10-30-2018, 05:00 AM | #24 | |||
Rep 3,946
It takes a bit of computer savvy to set up correctly. |
10-30-2018, 09:05 PM | #25 |
Rep 424
I would pay someone to set up ISTA+ for me. Issue is I would have to buy a computer as well as the cable.
10-31-2018, 05:17 AM | #26 |
Rep 3,946
12-14-2018, 02:51 PM | #28 |
Rep 507
Sorry to revive an old thread but does anyone know if the NT510 will display realtime 02 data, looking to see if 02s are shot
thanks!
07 e90 335xi- Sold, 09 X5- Sold, 12 e92 335 xdrive - Sold 11 e92 M3- Sold, 15 M235-Sold,07 e90 335xi (current daily), 10 Atlantis e92 M3 (current) Way to many mods to list
12-14-2018, 03:29 PM | #29 |
Rep 16,065
I haven't tried it myself, but it should.
http://www.foxwellsupport.com/foxwell-nt-510/ |
12-15-2018, 08:20 AM | #30 | ||||
Rep 10,351
I like the idea of ISTA but it requires a little more outlay vs the Foxwell unit.
"Drive more, worry less. "
12-15-2018, 09:32 AM | #31 | |
Rep 3,946
ISTAP (older programming suite) needs the voltage to be regulated during the flashing process. However, this can also be achieved by connecting another F chassis BMW to the one being flashed using jumper cables. The other vehicle will regulate the voltage in this case. That's my workaround at least. |
12-15-2018, 11:00 AM | #32 |
Rep 797
You need a battery maintainer (not a tender) capable of 70 amps if you're going to flash. They're not cheap. I picked up a Schumacher Inc 700a on eBay for about $400. They say 70 amps but I've flashed the entire car twice and didn't see more than 30 amps I think being drawn.
For just ista d diagnostics you don't need that, but anything at your own risk. Ista d Esys Enet cable Battery maintainer Icom isn't needed for the f chassis. It will show you the kl15 voltage but at least the versions of the software I used didn't seem to care, and I knew it was good due to the maintainer. Enet worked fine. Ista p is basically Esys for dummies (bmw service department) the only nice thing it offers is running the right service functions after a flash. E.g. disabling the AC compressor run in after flashing ihka. That one got me. |
12-15-2018, 11:09 AM | #33 | |
Rep 3,946
People don't flash very often so I'm okay idling another car for a bit less than 60 minutes for a full flash. Less expensive to idle a car for an hour than it is to purchase a Schumacher INC device. |
12-18-2018, 11:36 AM | #34 | |
Rep 507
09-09-2019, 07:20 AM | #35 |
Rep 259
A question about scan tools: I have the Peake R5 which I used on my 2007 E90. Will it read everything on my 2020 F32 or will some of the codes be missing/wrong/unreadable. Trying to decide if I can keep it or need to replace it with the Foxwell. With the Peake Research site gone, and a forum and web search fruitless, thought I'd ask here.
09-10-2019, 01:14 PM | #36 | |
Rep 788
cfm56d7b5883.50 |
09-10-2019, 03:59 PM | #37 |
Rep 10,256
11-23-2023, 03:35 AM | #38 |
Rep 2
NT510 is a good choice. However, if you intend to use it for Ford, GM, and BMW, it would cost you more for software for each brand. You can take a look at autel MK808s, it's a best bang of the bucks for me. Check this post to see what it can offer you. I often turn to this website for advice before picking up a new scan tool.
