12-14-2016, 08:08 PM | #1 |
Rep 203
Ceramic brake pad options for F36 435 X-drive GC
Has anyone here upgraded their brake pads to ceramics on their F36 435 xdrive GC?
I had akenbono's on my S4 and they were awesome, barely any brake dust, no noise and sharp bite. I found these but they say for 428i only.. https://www.carid.com/2016-bmw-4-ser...-94693012.html |
12-16-2016, 09:39 AM | #2 |
Rep 258
Drives: F30 320i (328i ECU) M-Sport
I only do not recommend Ate Ceramic.
Those are squeaky when cold and don't hold spirited driving.
'13 F30 320i (328i ECU) RWD M-Sport
Michelin PSS, M-Sport brakes, 320i LCI muffler F32 bottom V-bar F80 bottom reinforcement plate Koni Sport, M-Performance springs, M135i Anti-roll bars |
12-16-2016, 09:24 PM | #4 |
Rep 4,876
I'm looking for ceramic pads for my 340 m-sport with no luck as well. I had Brembo ceramic pads on my E90, and they were amazing. Great feel, no dust. Can't find them for the F30 though.....
12-18-2016, 01:54 PM | #5 |
Rep 203
Wires - if they make akebono ceramics for your car I would highly recommend.
As an update, just ordered Power Stop Z23 Evolution Sport Performance Ceramic front and rear Brake Pads... installing in 2 weeks, will post a review. |
12-19-2016, 07:22 PM | #6 |
Rep 4,876
I checked ECS Tuning, and they claim the EBC Red Stuff pads fit my setup. I have a set on order and they should be here end of the month.
Thanks ajg.esq for the suggestion. I have heard great things about those pads. |
12-21-2016, 10:52 AM | #7 | |
Rep 258
Yellows unfortunatelly are track-oriented, and squeak like hell when heat up.
12-24-2016, 05:37 AM | #9 | |
Rep 603
They bite about the same as the OEM when cold and get better/more aggressive the hotter they get. I've never had any other pad in 30 years driving with less brake dust. Just make sure you give them a good slow bedding in as recommended!
335i F31 RWD in SB || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around || Various: LED bulbs: Fog-L. front | Turn Signal f&r | Brake L. | Reverse L. | Rear L. | Rear Fog L.
12-29-2016, 05:59 PM | #12 |
Rep 4,876
Check out ECSTuning, they were the only site that listed pads for my 340i (even though they apparently fit back to ~2011).
I put on the EBC red's this morning. The F30 is really easy for brake swaps, and took about 2 hours with a floor jack and leisure install. On the F30 (2016 m-sport), the EBC part numbers are: Front EBC RedStuff Performance Brake Pad Set Mfg Part #DP32130C Rear EBC RedStuff Performance Brake Pad Set Mfg Part #DP32133C Last edited by Wires; 12-30-2016 at 08:50 AM.. |
12-30-2016, 02:49 PM | #13 | |
Rep 259
Do you know if the F32 Msport shares the same part #'s? |
12-30-2016, 05:15 PM | #14 |
Rep 203
As an update, had the Power Stop Z23 Evolution Sport Performance Ceramic pads installed yesterday. Bedded them last night. 1000x improvement over stock. Good bite, improved stopping distance, very pleased.
12-31-2016, 07:49 AM | #15 | |
Rep 603
http://ebcbrakes.com/Assets/ecatalog...gue.html#p=132 FRONT: If you have a Europe or US 335i/435i/340i/440i with either 340mm or 370mm front rotor and Brembo 4-piston caliper RedStuff part #: DP32130C REAR Variant 1: If you have a Europe or US 335i/435i/340i/440i with 330mm rear rotor and ATE 1-piston caliper RedStuff part #: DP32131C REAR Variant 2: If you have a Europe or US 335i/435i/340i/440i with 345mm rear rotor and Brembo 2-piston caliper RedStuff part #: DP32133C In general for other US Models check with the US catalogue, as the US brake sizes are not like the Europe for several models. (for Europe Models use above linked UK/Europe catalogue) http://ebcbrakes.com/Assets/ecatalog...2016.html#p=52
Dr Thrillride1397.00 |
12-31-2016, 12:05 PM | #16 | |
Rep 259
01-11-2017, 11:16 AM | #17 |
Rep 83
I have the M Sport Brakes on my F36 and switched to the Power Stop Ceramic pads. I'm liking the switch so far. Positive pedal feel, good stopping power and now no more squeal. I haven't ridden them long enough to comment on dust, but I'm sure they will be less than stock.
01-11-2017, 02:41 PM | #18 | |
Rep 259
