10-17-2020, 05:52 PM | #157 |
Rep 71
I pulled that part number off of realoem.com
Mine will be different than yours then as you pointed out. Be longer I would think. There's one on ebay for £166 so looks like I'll be ringing the dealer on Monday. |
10-19-2020, 02:39 AM | #159 |
Rep 71
cossie1 When you ordered the OEM loom, did it replace & plug into where the white centre plug goes on the REM, leaving the black plugs on the left & right of the REM intact?
10-19-2020, 09:41 AM | #161 | |
Rep 71
Anyway, I've ordered a cable from BMW, picking it up tomorrow. |
10-20-2020, 04:55 AM | #162 |
Rep 71
New loom in. No coding. The inners power up! Yes! No indicators though, so...
Re-coded everything to the T again from the coding provided by UKF30 (thanks again for that) as it was coding that made everything work properly. Everything working perfect now = happy days! Now I need to recoupe some money back for this crap ebay harness but overall I'm chuffed to bits now it all finally works. Thanks to everyone who helped, especially cossie1 of this thread, nice one brother! |
10-31-2020, 05:23 PM | #164 |
Rep 1,475
I'm going to attempt this soon, I have two questions that I don't think have been asked before.
One, how long are people typically taking to do the retrofit (including coding)? On the F31, I understand an extension is needed on the cable, what length of extension is needed?
11-03-2020, 11:52 AM | #166 | |
Rep 2,302
02-06-2021, 08:45 AM | #167 |
Member
79
Rep 206
Finally finished this retrofit!!!! Posted my experience here: https://f30.bimmerpost.com/forums/sh....php?t=1797529
2014 328i xdrive | Black Dakota Leather w/ DIY Blue Stitching | EB Interior trim | M Sport | Lighting | Premium | Driver Assistance | Cold Weather | LCI Tail Lights | M Performance Brakes (Blue) | 340i Muffler
06-08-2021, 08:11 PM | #168 | |
Rep 817
Drives: bmw M3 F80
07-23-2021, 07:42 PM | #169 |
Rep 2
Have just installed the black/shadow/m performance rear lights on my F30 MY64 following the BMW instructions, need a bit of help. The rear lights work perfectly, brakes, indicators, etc perfect. But when I activate rear fog it turns on my driver side reverse light.....any ideas. Coded using bimmercode by activating the lci code.
07-24-2021, 03:22 AM | #170 | |
Rep 2,302
Can you show the list of codings or from where you've got it? |
12-11-2021, 05:15 PM | #172 |
Rep 10
Appreciation
david51 Really nice write up! Thank you for your time to write it so compleated!
Last edited by Chepelin; 12-11-2021 at 05:16 PM.. Reason: Forget to mantion name |
12-14-2021, 04:09 PM | #173 |
Rep 817
Drives: bmw M3 F80
05-31-2023, 12:11 AM | #174 |
Rep 14
Drives: '10 528, '13 AlpinaB7, '16 328
Ok, so I read through all this... I can't really follow most of it, but I have what I think is a simple question.
I'm not asking about either of the rear tail lights, but the rear reflectors near the bottom of the bumper below the tail lights. I recently replaced the red reflectors, with black(smoked) LED lighted reflectors. All the instructions said was to get power from the rear tail light, black wire to black and red wire to red. I don't know where to wire these new LED reflectors in. If anyone could help me find where to wire into the rear taillights, these should illuminate when braking or signaling if that helps. Thanks a lot!! |
06-05-2023, 03:58 PM | #175 | |
Rep 817
Drives: bmw M3 F80
i bought it too if you connected them on the brakes Left lights: Exterior(E62) Black/white (flashing) Black/Yellow (Brake) Brown (Ground) Grey/purple (daytime running lights) Interior(E60) black/purple (reversing lights) Brown (Ground) Yellow/black (daytime running lights) Green/yellow (fog light) Right lights Exterior(E57) Black/Grey (flashing) Black/Blue (Brake) Brown (Ground) Grey/yellow (daytime running lights) Interior(E58) Green/red (fog light) Brown (Ground) Yellow/purple (daytime running lights) Black/Blue (Reversing lights) |
06-24-2023, 10:12 AM | #176 |
Rep 1
Hello, I've also bought some LCI rear lights, so I can follow your tutorial, can you send me the download link for the E SYS 3.27.1 software. Thanks in advance
