BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Retrofitting Instrument Cluster 6wa
      03-21-2016, 04:51 AM   #1
Bmwespendn
Bmwespendn's Avatar
Drives: Bmw 320DT E91 Msport 2011
Iam gonna retrofit instrument cluster on my F30.
I have just buy'ed a used cluster.
What do i need? What is the most fibre everybody is talking about?
I have CIC Prof HU.
Espen
      03-21-2016, 06:51 PM   #2
Level3
1/2 Asian Sensation
Level3's Avatar
Drives: 2011 BMW M3 e92 ZCP
I could be wrong but I don't think 6wa can interface with a cic unit. I don't think there is a most connection on cic unit for them to talk to each other.
All too easy...
      03-22-2016, 02:21 AM   #3
tomsab0
Drives: F48
6wa needs a Most Connection from HU to Kombi. Also the old VIN needs to be deleted from eprom; Therefore Special Equipment is needed...
      03-22-2016, 02:57 AM   #4
knightsabers
knightsabers's Avatar
454
Drives: Audi R8 v10 Spyder
This is the most cable you will need but I think it's only compatible with the NBT unit.
The MOST cable is the orange one with the Red LED lights
After which should join the NBT headunit to the instrument cluster.
      03-22-2016, 05:07 AM   #5
Bmwespendn
Bmwespendn's Avatar
I do have most fibre from combox right? So i have most fibre output on my cic?
      03-24-2016, 11:38 AM   #6
Bmwespendn
Bmwespendn's Avatar
How does the most input looks like behind the HU?
      03-25-2016, 06:43 AM   #7
knightsabers
454
Here's some pics behind the HU & Cluster
Original Green Cable
Removed the Green Cable
Inserted MOST cable
Behind the Cluster
      03-25-2016, 12:35 PM   #8
Bmwespendn
Bmwespendn's Avatar
I do have output in my cic 😁👍 Is the red laser gonna activate when i code the cic?
      03-26-2016, 07:47 AM   #9
Bmwespendn
Bmwespendn's Avatar
Where have u puted the green cable ?
I have buy'ed a used cluster, how do i do the steps?
      03-27-2016, 09:07 AM   #10
knightsabers
454
The red laser will light up automatically if correctly connected. Make sure it's correctly connected
      03-27-2016, 09:10 AM   #11
knightsabers
454
Hmm, good question. I forgot what I did with it. First off since it's used you might need to get the seller to clear the previous vehicles VIN from the cluster. Don't have much steps, just unscrewed the 4 screws insider the cluster and removed the iDrive Head unit to access the harness & routed the MOST cable from the cluster to the Headunit. Then it's all coding from there
      04-25-2016, 07:35 AM   #12
Alano_Mpower
Drives: Bmw 435i
were did you buy the cluster from ??
      11-02-2016, 01:40 PM   #13
gup
Drives: f20
Hello
I have a F20 and searching desperately for the Most Optic Fabric.
Please tell me where I can order 1?
      11-06-2016, 10:27 AM   #14
bimmer001
Drives: bmw F30
Hello . at one clock as your cluster M I installed it, now I have coded it like ?? you please help me. thank you very much
      11-08-2016, 04:11 AM   #15
beanbaguk
beanbaguk's Avatar
Spain
456
Drives: BMW G30 520d M-Sport
I've always wondered if there is a complete retrofit guide to doing this?
I'm hopefully about to upgrade my CHAMP2_HU to an NBT in the coming weeks so I may have the opportunity to upgrade my clocks.
The one thing I've heard is the donor 6WA must have a lower mileage than the one you are replacing. If this is the case, I'm in luck as my car has rather high mileage due to my 200km daily commute!
However, I digress. If anyone can point me towards a guide, that would be great.
Thanks!
Current car: 2017 BMW G30 520d M-Sport, BMW F46 218d Grand Tourer
Previous cars: 1989 BMW E30 316i, 1998 BMW E36 323i Coupe M Sport, 2009 BMW E87 116d, 2013 BMW F31 320d M-Sport
      01-23-2017, 12:34 AM   #16
gup
Drives: f20
I have a F20
Coding wise it was not as simple as I thought, so I was lucky to have a friend to the coding for me. The installation is not that hard.
for anyone interesting the MOST cable link here
http://www.ebay.com/itm/MOST-Fiber-O...-/262306481634
      02-06-2017, 10:34 AM   #17
M-terkait
M-terkait's Avatar
Kuwait
209
Drives: F30 335i 3/13
Attachment 1386919
Attachment 1386920
Attachment 1386921
Attachment 1386923
Attachment 1386928
So have you successfully installed the M3 cluster with no errors and Auto Gear box positions working ? how about redline, is it possible to work 100% with coding ?
Docrace 6266
      01-11-2019, 09:40 PM   #18
F30MGM
F30MGM's Avatar
Drives: 2016 340i
does this work with nbt
Car List:
2000 328i E46 Steel Gray Metallic 5SPD MT- Sold
2016 340i F30 M Sport Mineral Gray Metallic 8SPD AUTO - Current
      01-11-2019, 10:21 PM   #19
Jhnblckwood
Drives: F30 2014 320i xdrive
Does 6wa work with nbt? Yes.
      01-11-2019, 10:22 PM   #20
F30MGM
F30MGM's Avatar
Drives: 2016 340i
6wa is m3 cluster correct?
Car List:
      01-11-2019, 10:24 PM   #21
Jhnblckwood
6wa varies from build to build. Example: F10 6wa is not the same as f30 6wa but can b retrofitted into f30 with some modifications.
      01-16-2019, 03:01 AM   #22
E-mann
Drives: 2013 F30
Hello there, does anyone here know what @knightsabers did with the green optical cable that he disconnected?
