10-01-2018, 02:47 AM | #1 |
Rep 14
Setting time all the time
Hello everyone,
I have a problem every time I start the F34 325D GT, I have to set time again each time. I thought the battery would be coded enough, but it did not help. Does anyone know where could be a mistake? |
10-01-2018, 04:08 AM | #4 |
Rep 33
Drives: 2015 F34 GT
does the clock freeze or does it work after you have set the time?
i had a problem with the clock not counting time just froze on the time i had set. this was after the battery had been flat. if this is the case you could try this: 1. Open fuse box that is located under the hood 2. Take out 50 and 52 fuse 3. Start the car - dashboard should not work 4. Turn off the car 5. Place 50 and 52 fuse back to their place 6. Launch car - dashboard works |
10-03-2018, 08:38 AM | #8 |
Rep 99
Give more details please.
Have you experienced this issue with a new battery? If it is so - is it aftermarket or OEM? It can be bad IBS (intelligent battery sensor) or somekind of shortage. |
10-04-2018, 01:30 AM | #9 |
Rep 14
As soon as I'm home, I look at it. The battery is BANNER 61 21 7 575 327.
The car has two months, the vendor said the battery is original, first I tried to coding the battery, but it didn't help. IBS did not think of me |
10-04-2018, 04:42 AM | #10 |
Rep 99
yes thats an oem battery - have you tried to charge it? Im using banner accucharger 12V 6A - I had my car parked for 3 months once and the gps drained the battery a bit - so I bought a banner accucharger and it worked perfectly.
10-05-2018, 07:21 AM | #13 |
Rep 16,091
If you're going to try to diagnose and correct problems you need an OBD diagnostic tool, like this:
http://www.foxwelltool.com/wholesale...e-and-obd.html |
10-05-2018, 08:44 AM | #14 | |
Rep 14
battery, setting time |
