02-02-2024, 06:31 AM | #1 |
Rep 87
F32-2015 - 2.0d -190 hp - starter issues
A few days ago, after a traffic stop (with Start/Stop activated), the car only started on the second attempt.
Since then I've turned off the start-stop, but it usually only starts the second time and you hear a metallic noise the first time. The voltage with the engine off is 12.90 V and on is 15.30 V. I include a photo of the error with english translation(the original is portuguese). Any ideas what might be: starter motor, battery, alternator? Thanks! |
02-02-2024, 10:13 AM | #2 |
Rep 12
Given the error message, I'd guess the starter is probably on it's way out.
Have you hooked it up to a computer \ diagnostics machine to check for error codes ? |
antonius201827.00 |
02-02-2024, 10:19 AM | #3 | |
Rep 87
I have not checked for errors yet, I only have ESYS, can I check errors with that ? (I also have Carly, but no errors detected). The "Check Control" in the car returns "OK" . |
alternator, battery, starter |
