06-08-2022, 03:47 PM | #529 |
Rep 19
I just installed the 6wb in my F36. After cosing everything works flawlessly and installing was a breeze.
However I find something strange about my navigation display. In my opinion the circled views should be white however they show red/orange. The picture is taken at sundown, however the colors are the same during the day. How should these be displayed? I tried the 3 options in navicolor_table however this doesn't change. |
07-14-2022, 06:28 AM | #532 |
Rep 666
I notice that there are at least 4 different part numbers for the 6wb (HUD or non HUD version) from realoem database.
1. is there a particular HW version I should avoid? 2. how do i update the SW version to the latest version? what is the latest version? 3. how do i check my 6wb software version (besides from the label)? Thank you |
08-01-2022, 01:24 PM | #533 | |
Rep 1,833
08-12-2022, 12:50 AM | #534 |
Rep 906
Retrofitting 6WB to F31 LCI
I'm considering doing a 6WA->6WB upgrade on my car using a dealer-sourced 6WB cluster. I've been reading up on the coding procedure and there were a few things I wanted help understanding. My car is a 2017 F31 LCI (11/16 build), with NBTevo, current I-Step is F020-21-11-540.
During VO coding, it sounds like I need two separate FAs
With a dealer-sourced 6WB, it's going to be virginized, but do I need to flash it? Or can I go straight to injecting the CAFD?
2017 328d xDrive Sports Wagon: Estoril Blue, Black Sensatec, M-Sport Pkg
2020 i3 Rex: Capparis White, Giga World |
08-18-2022, 04:36 PM | #535 | ||
Rep 3,887
You should be able to instantly tell what gear you are in just by listening to the engine combined with the speed you are driving with.
08-18-2022, 05:28 PM | #536 | |||
Rep 1,833
08-20-2022, 11:55 AM | #538 |
Rep 40,998
DKOMBI => DIGITAL_TACHO_ENABLE = mph_mph
08-21-2022, 03:41 AM | #539 |
Rep 112
Hey guys, specific question. I got Android screen in my car and I will have 6WB cluster. Are there doing to be any issues? Would path of navigation from android be shown on cluster?
08-21-2022, 08:30 AM | #540 |
Rep 379
Only BMW native maps will show on cluster. If you plan to use Google maps or waze etc on your android screen, they won't show up on cluster.
Click appreciate if this post has helped you
Retrofits: NBT evo ID6, 6wb cluster, heated steering wheel, HUD, Kafas2 with LDW, SLI, HBA, FCW and pedestrian warning, LCW, Surround View, Parking Assist and ACC with Stop |
08-21-2022, 09:32 AM | #541 |
Rep 666
Do you have to code this? Or does it come right away as soon as you finish retrofit the 6wb and code 6wb to the car vin?
08-21-2022, 10:53 AM | #542 |
Rep 112
08-21-2022, 03:34 PM | #543 | |
Rep 379
08-23-2022, 06:16 PM | #544 |
Rep 112
I got 6WB coded to my VIN, I moved from regular, smallest cluster. I also retrofitted NBT which is coded to my car(from CIC) and everything related to NBT works great. Not any problem with navigation/music/speaker/bluetooth, etc..
However I am not sure why 6WB is not fully working. It seems optical cable which is connected to Headunit and cluster is not giving any information to the cluster. I checked optical cable and it emmits red lights as it should and it is connected as it should. I can change modes on cluster, speedometer is working, I can see next songs or change radio, call anyone, etc. I cannot set date and time and I cannot see navi guidance on the cluster. Also, cluster cannot be coded or be accessed with any amateur or professional tool(service tried to see it in the tool). Like not any cluster is connected! And when I connect old cluster with small display(it is not using optical cable), it automatically appears in any coding tool as a Kombi or Instrument Cluster. Anyone could help me please with this one? I cannot find any good answer to this one. This were happenijg with both cic or nbt system. Please some advice! |
08-24-2022, 05:37 AM | #545 | |
Rep 534
;DKMOBI NAVI_NBT_ENABLE=nbt_anzeige NAVICOLOR_TABLE=farbwelt_id5 ;HU_NBT or HU_NBT2 KOMBI_CIC=kombi_high EXTERNER_MOST=aktiv EXTERNE_MOST_DIAG=aktiv KOMBI_AUFLOESUNG=aktiv MFID_KOMBI_VARIANT=aktiv
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
08-24-2022, 05:14 PM | #546 |
Rep 112
Can I code this via bimmercode, since I never used any other tool?
08-24-2022, 05:34 PM | #547 |
Rep 112
I will try this tomorrow via bimmercode since I see all of the codes exists for the headunit. However, not sure if Instrument Cluster will appear after headunit coding because at this time I am not able to access Instrument Cluster codes. It does not exist at all at this moment if you try to access it. On bimmercode app itnjust does not show it up, and on other coding tools its just red, like none cluster is plugged in.
08-25-2022, 03:39 AM | #548 |
Rep 112
Update: @Siki78, you are a man! Thank you sp much!! I have coded HU_NBT part and I am able to set the date, board computer is working and I can see navigation on 6WB!!!
The only thing is that I cannot still see Instrument Cluster when I load parts to code with Bimmercode, so I am simply not able to code Kombi parts. Maybe this could be done via other tool than Bimmercode. Any tip? |
08-25-2022, 06:05 AM | #549 |
Rep 112
Another update: after setting navigation in iDrive everything on the 6WB works and it showing correctly which direction to take. However when I start moving, some glitch appears above arrows. Arrows(navigation) still works great, however this glitch of colours is now bothering me. Do anyone know how to solve it?
So, there is no glitch when I set destination and I do not start moving. It appears and it stays until I stop and turn off the car. Image: |
08-25-2022, 02:43 PM | #550 |
Rep 112
Last update(I hope): I managed to fix everything related the cluster besides one thing. Navigation is working perfectly, there is no glitch and I can see street names. I solved this via simple coding.
The only thing which is left to be done is to do make 6WB(Intrument Cluster) visible in any coding program or app. Currently everything is working on cluster but I just cannot see it and code it through any app. How can I make it visible in any program(Bimmercode for example)? Thanks in advance! |
