03-03-2020, 12:56 PM | #67 |
Rep 1,282
I have the turbosmart bov installed with no issues. The car feels great and it seems like it can hold better boost.
SOLD! X5 35i sdrive- JB4 SOLD! 435i- Cary Jordan E30 Tune~ Dinan Turbo~ BM3 trans tune~ XDI-35~ 3.5 T-map sensor~ VRSF HD FMIC~ VRSF Chargepipe~ VRSF Catless Downpipe~ CTS Intake~ FTP boost pipe~ FTP intake inlet~ FTP oil catch can~ Turbosmart dual bov~ |
alohasurftoad3076.50 |
09-17-2020, 11:43 PM | #68 | |
Rep 2,639
Today is your lucky day I'm getting the dual port installed and I'll provide you your favorite thing ever: comparison logs.
09-18-2020, 01:50 AM | #69 | |
Rep 2,357
(A Dane in China) |
09-18-2020, 09:52 AM | #70 | |
Rep 7,602
AmuroRay2267.50 |
09-18-2020, 11:45 AM | #71 |
Rep 2,639
My logs are always multi-gear, 2nd gear 2500rpm to 5th gear 6500rpm.
09-18-2020, 01:16 PM | #72 | |
Rep 2,639
First things first, the sound this thing makes is ridiculous, it's not obnoxious but you get a nice whoosh and small flutter. Second thing, I'm getting a code like the two others, Diverter valve, actuation cable disruption. It doesn't seem to affect anything but I'm sending a email to turbosmart to try to see what it is. When the mechanic took out the DV+, it was pretty bad, it had some crusty oil around it and it seems like you do need to oil it or it will stick. Unfortunately, he also lost the top long extended bolt. If anyone wants to buy my DV+, I'll sell it for 70$ Third thing, here's the logs. GFB DV+ https://www.bootmod3.net/log?id=5f55...0b4351832dd8a9 Turbosmart Dual Port VR9 https://www.bootmod3.net/log?id=5f64...0b4348f8afd2c0 Ignoring the timing as I just changed gas stations, I could see that the WGDC is slightly lower, and there's less overboost. I'll continue to monitor the code and log more as I go.
09-18-2020, 03:12 PM | #74 | |
Rep 7,602
Also very interested to see their response, because getting a CEL for a DV is a dealbreaker for me. Have any pictures of the removed DV+ and how many miles were on it / age? |
09-18-2020, 03:25 PM | #76 |
Rep 7,602
09-18-2020, 03:39 PM | #77 | |
Rep 2,639
Here's your pictures of the DV+ Overall in good condition other than the oil around it, and I think about maybe 60-70k miles? I'm not too sure. I got off the phone with Turbosmart and they stated that they sent it to their tech team and they'll look into it to make sure, but they stated that the code is there since you replaced the entire DV, it's a brand new unit and not the OEM DV, they also stated that the plumb version does have a slightly stiffer spring and it might have a jammed closed code at low rpm but will work as intended in the high rpm. There's nothing wrong with either codes basically. They'll get back to me next week after their tech team confirms this. But there is no CEL at all, and the car runs great. I do have a lapping day tomorrow, so I'll do a giant log for the session.
thejeremyman94362.00 AmuroRay2267.50 |
09-18-2020, 03:42 PM | #78 | |
Rep 7,602
09-18-2020, 03:45 PM | #79 | |
Rep 2,639
Not to mention you don't have to worry about maintenance of the DV, just install and forget.
09-18-2020, 04:12 PM | #80 | |
Rep 7,602
09-19-2020, 05:23 PM | #81 |
Rep 62
Got my turbosmart bov last week along with the MST v2 inlet. Gosh it sounds amazing.
Pre BOV: https://www.bootmod3.net/log?id=5f5c...90c62dfcacc86a Post BOV: https://www.bootmod3.net/log?id=5f64...0b4348f8afd279
KWV1’s, Remus sport exhaust, VSRF hi-flow cat, TIC & Charge pipes, 5” stepped intercooler; turbosmart BOV,MST V2 inlet, MHD Stage 2, oem m437 wheels, m performance alcantara steering wheel.
oma3710194.50 |
09-19-2020, 08:36 PM | #82 | ||
Rep 529
2013 F30 335i xDrive M-Sport 6MT (FBO/BM3 custom tune by HCP, 91 oct, 550i clutch, xDelete)
09-20-2020, 09:25 AM | #83 |
Rep 2,639
Question for you, do you know where the DV electric connector comes from? Like from where it plugs into the DV/BOV. I tried to trace the cable back to where it comes from but there's so much shit in the way, I couldn't do it without taking apart everything, also tried looking online at manuals but couldn't find any info.
09-20-2020, 11:05 AM | #84 | |
Rep 643
M235i rwd 6mt
09-20-2020, 11:21 AM | #85 |
Rep 2,639
From what I can see, it has slightly lower WGDC, but usually you should see some difference during the multi gear changes. I do notice that PWG gets more of a benefit from it then EWG does.
09-20-2020, 01:19 PM | #86 | |
Rep 7,602
I documnted everything in the inlet thread, specifically my post here: https://f30.bimmerpost.com/forums/sh...&postcount=173 You will also see a gallery of how i did the MPPK mod - i didnt just drill the holes (thought that was ghetto), but rather copied the shape of the MPPK box and cut that hole, and modified my snowflap without completely deleting so as to not block airflow from the front opening. |
akgambino271.50 alohasurftoad3076.50 |
09-20-2020, 01:20 PM | #87 | |
Rep 7,602
09-20-2020, 09:59 PM | #88 | |
Rep 2,357
Also why is the boost target fixed at 17.9? Should this not adjust depending on load request? Try to compare to this MHD PS2 OTS. There is a load target that is actually being followed quite precisely and boost target is adjusted along the way to do this. https://datazap.me/u/harkes/ps2-ots-...a=3-5-10-11-16 Fearing to start a war here but that 2H looks very crude and hasn't improved since I stopped using it ~2 years ago. PS: Not saying that the MHD is perfect - cause it also has its issues, but I think these are more related to PWG in general that is just a B*TCH to tune. PPS: I consider my custom tune "finished" (will drive it for a few weeks to see if anything to tweak). Work done by Fabian from PureBoost and he was the only person of 3 "high profile" tuners that managed to make a working tune for my car. Biggest issue I still have is the post shift overboost but it seems to be either that or a dip in performance which I can feel in the car. 100-200kmh in 7.5sec https://datazap.me/u/harkes/fabian-v...a=3-5-11-12-17
(A Dane in China) Last edited by harkes; 09-20-2020 at 10:10 PM.. |
