives: Bmw 116i
Thanks for all the help, re-read all the values and they were stored in the car but yeah there was no difference
      05-30-2014, 09:17 AM   #128
Frogman
I also don't notice any difference in Comfort mode.
Shifts may be a bit faster in Sport mode, but if it is faster, it's hardly noticeable.
Where the shifts are noticeably faster is when the transmission is in manual mode.
Since I don't have the paddles, manual shifting has to be done by the transmission selector. Changing gears this way is very noticeably faster.
The only other thing SAT gives you is Sport+ mode. I've verified it's selectable, but I've never actually used it.
      05-30-2014, 09:20 AM   #129
Frogman
Try shifting manually; you should notice a difference.
      05-30-2014, 09:28 AM   #130
Ashil
Drives: Bmw 116i
Tried it changes like it used to, shifts up when close to redline, would it matter that no 116s came with the 2tb?
      05-30-2014, 11:56 AM   #131
marcoac14
Drives: E90 M3
Not on 116/118
I think so. But that's just a guess
      06-08-2014, 05:30 PM   #132
TractionControl=OFF
Drives: XP-38 (F30) Landspeeder
So it is bad for transmission or injectors?? I had injector problems after installing sport plus And sat.
