BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > CANADA > How to loosen/remove the cruise control settings and volume controls?
      10-26-2022, 08:04 PM   #1
derek.megyesi
M-Experienced
derek.megyesi's Avatar
Drives: 2024 BMW X5 xDrive50e AWD SUV
Hi all,
I went ahead and ordered a MeWant steering wheel cover for my 2020 BMW 430Xi Grand Coupe, but I have decided that I want to pull the wheel off to make installation easier.
I've been watching a lot of YouTube videos on how to remove the steering wheel, but I am nervous about removing the cruise control settings and volume controls (on each side of the steering wheel). In order to remove these controls, so do I have to remove the paddle shifters first? Can I just loosen (not remove) the paddle shifters? Can anyone help?
      10-28-2022, 09:06 PM   #2
F32Quartz440
Drives: F32 440i xDrive
It shouldn't be too hard to get them off, and back on again once you're done. It's just a couple of t-20 and Phillips head screws holding it all together.
You gotta remove the airbag and then the steering wheel which is just held on with one bolt. Theres one t-20 screw on either side behind the airbag which hold the paddle shifters on. After that, it's just a few more t-20s and Philips head hold the trim pieces to the wheel.
This video should be really helpful. Pretty much shows the whole process from 3:10-4:20.
Hope this helps, good luck!
      10-31-2022, 05:46 AM   #3
Th3Walrus
Drives: 2020 X3MC Alpine White/Sahkir
I have a 6MT, so I don't have paddle shifters in the way, so for me it was just two torx per trim piece and they pop off the front. From there I was able to stitch perfectly and tuck the material under the rear trim pieces without removing the wheel. Can you get a torx between the trim piece and paddle?
      11-07-2022, 09:56 AM   #4
derek.megyesi
M-Experienced
Thanks folks. I'll look at it this weekend.
f36 4 series gran coupe
