11-17-2016, 04:24 PM | #67 | |
Rep 2,666
Ideally you need to split the days you train these two
335d xdrive 2016 M-Sport
745Le xdrive 2020 M-Sport |
11-17-2016, 04:31 PM | #70 | |
Rep 2,666
Builds the shoulders and rear delts in no time!
11-17-2016, 05:46 PM | #71 |
Rep 32,881
11-18-2016, 03:35 AM | #72 | |
Rep 2,666
Once you crack it mate get ready for massive gains
11-18-2016, 06:15 PM | #73 | ||
Rep 2,060
What's the best thing to do to progress for example with a bench press? I can probably press about 70kg at the moment which for me is doable but challenging. Is it best to stack on a bit more and lower the reps? Also how frequently should I be increasing the weight in order to progress. Not really looking to bulk up massively but would just like to be challenging myself a bit more and perhaps increase size a bit. |
11-18-2016, 07:10 PM | #74 | |
Rep 32,881
Also important to train whole body, as the more muscles you train, the more growth hormone your body produces. Also do you have enough protein? Should consume between 1.5-2 grams per kg of body weight per day. |
rich100874.50 |
11-19-2016, 01:44 AM | #75 |
Rep 2,060
Thanks Teaston.
I do a range of weights working different muscle groups but nothing much scientific about it really. I'm aware that its probably better to work different muscle groups but possibly I bit like yourself time is often at a bit of a premium. I think I've plateaued somewhat so probably just need to adjust as you've suggested above. In terms of the protein, very likely not, I used to take protein shakes after workouts but haven't done so for a while so think I need to address that again as well. How's yours going now? Last edited by rich100; 11-19-2016 at 02:27 AM.. |
11-19-2016, 04:27 AM | #77 | |||
Rep 2,666
Stick to heavy compound movements when strength training Bench press Clean and press Back squats Deadlifts The minor muscle categories will still be getting hit and vitally having a needed rest To increase bench press try to work on your triceps as well then are the main stabilisers for the lift the chest is where the power comes from Take your grip to the centre of the bar so both hands are 3" apart them press like you would a bench press keeping your elbows tight in you won't be able to do a lot of weight to begin with but you will be solely hitting the triceps Also try doing some static floor movements e.g bench press from the floor, so lay on the floor prop up the bar on the sides so the bar is starting from you chest then up in explosive press and slow as you can back down this trains your inner lower chest fibres which in turn will help a lot with the sticking point on the normal bench press at the bottom Sorry for rambling on
rich100874.50 |
11-19-2016, 04:43 AM | #79 | |
Rep 2,060
Not at all, thanks very much for providing such an informative response. There are some really helpful ideas there. Will give these ideas a try next time i'm in the gym. |
11-19-2016, 05:10 AM | #80 | |
Rep 32,881
http://www.myprotein.com/sports-nutr.../10530943.html Also their protein cookies (I recommend the white chocolate almond): http://www.myprotein.com/sports-nutr.../10530674.html And brownies are nice too: http://www.myprotein.com/sports-nutr.../11094927.html Also get some creatine, it's cheap as chips & has made a huge improvement to my strength! Noticed a change after 1 week and by 3 weeks I was lifting so much more! http://www.myprotein.com/sports-nutr.../10530050.html |
11-19-2016, 05:13 AM | #81 | |
Rep 2,060
That's great, thanks |
11-19-2016, 05:18 AM | #82 | ||
Rep 2,666
rich100874.50 |
11-19-2016, 05:26 AM | #83 |
Rep 2,666
Also form is important and "mind to muscle" try to connect your mind with the muscle you are working and eliminate using others by keeping focused on that muscle keeping your body as still as possible. You see people in the gym throwing there body all over especially when training arms and most of the time are training their back not biceps haha
rich100874.50 |
11-19-2016, 05:36 AM | #84 |
Rep 32,881
Also rest time i think is the main thing that has made me grow so quick!
45-60 secs between sets for isolation exercises. 60-90 secs for compound exercises. When I was going to the gym I used to go minutes between sets and saw much slower gains. |
M40CCA1437.00 |
11-19-2016, 03:37 PM | #86 | |
Rep 2,060
I see a lot of guys doing some quite strange looking things and which to me are likely going my to result in an injury. I saw someone today letting a bar bell above his head, quite a big weight but he seemed to be quite badly arching his back to lift it and just looked like a recipe for an injury. tried a couple of things you / teaston mentioned earlier higher weight lower reps, felt like I'd worked hard at the end of it. |
11-20-2016, 03:38 PM | #88 |
Rep 25,113
On the supplement side of things I tried and dropped ZMA after a couple of months. The results for me where phenominal, probably associated with some of my quickest advances, slept like a baby and felt so much stronger. ..... however the unacceptable side effect for me was the quite common acne outburst Shame as I was very impressed with the results. Currently I go only with protein and creatine.
Just sharing in case you were considering also. Enjoying this thread and just started another 13 weeks of PT at my local place. |
